anyone have alignment issues with the 5100's?
Discussion in 'Suspension' started by jermoids, Oct 2, 2012.
  1. Oct 2, 2012 at 5:31 PM
    jermoids
    jermoids [OP] Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    before i go ahead with this, i was wondering if anyone has had any issues with re-alignment after installing the bilstein 5100's @ 1.75"?
    on 2012 models to be more specific.
    thanks.
  2. Oct 2, 2012 at 5:38 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    mine is not a 2012, but it is a 2nd gen, no issues getting it aligned
  3. Oct 2, 2012 at 7:50 PM
    cleveland48
    cleveland48 Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    Having trouble with mine set at 1.75 whic I shouldn't different shop is doing it tm first guy just give me a hot pass. Then Toyota dealer said they couldn't align it so hopefully next shop can getting pissed cause pretty sure dealer just didn't wanna do it and other guy just didn't give a damn maybe 3rd time is a charm
  4. Oct 2, 2012 at 8:01 PM
    jermoids
    Jeremy
    2021 TRD Sport
    that sucks, good luck, i was hoping to NOT have any replies like this :confused:
  5. Oct 2, 2012 at 8:08 PM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    Mine are at 2.5, and the alignment was done by Toyota of mcdonough
    If that helps any
  6. Oct 2, 2012 at 8:25 PM
    cleveland48
    Andrew
    2012 TRD Off Road
    There shouldn't be any problems I'm sure my problem is lazy or piss poor mechanics ill let u know tm evening if this shop fixes it for me was pretty pissed that Toyota said they didn't have the equipment
  7. Oct 2, 2012 at 8:28 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Dealer had to do a lot of adjustment on my '09 set at 0.85, said it was close but they got it. The 1.75 setting may have it right on the edge. Did you change tires and wheels as well?
  8. Oct 2, 2012 at 8:36 PM
    jermoids
    Jeremy
    2021 TRD Sport
    im going to put 265/70/17 duratracs on the stock wheels, i have been told by others that have them that they'll fit with everything stock. i just wanted to level the front a bit with the 5100's, but might not if it's going to be a problem getting it properly aligned.
  9. Oct 2, 2012 at 8:51 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    That's close enough to the stock tire size and shouldn't be a problem. Get it aligned with the wheels and tires you are going to use on it, though. If you haven't changed tire sizes or wheels yet, they *should* be able to align it even at 1.75. But, it may be right on or just past the edge and they may only be able to get it close. Some people are OK with it being close, others want it in spec, your call in the end. Going from 65 to 70 shouldn't make a big difference.
  10. Oct 2, 2012 at 9:40 PM
    Markallyn86
    Markallyn86 I like tacos and burritos
    Mark
    Houston, TX /Heights
    Trd sport 4x4 2012
    OME kit 885, LR UCA, XD addict 17's, 265 70 Nitto, ultra gauge, weather tech
    Had mine done at toyota after i installed 5100's at 1.75 went fine, no problems. Rides better than stock. cost around 100 after tax.
    Dooooo itt.
