Anyone have a weird loose vibrating sound from passenger seat? door area?
Discussion in 'Technical Chat' started by 2ManyTacos75, Jun 13, 2016.
  1. Jun 13, 2016 at 7:57 AM
    2ManyTacos75
    2ManyTacos75 [OP] Well-Known Member
    Ok, new member here, have a crazy issue, wanted to see if anyone has this problem. I have a 2015 TRD DC off road and once in a while, whenever i hit the right pothole or uneven pavement, or anything that makes the truck shake, i hear this random sound coming from the front passenger seat area, can't tell if it's from the seat or the door or what the heck it is. it doesn't do it everything, you just have to hit the uneven surface or pothole just right, almost sounds like a window vibration. But the sound seems to originate from the lower area behind the seat, hence the reason i suspect the seat. I inspected the seat, moved it up and down, shut the doors while sitting inside, and cannot replicate the sound to save my life (reason why i havent taken it to the dealer) Am i going crazy? what the hell could be making that. When it happens, its real quick and lasts maybe 2 seconds. Just irritating since truck is a 2015, I expect this from Chrysler, not Toyota.
  2. Jun 13, 2016 at 8:00 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Look under the seat itself for possible wire to heated seat rattling or shifting? Where is your jack stowed?
  3. Jun 13, 2016 at 8:01 AM
    2ManyTacos75
    i dont have a heated seat, i looked under the seat and everything looks intact, that's whats weird about it
  4. Jun 13, 2016 at 8:03 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    it's not the seat belt tab on the passenger side hitting the door panel is it? Sometimes mine will rattle if it's out of the little clip that holds it snug...
  5. Jun 13, 2016 at 8:04 AM
    2ManyTacos75
    checked that too, nope :anonymous:
  6. Jun 13, 2016 at 8:04 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Also, look under the floor from the outside. there might be something striking the floor, like an exhaust hanger...
  7. Jun 13, 2016 at 8:28 AM
    2ManyTacos75
    HMM....interesting....will check it out
  8. Jun 13, 2016 at 9:28 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    If you have pretty well eliminated anything inside causing the sound, that kinda narrows it down to something outside!
  9. Jun 13, 2016 at 10:47 AM
    2ManyTacos75
    Could be worse, could be stuck with a Chrysler or Jeep product...lol
  10. Jun 13, 2016 at 10:58 AM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Well, if you can't Dodge it, Ram it!
  11. Jun 13, 2016 at 11:16 AM
    2ManyTacos75
  12. Jun 13, 2016 at 5:34 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Have a passenger try to narrow down the source. Maybe he/she can feel it.
  13. Jun 22, 2016 at 11:47 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    Yea I hear that now and than, and don't have the slightest idea what the heck it is. I just say I have a truck and it makes some noises. Oh well. Let me know if you figure it out. Sorry but thanks
  14. Jun 25, 2016 at 7:29 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Check the door hardware. I was hearing road noise from my door like the door wasn't closed fully. Turned out that the striker was loose. Tightened it up and door was tight as a drum again. It only took 12 years to loosen...
  15. Jun 25, 2016 at 7:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Remove the seat and see if the noise stops.
  16. Jun 29, 2016 at 12:54 PM
    2ManyTacos75
    whats a striker?
  17. Jul 3, 2016 at 10:37 AM
    Clearwater Bill
    Billy
    Largo Florida
  18. Jul 4, 2016 at 6:01 PM
    Tacoski
    Tacoski Member
    Bloomington, Illinois
    2016 Tacoma TRD Sport
    none
    I too have a weird rattling noise that sometimes comes from the passenger sie of my 16 OR 4x4. It sounds to me like its the linkages inside of the door that come from the handle to the door latch. But when I slam the door its quiet only when I go over small bumps in the road. I looked at the 2 black little rubber bumpers that are on the door, and they are loose so I grabbed some Yamabond and removed the plugs and put a little on the backside and where it goes through the door. It seems to have helped. I also noticed that the seatbelt cover on the bottom of the door is really loose fitting, so I took some Yamabond and filled the areas where the clip is attached to the metal loop. I wonder if the resonance of the clip rattling is what i am hearing? I really dont notice the rattle sound when I have a front seat passenger, hence the seatbelt changing position on the door and putting some tension on the bottom plastic cover. I will report later if that is what takes care of the problem.
  19. Jul 4, 2016 at 6:13 PM
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
    Hey ... buckle the front passenger seatbelt then ride around ( over some bumps ) and see if you still hear the sound. I had a rattling sound id hear only when going over a bump and it sounded like the door ... finally i realized i wouldnt hear sound when my wife was in passenger seat with seatbelt on ... it was then i discovered it was the buckle hitting up against that pad thing next to passenger seat when belt is not being used
    ... could be what you're hearing
  20. Jul 4, 2016 at 6:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Same here OP!! Same thing happens on my '15. It's pretty rare (a few times a month) but I have yet to figure out what it is. I just stopped caring at this point.
    2ManyTacos75[OP] likes this.
