Anyone has any experience installing kill switches??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Junetaco03, Aug 31, 2018.
  1. Sep 1, 2018 at 11:09 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Ah. GPS. My relatives Grampappy has a SPOT(?) GPS tracker. He has is tucked away somewhere in his Heep.
    Showed me his current gps position on the puter, just over satillite. $15 subscription a month. Plus the unit cost, I'm guessing...
  2. Sep 2, 2018 at 2:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I wasn't thinking of breaking one and putting the broken one in when parked overnight / in bad areas as one more layer of security so they don't see it missing and jumper it.
  3. Sep 2, 2018 at 2:29 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Someone turned me on to a latching relay that could be activated by pressing a hidden switch or a non-functioning factory dash switch (just think of the switch that you perhaps never use). It would start the fuel pump along with the ignition of the button is pushed and continue to function until the vehicle is turned off. Then you repeat to start it again.
  4. Sep 2, 2018 at 3:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yeah. 'Cause all the '84's had those.
    @Junetaco03 if your truck is a manual trans, you just detered a bunch of potential thieves. At least the joy riding kid crowd.
    Your biggest group of potentials is folks who want to get it over your southern border to never return. Your vintage of truck is like gold in Central America.
    While I'm sure it's doubtful that the '84 had the clutch interlock (have to have clutch depressed to start truck) that is a good circuit to interrupt and use a discreetly hidden switch to kill. Lots of sports car guys do that. I've even seen switches that were the cigarette lighter, as in you had to push in the lighter to start the vehicle.
    As far as tracking, an old cell phone with 'find me' software, hidden in the vehicle works well. Connect it so it's on charge when the vehicle is running, disable all the other apps and screen, and the battery will last hours when the vehicle is not running.
    But if it gets flat bedded to be prepped to haul South, your bet protection is a stated value insurance policy.
  5. Sep 2, 2018 at 7:55 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I literally was thinking about laying a concrete slab, some thick chain and connect to rear axle. Hard to do all of that in the middle of the night without a sound. Hah
  6. Sep 2, 2018 at 9:15 AM
    Petrol
    Petrol Well-Known Member
    Central Va.
    Tacoma
    The comments by Indy back in post #10 are spot on.
    Under the topic of vehicle theft, assuming the keys were NOT left in the vehicle, it is often the older vehicles that actually get stolen largely because they are easier to steal. Those older vehicles have less anti-theft devices AND the techniques to steal them have been well developed by the criminal community. Assuming we are not talking about the use of a tow truck or flatbed, about 99% of the thefts can be prevented by simply taking the keys with you and that last 1% can be prevented with some simple device such as a kill switch.
    There are a LOT of ways to wire a kill switch but it's important to make it somewhat convenient to use. One of the best ones I saw was hiden switch mounted to the shifter (manual transmission). The switch was only closed when the shifter was in a particular gear. You would leave the car parked in 1st or reverse but you had to put it in another gear (2nd) to close the switch and allow power to reach the starter solenoid. It worked like a neutral safety switch on an automatic but it was on a manual transmission and was set up to close in a specific gear.
    The rig was wired through a hidden double throw switch so that it could be returned to completely original operation if someone else needed to use the vehicle and you didn't want to inform them of the kill switch.
    Another good system is the "Pull Pin" switch where something must be removed (or inserted) to close a hidden switch. The "something" can be an innocuous tool such as a screw driver or an actual part of the vehicle like an ashtray or a bolt. This system works practically well in cluttered, crappy old work trucks that are full of junk. No one ever thinks of pulling that $0.50 screw driver out of that hole in the bottom of the center console to start the truck.
  7. Sep 2, 2018 at 9:18 AM
    Bishop84
    Bishop84 Well-Known Member
    We have an installer that uses the defrost button as a un-kill switch to a relay. You have to push the defrost before trying to start the car. It's simple enough yet obscure enough to deter most dickbags.
    Colchicine likes this.
  8. Sep 2, 2018 at 9:19 AM
    License2Ill
    Ian
    I was quoting @Sebz13 not op.
  9. Sep 2, 2018 at 9:22 AM
    Petrol
    Central Va.
    Tacoma
    YEP /\ It doesn't take much. You just have to slow them down enough to make them abandon their intention of stealing the car.
  10. Sep 2, 2018 at 9:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Best I ever saw on simple key and push button starter vehicles
    Chain looped through the steering wheel and around the brake pedal .
    Sure one could mess with removing the steering wheel to get the chain off the brake pedal
    If your needing to steal that bad a Roll back is in your garage
  11. Sep 2, 2018 at 10:05 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I have and use a steering wheel lock, but it takes seconds to cut through a plastic steering wheel with a hack saw. If you live in a major population center then keeping your keys with you just isn't an effective means of vehicle security; people have relatively new and even brand new locked and anti-theft system armed vehicles stolen while parked in their driveway, on the street, and in parking lots all the time.
    Here's that latching relay I was talking about:
    http://www.wolstentech.com/products/latchingrelay/latchingrelay.php
  12. Sep 2, 2018 at 10:51 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Holy shit. This is genius.
    Running Board Man likes this.
  13. Sep 2, 2018 at 12:36 PM
    Petrol
    Central Va.
    Tacoma
    If someone wants to steal a vehicle bad enough, there's not much you can do to stop them.
    However, a little deterrence goes a long way. If you can slow them down just a little bit, chances are very good they will move onto a different target.
    There's also a difference between a car that is just reported stolen and a car that is reported stolen that was actually stolen.
    A drug addict that loans their car to a drug dealer in exchange for drugs and then reports the car as stolen, isn't really a stolen car.
    A car that is repossessed for non-payment of a loan and reported stolen, isn't really a stolen car.
    A car that is abandoned by the owner and reported stolen after being involved in some criminal activity such as a police pursuit or an accident, isn't really a stolen car.
    A car that is towed from private property after being parked without permission and reported stolen, isn't really stolen.
    The VAST majority of cars that are actually stolen had the keys in them.
    Of the ones that are actually stolen that didn't have the keys in them, most of those thefts could have been prevented with some simple device such as a hidden kill switch. An option to a kill switch is some type of mechanical lock on the steering wheel/pedals, a battery disconnect, a fuel line shut off or some other device to prevent it from being easily started or operated.
    Alarms are practically worthless because no one cares if they hear one going off.
    GPS trackers help to recover stolen cars but do nothing to prevent the theft.
  14. Sep 2, 2018 at 12:53 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
  15. Sep 2, 2018 at 4:12 PM
    #35
    Wyoming09
    New Tripoli Pa
    Super Springs
    Most of these vehicles still had the steel in the steering wheels I forget all the plastic these days
    Dalandser likes this.
  16. Sep 2, 2018 at 9:49 PM
    #36
    Petrol
    Central Va.
    Tacoma
    They still have a steel ring under the plastic but it's mild steel and easily cut.
