Anyone had to replace bearings in the rearend?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guitars&tacos, Jan 31, 2015.
  1. Jan 31, 2015 at 12:57 PM
    guitars&tacos
    guitars&tacos [OP] Well-Known Member
    North Metro Atlanta
    2018 White TRD 4x4 Off Road 6 MT
    The rear end in my 08 Prerunner TRD has been whining for a while. Not it sounds more serious. I am kind of upset because I had my mechanic look at it and he replaced the left rear axle bearing. The noise is still there and loud as ever so he said the other one needs replacing too.
    I had my wife drive me around the neighborhood while I sat in the bed today and to me it sounds like the noise is coming from the rear diff. Looks like there are some bearings in there too. Am I correct? Anyone else ever went through this?
  2. Jan 31, 2015 at 1:02 PM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Lots of bearings in there. 2 Pinion bearings, a carrier bearing on each side of the 3rd member where the axles go in, and of course the rear wheel bearings. I've blown up plenty of differentials on older Toyota trucks due to downright abuse when I was younger but I've never had to touch the diff on a 2nd gen besides changing the fluid every 35-40k miles or so.
  3. Jan 31, 2015 at 1:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The whining you describe is most likely the pinion bearing , does it get loud when letting off the gas/coasting down hill ??
    But yeah I paid just under $200 for a complete bearing kit...
    EDIT: Unless you know diffs/gearing & have the tools to do it let a qualified shop do the rebuild
  4. Jan 31, 2015 at 1:13 PM
    guitars&tacos
    North Metro Atlanta
    At real low speeds it has what I can best describe as a lower rumbling growl sound. Freeway speeds it is higher pitch and when you let off it DEFINITELY changes pitch. I'm bummed my guy changed an axle bearing at $440 and still has the issue.
  5. Jan 31, 2015 at 1:15 PM
    guitars&tacos
    North Metro Atlanta
    4WD...I could never do this myself. I would certainly take it to a shop. I wonder how much it will set me back?
  6. Jan 31, 2015 at 1:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Def. pinion is going out, bet theres no preload left in it either...
    & you got fucked on the axle bearing & the so called mechanic is either a liar or stupid (your choice) & you can tell him I said it...He should've checked the pinion for excess play, simple to do & takes about 30 sec. to check
    Fl keys taco likes this.
  7. Jan 31, 2015 at 1:20 PM
    guitars&tacos
    North Metro Atlanta
    Yeah bummer. I was really shocked by how bad it sounds today while riding in the back of the truck in the bed. That sucker is whining!!! Also sucks too cause I don't abuse mine at all and take great care of the truck. This will be the first somewhat serious.issue I have ever had with any of my 3 Tacomas.
  8. Jan 31, 2015 at 1:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Even if not a mech. without a grip of tools you can pull the 3rd member (the guts of differential) pretty easy, so $200 for bearing kit/another $200+ for a competent bench job you can get it done for less than that thieving asshole did for 1 axle bearing
  9. Jan 31, 2015 at 2:16 PM
    85GT 79FJ40
    Ken
    New Hampshire
    Another thing is to quit driving it before you need a ring and pinion too. I'm rebuilding the diff in my BMW right now and it's certainly not a job for a novice.
  10. Jan 31, 2015 at 2:41 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    First thing first.
    Have you check Differential oil level ? When was last changed?
    Secondly your cheapest option is to pull third member from junk yard and have it swapped. Good rebuild is going to cost you and if they open and find out your gear is already crap you you will have to pay for another third anyway.
  11. Jan 31, 2015 at 2:46 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I have a '14 DCLB Sport that has a howling rear end. When I get between 50-60 and let off the gas is when it does it. I'm only at 3500 miles, I'm waiting to get things a little more broken in before getting it fixed. There is a TSB out for trucks that howl like mine.
  12. Jan 31, 2015 at 4:43 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I've never seen nor heard anything about a diff TSB but what some of you describe it can't be anything else but the pinion bearing. (howling on de celeration) & it's subjective it may make noise & last the lifetime of ownership or it could grenade tomorrow, I drove mine w/howling for over a year but when it got to a point where I could physically rotate the pinion almost 3/4" out of the housing figured it was time to fix...
  13. Jan 31, 2015 at 7:18 PM
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    my rear diff grenade yesterday and i am lucky i was just getting out of my driveway and not going 100kmh the rear diff lock up . Be safe and have it fix !
  14. Feb 2, 2015 at 6:27 AM
    guitars&tacos
    North Metro Atlanta
    Bummer. Sorry to hear. Any details you mind sharing? Did you have noises before or just a sudden blowout? What year/mileage?
  15. Feb 3, 2015 at 8:26 AM
    guitars&tacos
    North Metro Atlanta
    Guys-
    So I took the truck to a reputable mechanic near my home. The entire rear diff is shot. I could use some help on the quick.
    A complete replacement of the entire diff is going to be:
    Option A 3 year nationwide parts and labor warranty $2800
    Option B: 1 Year nationwide parts and labor $2300.
    Does this seem crazy high?
  16. Feb 3, 2015 at 8:54 AM
    BlueT
    NorthEast
    Wow, That is crazy. almost $3 grand for new Diff ? :eek:
    Go to Junkyard pull another one. fill with oil, continue driving.
    EDIT: If it is whinning than its not completely gone, swap gears and bearings and be done with it.
  17. Feb 3, 2015 at 9:03 AM
    BlueT
    NorthEast
    Found one in Atlanta, Georgia thats a price should be with housing.
    2007
    Rear Axle
    Toyota Tacoma4.0,AUTO,4X2 4x2, Pre Runner, w/differential lock (3.73 ratio), electronic92,524A$J22981$1335.1LKQ Atlanta USA-GA(Jenkinsburg) E-mail 1-800-775-2710
  18. Feb 3, 2015 at 2:40 PM
    guitars&tacos
    North Metro Atlanta
    It seems no one I am talking to is tooled for a rebuild. I may be completely wrong, but everyone wants to do a direct swap for all new stuff as opposed to a rebuild. I am parking it for a while until I feel I have found the right option.
  19. Feb 3, 2015 at 3:27 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    East coast gear supply has complete 3rd members assembled for around $675. if you follow the instructions on this site it should be a relatively easy swap.
  20. Feb 3, 2015 at 3:37 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
