Anyone had trouble buying Engine oil yet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Oct 26, 2021.
  1. Oct 26, 2021 at 10:25 AM
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
    I have an oil change coming up on my 3G. A couple electrical generation projects I am working on are now stalled due to zero availability of Diesel Engine oil, in any quantity, where I live.
    Anyone starting to see this with 0W20? Should I be panic buying?
    Junkhead and tacotoe like this.
  2. Oct 26, 2021 at 10:31 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I noticed a pretty lacking supply of diesel rated oil at my local Tractor Supply the other day. I haven't bought any 0w20 in a while, but every manufacture makes it. However you might not get the exact brand you are looking for and will have to settle for a different brand. Hell in the 3.5 2GR I'm sure you could use a 5w30 for a change or two if need to be. I'm sure the owners manual Nazi's will come after me for saying that :laugh:
  3. Oct 26, 2021 at 10:32 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    dont know where U live
    some/ many shortages are contrived
    U want diesel oil ( ROTELLA ) ...................try a full line truck stop
    tacotoe likes this.
  4. Oct 26, 2021 at 10:32 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I bought some Mobil 1 0W20 @ walmart.com late last month (before the rebate ended on Sept 30 2021).
    shakerhood and tacotoe like this.
  5. Oct 26, 2021 at 10:34 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I've noticed my local Walmart out of some varieties and figured it's just because our local Walmart sucks. Then found the same situation at the larger store in Lincoln NE.
    I've been buying the 12 quart box and have enough for awhile.
    Panic though:notsure:
    Junkhead and Stocklocker[OP] like this.
  6. Oct 26, 2021 at 10:34 AM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Any diesel shop or even independent mechanic worth their weight sure as hell ain't buying oil at TSC. There is no shortage, you're good...
  7. Oct 26, 2021 at 10:35 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Nope. Costco and Advanced Auto shelves were fully stocked when I was in the past 2 weeks.
    BMH and Stocklocker[OP] like this.
  8. Oct 26, 2021 at 10:36 AM
    Stocklocker
    17TRDORDCSBAT
    It’s the diesel shops that can’t get any engine oil. They are literally sidelining freight trucks now, which of course exasperates the situation.
    shakerhood, Junkhead and tacotoe like this.
  9. Oct 26, 2021 at 10:37 AM
    Roberto123
    Roberto123 Well-Known Member
    robert
    2018 Tarcoma SR 4X4 Dbl Cab
    Saturday I had to stop at three different gas stations to get two quarts of oil for my kid's old Accord. I thought it was just happenstance.
  10. Oct 26, 2021 at 10:38 AM
    Stocklocker
    17TRDORDCSBAT
    Good to hear.
  11. Oct 26, 2021 at 10:39 AM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    Ha just ran into this last night. Got the last 5 qt bottle Mobil 1 at walmart to go with an extra quart I had at home.
    tacotoe likes this.
  12. Oct 26, 2021 at 10:39 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I just did my annual oil changes on 4 vehicles, was able to get plenty of Walmart Supertech 0w-20 for 3 of them and 5w-30 for one.
    tacotoe likes this.
  13. Oct 26, 2021 at 10:39 AM
    Stocklocker
    17TRDORDCSBAT
    Hah. If this gets out of hand, we’ll all be doing 10K oil changes whether we like it or not.
  14. Oct 26, 2021 at 10:39 AM
    Cereal_killer
    Dan
    Yeah
    I don't believe that for a second. I'm a class A CDL driver and I can tell you there's no talk of oil shortages around here. Rotella sucks anyway, most companies use LE.
    SR-71A, DavesTaco68 and hiPSI like this.
  15. Oct 26, 2021 at 10:40 AM
    Stocklocker
    17TRDORDCSBAT
    How would you like me to prove it to you?
    manwithtools and SR-71A like this.
  16. Oct 26, 2021 at 10:41 AM
    Stocklocker
    17TRDORDCSBAT
    Just took a while to work through the system. “Supply crisis”. Not my words.
    https://m.youtube.com/watch?v=jyCCnLlXbog
    oconnor, shakerhood and davidstacoma like this.
  17. Oct 26, 2021 at 10:42 AM
    Cereal_killer
    Dan
    Yeah
    Since you seem to think I'm personally attacking you I'm done here.
    Call LE and inquire about supply if you'd like to for personal reasons but you have nothing to prove to me bud. There will still be gasoline engine oil on the shelf next time you need it. Carry on.
  18. Oct 26, 2021 at 10:43 AM
    Stocklocker
    17TRDORDCSBAT
    I don’t think you are attacking me at all. Text has its limitations. I’m just generally curious about this situation now that I’m seeing it first hand.
    Im all good with your observations, and thank you for them.
  19. Oct 26, 2021 at 11:06 AM
    sporin
    sporin Well-Known Member
    Dave
    Vermont USA
    '21 Tacoma TRD-Offroad
    If you are seeing motor oil running out locally, it's likely the same supply chain issues that are affecting virtually every other product on the market. I don't believe it's a genuine "shortage" issue so much as a "can't package it and get it to stores fast enough" issue.
    Grease is something that folks seem to genuinely be scrambling to get. The big Chemtool explosion put a serious dent in the supply as they made grease for a number of big brands including Shell. That plant was the largest industrial grease producer in the US.
    https://www.mystateline.com/news/cause-of-rockton-chemtool-fire-ruled-accidental-says-fire-chief/
    The other grease manufactures have increased production to try and compensate but I know we are selling a LOT more grease since that accident (we sell TRC) because it's harder to find locally.
    Slick Taco and Roberto123 like this.
  20. Oct 26, 2021 at 11:28 AM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    What I noticed a couple of weeks ago at Walmart was except for a few off brands, there was almost no conventional oil on the shelves at all. Plenty of choices for Synthetic across all brands and weights and a few choices of semi-synthetic. I then went to AutoZone and saw the same thing. I ended up with Castrol High Mileage 5w30 semi-synthetic. I also noticed that the price difference between conventional and synthetic is only a few dollars now.
    sporin likes this.
