Anyone Have an ECU?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Raspberry, Jan 17, 2024.
  1. Jan 17, 2024 at 12:55 PM
    Raspberry
    Raspberry [OP] Well-Known Member
    Andrew
    1995 Tacoma 4x4
    Full restoration
    I need an ECU for a 95 Tacoma, number 89661-04050
    Anyone have one that I can plug in/don’t need to program?
    I am located in Staunton VA
  2. Jan 17, 2024 at 1:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    @Ozark_RegCab don't you have the one you pulled that turned out to be fine
  3. Jan 17, 2024 at 2:19 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I have the old one I pulled that had a fried circuit and wasn’t communicating with any scan tools. It could probably be rebuilt for cheaper than a used one though. It’s for an R150/V6 btw; I’m not sure if that’s the same as OP’s truck or not.
  4. Jan 17, 2024 at 4:22 PM
    RandyLahey
    RandyLahey Well-Known Member
    Southwest PA
    2013 sport 6mt
    I think I have one out of a 95 4 cylinder 5 speed, I’ll look for it in the garage tomorrow if that’s the one you need
  5. Jan 17, 2024 at 5:25 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    So I haven’t got around to putting an update on that yet, sorry.
    Basically I thought it was fine and I pinpointed the issue to the Circuit Opening Relay, so I replaced that. It seemed to fix the issue but then it occasionally would crank up and immediately die. Giving it gas would save it and then it would idle and run perfectly. So I figure it’s either the ECU or the wiring in between that and the COR. CEL is also back. To be safe, I wired in a bypass switch to the COR so I won’t get stuck anywhere, and I’ve been driving it.
    Whether the ECU is the problem or not, I figure it’s just good to have an extra, especially since I did open it up and found 2 capacitors that looked a little suspicious.
  6. Jan 17, 2024 at 5:26 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    No, mines a 4cyl 3rz. Pretty sure yours wouldn’t work. Thanks though
    Ozark_RegCab[QUOTED] likes this.
  7. Jan 17, 2024 at 5:27 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    Thanks, if you don’t mind looking at the number to see if it works
  8. Jan 17, 2024 at 5:34 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    I’ll also note, there is a reconditioned one on EBay for pretty cheap, I’m keeping my eye on it. Not sure how exactly trustworthy a reconditioned one would be though…
  9. Jan 18, 2024 at 1:03 PM
    RandyLahey
    Southwest PA
    2013 sport 6mt
    I wasn't able to find that ECU yet, I know its still here but in the meantime I wouldn't be scared of an ebay ECU, these don't really go bad very often and I imagine reconditioned means they wiped it off and posted it for sale
    Speedytech7 likes this.
  10. Jan 18, 2024 at 1:37 PM
    Raspberry
    Andrew
    1995 Tacoma 4x4
    Full restoration
    Thanks, I think I might go ahead and pull the trigger on the EBay one, I don’t wanna wait too long and have it sell
