Anyone have a sunroof?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dark Knight, Jul 25, 2008.
  1. Feb 4, 2012 at 11:27 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I very much like the installation on my "new to me" 05 DC. Power moon roof.
    same as gavonder
    No leaks at all, survives the Cdn winter (well at least an Okanagan winter, here in southern BC)
    Here are the details:
    http://webastoshowroom.com/
    http://webastoshowroom.com/pdf/holla...0_brochure.pdf
    not a double unit, sits covers the front seats, but fully electric, and recedes into headliner. This unit looks like it was installed at the factory, the aftermarket install is that good. simple electric controls. Will enjoy it this summer! makes the cab feel even roomier.
