Anyone have any clothes dryer knowledge?
Discussion in 'Off-Topic Discussion' started by nivek5sfe, Jan 27, 2019.
  1. Jan 27, 2019 at 2:01 PM
    nivek5sfe
    nivek5sfe [OP] Well-Known Member
    Marietta, GA
    05 DCLB 4x4
    Our dryer has stopped drying correctly. After running a cycle the clothes are barely dry and takes maybe 3 hour long cycles to dry a load. Its blowing so it's not the blower. I checked the exhaust line and there's no clog. Its turning so it's not the belt or motor. I've changed the heating element and thermostat. What else am I missing that could be the problem?
  2. Jan 27, 2019 at 2:56 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Are you getting 220 volts to the back of the dryer where the cord hooks up? Is tree an overtime cut-out switch? Is the out flow of air warm at all? Over temperature switch. Damn spell check.
  3. Jan 27, 2019 at 3:02 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    What he said, unless it’s a gas dryer. Lol.
  4. Jan 27, 2019 at 3:04 PM
    megillet
    Mark
    Atlanta, GA
    Also, if it’s a newer dryer (like 10 years), it may have a repair manual inside for “technician use only”. Both my washer and dryer do. They describe how to retrieve error codes and troubleshoot. Might be worth taking the back and top off to see.
  5. Jan 27, 2019 at 3:07 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Make sure the Exhaust vent is not clogged up when it does happen it hits over temp fast and ceases to correctly dry. Simple way to check is turn it on and go to the exit end and see if you have lots of very warm air coming out. If lots of air not warm check voltages at the 220 because some dryers will run motor and fan OK on the single phase but heat element requires both phases of the 220 to heat well
  6. Jan 27, 2019 at 3:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I gotchu fam. Do you own a multimeter and able to check continuity?
    shakerhood likes this.
  7. Jan 27, 2019 at 3:08 PM
    81shark
    81shark Well-Known Member
    Electic. Or gas?
    Temp sensor.. Flame ignitor...
  8. Jan 27, 2019 at 3:10 PM
    T4RFTMFW
    It isn’t gas if he said he changed a heating element.
    Also, there’s 4 sensors and a timer/control board that all come into play as well.
  9. Jan 27, 2019 at 3:12 PM
    nivek5sfe
    Marietta, GA
    05 DCLB 4x4
    I checked and I have alot of warm air coming out of the exhaust. Also checked the exhaust line to be sure and there's no clogs. It seems to be heating since exhaust is hot and the clothes get hot. I'm stumped
  10. Jan 27, 2019 at 3:14 PM
    megillet
    Mark
    Atlanta, GA
    Is your washer spin drying them correctly? Checking the obvious that you aren’t loading soaking wet clothes into a dryer. My wife did that once and asked me why it took so long to dry....
  11. Jan 27, 2019 at 3:16 PM
    nivek5sfe
    Marietta, GA
    05 DCLB 4x4
    I opened it to replace the element and thermostat and didn't see one. I doubt it had one, it's a pretty cheap dryer and we've had it for about 6 years
  12. Jan 27, 2019 at 3:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  13. Jan 27, 2019 at 3:17 PM
    nivek5sfe
    Marietta, GA
    05 DCLB 4x4
    Had this issue in the past so it was one of the first things i checked. Its spinning fine from what i can tell, the clothes are as damp as they usualy are.
  14. Jan 27, 2019 at 3:18 PM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    Very good point about the washer not spinning the water out of them had that problem once.
  15. Jan 27, 2019 at 3:19 PM
    nivek5sfe
    Marietta, GA
    05 DCLB 4x4
    Plan on checking this tomorrow. The volts that is.
  16. Jan 27, 2019 at 3:20 PM
    T4RFTMFW
    Seems like he wants to bounce around with replies and ignore actual help. :popcorn:
    shakerhood, Crodell6 and Sperrunner like this.
  17. Jan 27, 2019 at 3:20 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Did you blow the thermal breaker in the back? That would cause it to run but not heat
  18. Jan 27, 2019 at 3:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Then ill take my appliance technician ass out of here
  19. Jan 27, 2019 at 3:23 PM
    Wsteven
    2018 Tacoma TRD Pro
    Working on them
    Ha! I have used that website many times to fix different stuff in the home and it is pretty darn good.
  20. Jan 27, 2019 at 3:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    His dryer runs but doesn’t heat
