Anyone have an idea what this noise could be?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonythetaco, May 19, 2023.
  1. May 19, 2023 at 5:21 PM
    tonythetaco
    tonythetaco [OP] New Member
    2016 TRD Off Road Tacoma
    none yet...about to do a 3" lift and level
    At first I thought there might be something hitting the fan…but that is all clear. The pitch changes with the RPMs and I noticed that the dash lights flickered a time or two during the last drive.
    anyone else experienced anything like this?
    2016 TRD Off Road with about 100k
  2. May 19, 2023 at 5:44 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW….Is the belt loose?
    tonythetaco[OP] likes this.
  3. May 19, 2023 at 6:05 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Belt tensioner, idler pulley, or alternator. Never seen an engine bay as dirty as that. Not trying to be an ass. But with that amount of dirt, sand, and grime, surprisingly more hasn't failed.
    Otterstuff likes this.
  4. May 20, 2023 at 3:07 AM
    tonythetaco
    yeah. Haven’t had a chance to clean the engine bay since my last excursion a few days ago. I’ll look further into these three options and report back.
  5. May 20, 2023 at 3:33 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You need to get out and use your truck more. That engine bay is only a couple good mud puddles worth of splashes and some dusty roads away from clean. I don’t think mine ever looked cleaner than that after it left the dealership lot.
    riggityj likes this.
  6. May 20, 2023 at 3:41 AM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Start by unplugging the fan. If it doesn't go away, you know it's not the fan so then you can try removing the belt to see if it goes away. If it's a pulley then just start spinning them by hand one by one until you find something that's rattling like that. If you still have no luck after the fan and belt are removed and the noise continues, might have to get underneath.
    riggityj, tonythetaco[OP] and Rusty66 like this.
  7. May 20, 2023 at 3:53 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Sounds like a pulley or drive belt issue. Pull the belt off (like he said^^^) and see if it disappears. I've been seeing reports of the lower idler pulley bearing failure on the V6.
  8. May 20, 2023 at 4:08 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Yeah I'd want to eliminate that noise too!
  9. May 20, 2023 at 4:22 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    My Dad taught me the golden rule; when in doubt, start with cheap and/or easy and go from there!
    After giving that engine bay a good bath, I would put a new belt on it (especially if that's the original belt). We had someone post here not long ago with a God awful sound worse than yours, and a new belt solved it.
    thomasburk and tonythetaco[OP] like this.
  10. May 20, 2023 at 4:36 AM
    tonythetaco
    Noted! I sure hope it’s that easy. I’ll report back once I have time to dig in and sort it out.
    thomasburk likes this.
  11. May 20, 2023 at 6:31 AM
    Buck Henry
    Well like I said, if that is the original belt you probably should swap it out regardless with that amount of miles on it. And you might get lucky and this is all that is needed to make your engine sing like new again. But if the belt does not do the trick, then start looking at your pullies as a possible culprit.
    PS: Friend of Crows gave a decent trouble shooting approach above that you might want to consider using.
