Anyone have any experience with Muth Heated Signal mirrors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaBuzz, Apr 24, 2010.
  1. Apr 24, 2010 at 1:48 PM
    TacomaBuzz
    TacomaBuzz [OP] Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I was checking out the Muth Signal mirrors and i noticed you can order them heated as well for the 05+ tacoma. Has anyone installed them?? If so do they heat good?
  2. Apr 24, 2010 at 3:24 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I used heated mirrors for a Siena. No signals but the heat works great. Plus they were less then $80. I also used an oem switch from a highlander so that everything looks factory.
    Shawn
  3. Apr 24, 2010 at 3:35 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  4. Apr 24, 2010 at 8:59 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    i have it install on my 09 tacoma, but the instruction for the wire termination color code is wrong, i have the right color code, if u need it pm me.
    also it is a great extra to add on the ride. i love it.
  5. Apr 24, 2010 at 9:34 PM
    TacomaBuzz
    CT
    Did you use a highlander OEM switch or the muth switch?
  6. Apr 24, 2010 at 9:39 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I ordered them, not installed yet, but they are a direct fit.
  7. Apr 25, 2010 at 6:33 AM
    wing103
    Boston
    I use the Muth Switch.
  8. Apr 25, 2010 at 6:45 AM
    george3
    new jersey
    tacoma
  9. Apr 25, 2010 at 6:54 AM
    shawnd2
    Shawn
    I bought a oznium switch, and it looks good. I just liked the oem switch better as the heated mirror symbol dims with the rest of the dash lights as well as shuts off after 15 minutes.
    It was expensive (around $50 I think) plus I screwed one up and had to buy another! But I do like that it looks like the truck came with it stock.
    Shawn
  10. Apr 25, 2010 at 7:46 AM
    george3
    new jersey
    tacoma
    I get confused with so many posts so I may be wrong but I seem to remember the OEM needed a relay and was around $70 but I don't feel like reading the old post thru 20 pages to confirm it.
  11. Apr 25, 2010 at 12:08 PM
    wing103
    Boston
    Can you post the link for that swith that u talk about
  12. Apr 25, 2010 at 1:42 PM
    shawnd2
    Shawn
    It's in the 3rd post.
    When you go to that link check out post 93 for pics
    Shawn
  13. Apr 25, 2010 at 1:51 PM
    george3
    new jersey
    tacoma
  14. Apr 25, 2010 at 2:02 PM
    shawnd2
    Shawn
  15. Apr 25, 2010 at 2:17 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    Take some pics of this install, I would like tom see what these look like when done.
    Thanks
  16. Apr 25, 2010 at 6:41 PM
    wing103
    Boston
    I mean the link for the switch that you talk about ( will auto shut off after 15 minutes. Can you post the link where did you get that switch? Thanks for the advice.
  17. Apr 25, 2010 at 7:07 PM
    shawnd2
    Shawn
    I got the switch from my Toyota dealer. As I mentioned above, go to the link in George3 post (#3) and once you are in that check post # 93. It shows the switch and the Toyota Part # is 84871-48030.
    Shawn
  18. Apr 26, 2010 at 4:16 PM
    wing103
    Boston
    Thanks. Shawn.............
