Anyone has mickey thompson ATZ P3 load range E
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12345, Nov 7, 2016.
  1. Nov 7, 2016 at 9:01 PM
    12345 [OP] 1st time taco owner
    Wahiawa 96786
    2013 v6 2wd
    K&n intake/borla
    Minds is real stiff. want to know what psi to run.
    Thanks
  2. Nov 7, 2016 at 9:24 PM
    Pigpen
    Dan
    Northwest Montana
    I run 45 psi on road in the summer on my load E tires - Toyo M55
    In winter, I run 35 psi
    Off road I run 25
    Deep snow I run 12
  3. Nov 7, 2016 at 9:33 PM
    TheNatural
    TheNatural Well-Known Member
    Fort Nelson, BC
    '12 DCLB
    Lots of bolt on chrome stuff
    I have those tires. I run them at 38psi on the street, but drop to 27 for any crappy dirt roads for a much smoother ride . Wheeling I start at 27 (that's what my quick tire deflators are set at) and drop depending on what kind of trail... often end up at 18. Your experience may vary depending on preference and truck weight, etc, but that should give you a starting point
    12345[OP] likes this.
  4. Nov 8, 2016 at 1:08 PM
    Wahiawa 96786
    2013 v6 2wd
    K&n intake/borla
    Called the mickey thompson shop they told me to run 40 psi front and back.
    I think it was up at 45 psi there new about 3 weeks out the shop.
  5. Nov 8, 2016 at 1:15 PM
    TheNatural
    Fort Nelson, BC
    '12 DCLB
    40 would be reasonable for the street. They will ride very harsh and not perform well offroad unless you let some air out though.
    12345[QUOTED][OP] likes this.
