anyone have an issue with removing wheel bearing? I am.... help needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Koolbreeze7, May 20, 2019.
  1. May 20, 2019 at 6:04 PM
    Koolbreeze7
    Koolbreeze7 [OP] GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    Purchased Jerseybuilt hub 2 years ago works great. Easy removal of bad original Toyota hub easy replacement of new JBHub on passenger side. Several months later Truck had a small sideswipe Driver's side collision and insurance replaces , wheel. tire, shock, coil spring, axle and wheel bearing. Other guys insurance paid so I thought nothing of it. Fast forward DS caliper stuck and I began GX460/470 big brake upgrade. I start on PS and remove / replace JBhub to do upgrade no problems. Now I cannot remove DS hub. loosened bolts hammered on it no movement. Is this thing pressed on? Am I spinning my wheels here and DO I need to remove the front suspension and have this thing "pressed Off" mechanically? Its almost like there is not enough room to loosen the back bolts to the spindle/ my MAC tools long 17 mm slim box end wrench fit on PS but didnt on DS ( too little space between hub). Anyone run into this before? any suggestions? I am ready to cut off the bolts and hammer the shit out of the DS hub.
  2. May 20, 2019 at 6:09 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    My go-to was always an air chisel with a u-joint bit, hammer on a bolt ear and get it to rotate. Just need to break the corrosion bond between the bearing shell and the knuckle.
    Gunshot-6A likes this.
  3. May 20, 2019 at 6:16 PM
    Koolbreeze7
    Jon
    Jersey
    Love your SD profile pic, seen them a ton of times.....Thank you I didnt think about an air chisel. I mostly have brute force tools. I was caught up in the fact that the wrench didnt fit where it had on the Passenger side and what kind of bullshit the shop could have done to make it so difficult as compared to the older PS hub
  4. May 20, 2019 at 7:35 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    The only thing I do is use the bolt heads retaining the hub to help out. So position the hub so the back of a wheel stud is over the top of one of the bolts and back that bolt out against the back of the wheel stud and get what movement you can. Then move to another one at the furthest corner and get what travel you can by the time you've basically got all 4 bolts backed out it should be loose enough to get out. You can also use a larger puller to assist in pushing the axle out of the hub after you start to get some movement.
  5. May 21, 2019 at 4:34 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    ^^° this...
  6. May 21, 2019 at 3:13 PM
    Koolbreeze7
    Jon
    Jersey
    Well, after 50 blows with the sledge hammer and pry bar got the DS hub off. continued prepping DS to finish lx460 brake upgrade. Of course hard brake line seized in caliper too. Get set to see if this wheel bearing will go back on the DS axle spline and it gets half way and jams up,..... literally pushing the axle and boot back and out and inch. Completely opposite of my experience with the PS bearing and brake job. I am now wondering if the axle is wrong, the bearing is wrong or they are damaged or were never replaced by ins co. I shouldnt have to hammer the bearing on something is out of whack. Ordering a new Jbuilt hub for starters
  7. May 21, 2019 at 3:17 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Pb blaster and keep working your way around tapping and working with a pry bar. Sometimes they are a bitch. Just gotta keep at it. Or soak it in pb blaster, then take a beer break
  8. May 21, 2019 at 3:21 PM
    fatfurious2
    David
    Ashburn, VA
    Edit: i read it too fast/wrong. How hard was it to get the axle out of the splines on the hub? Should have just came out with a little grunt force, but no tools.
    You might have to do a shake-weight action to get it to fully seat. Then when you tighten down the bolts and put the axle nut on, it should seat the hub-axle seal
  9. May 21, 2019 at 3:21 PM
    Koolbreeze7
    Jon
    Jersey
    got it off it doesnt go back on . gets hung up on the axle
  10. May 21, 2019 at 3:22 PM
    fatfurious2
    David
    Ashburn, VA
    Can you rotate it, and try a different side? I know they're all the same, but maybe you didn't have it lined up
  11. May 21, 2019 at 3:23 PM
    Koolbreeze7
    Jon
    Jersey
    Thank you. just seems odd I had zero problem with the Passenger side getting it off and back on. PS was a jerseybuilt bearing that I replaced last year
  12. May 21, 2019 at 3:26 PM
    Koolbreeze7
    Jon
    Jersey
    I will try that again, rotating it. It literally pushed the boot out. I was going to force it and just bolt it up and hope that it drew everything together but it just feels off....This side was repaired by some asshole through Insurance after I got side swiped. figures that is the side that is giving me grief
  13. May 23, 2019 at 9:39 AM
    Koolbreeze7
    Jon
    Jersey
    So I met Kevin from Jerseybuilt hubs last night to get a new bearing. Met me at 9 at a mutual Wawa store. put new bearing on DS this morning. slid on without a hitch. trying to finish up LX460 big brake upgrade in between thunderstorms that are rolling thorough my area. The perils of a driveway mechanic. ( If my Buick Turbo T wasnt sleeping in the garage I could be done already)
  14. May 23, 2019 at 11:55 AM
    08RC
    08RC Well-Known Member
    Which wawa did ya meet him at out of curiosity as they seem to be a very useful landmark to use here in Jersey
  15. May 23, 2019 at 1:29 PM
    Koolbreeze7
    Jon
    Jersey
    Rt 70 and 72
  16. May 23, 2019 at 3:47 PM
    08RC
    4 mile Cool. Im down between Tuckerton and Manahawkin
