Anyone have a rattle in their door?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNumber6, Aug 26, 2015.
  1. Aug 26, 2015 at 1:54 PM
    TacoNumber6
    TacoNumber6 [OP] 6 TIMES A CHARM
    I have a '15 DC TRD off road and recently i have noticed whenever i hit bumps or potholes in the road hard enough i hear a slight rattle on the passenger side. It doesn't happen every single time. its really weird. My brother in law recently got into my truck and when he shut the door he shut it kinda hard (the window was rolled down when he shut it) Could this be the culprit? Any suggestions would be appreciated
  2. Aug 26, 2015 at 8:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't know if this will help you but my Access Cab Doors had horrible rattles on my 2015, the upper strikers and latches were bouncing off each other over bumps and the tires were overinflated which made things worse.
  3. Aug 27, 2015 at 6:22 AM
    TacoNumber6
    interesting.....anyone else?
  4. Aug 27, 2015 at 6:39 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's in the window switches.
    I pulled mine out and wrapped electrical tape around the part that protrudes into the opening, and it shut it right up.
    Do both sides. It'll only take 15 minutes.
    There's a thread on it somewhere.
  5. Aug 27, 2015 at 6:43 AM
    rottenpixies
    rottenpixies Well-Known Member
    New York
    2015 DCLB 4X4
    Having rattle on drivers side. Bought silicone to try KBS fix, but I'm wondering if I should have dealership look at it so I don't mess up any warranty or something if that doesn't fix it. Just bought it week ago.
  6. Aug 27, 2015 at 6:51 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    My window rattles when half way down. I also had the switch rattle which I fixed.
  7. Aug 27, 2015 at 6:54 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Just do it. You won't mess anything up in regards to warranty (nothing important anyway), and the dealer's gang of window lickers won't have a clue what to do.
  8. Aug 27, 2015 at 7:10 AM
    TacoNumber6
    so you dont think its anything inside the actual door? last time i took it in to have the left driver side panel replaced under warranty, it took them 3 tries to re-install the damn door panel correctly.
  9. Aug 27, 2015 at 7:12 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I know it sounds stupid, but make sure it's not your seat belt bumping the plastic. Alot of times when my wife or daughter get out on the passenger side (front or back) they leave the seat belt twisted so it rubs the plastic. Drives me crazy.
  10. Aug 27, 2015 at 7:13 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It's most likely the window switch.
  11. Aug 27, 2015 at 7:15 AM
    TacoNumber6
    it almost sounds like a glass rattle, but when i sit in the passenger side and shut the door, i hear nothing, only when driving sometimes and hitting a rough spot in the road it will make a rattle
  12. Aug 27, 2015 at 7:15 AM
    TacoNumber6
    i checked the seat belt and everything, adjusted it up and down to make sure it wasn't that. weird
  13. Aug 27, 2015 at 8:40 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    i had a rattle/squeak when my window was down. had the panel taken off. most of the bolts holding the motor had fallen off. my mechanic found the parts at the bottom of the door sill, had to reinstall and tighten all the bolts. it was just about ready to drop the glass into the door.
  14. Aug 27, 2015 at 12:02 PM
    TacoNumber6
    how in the hell did the bolts come out? insane !!!
  15. Aug 27, 2015 at 12:19 PM
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
    I think my driver side window is about to fall off too! I better open it up and tighten everything up before it does.
  16. Aug 27, 2015 at 1:04 PM
    TacoNumber6
  17. Aug 28, 2015 at 6:00 AM
    nobescare
    Mark
    2019 Highlander SE
    its going on 10 years old. lotsa use i guess. i was hanging on by one nut/bolt. i was just about to do a 700 km drive. lucky i had it checked. probably would have dropped down in a rainstorm with my luck
  18. Aug 28, 2015 at 7:21 AM
    TacoNumber6
    i thought it was newer.....does anyone think that maybe the passenger seat could be the culprit??
  19. Aug 28, 2015 at 11:38 PM
    Dustflap
    Dustflap Well-Known Member
    My 2015 started doing the same thing at around 800 miles. Have you had any luck getting it fixed?
  20. Aug 29, 2015 at 12:08 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I got an annoying rattle in my passenger seat.....My fault though....I married her ;)
