Anyone have any experience with the Marlin Short Throw Shifter?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotadude520, Apr 26, 2022.
  1. May 23, 2022 at 9:10 PM
    #41
    1997tacomav6
    Denver
    Did you use foam plumbing pipe insulation that you can get at Home Depot that wraps around it? Or noise deadening material.
    homegrown_xt[QUOTED] likes this.
  2. May 23, 2022 at 10:02 PM
    #42
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I used some rubber fuel line I had in my tool box and cut it down lengthwise on one side and put it around the bent shaft part
    and zip tied it real tight and up against the black part of the shifter.
    Did you notice more noise after you put the Marlin in? Maybe after cutting it down the noise has less to travel.
    1997tacomav6[QUOTED] likes this.
  3. May 24, 2022 at 5:15 AM
    #43
    1997tacomav6
    Denver
    I definitely do notice that lower growing bearings noise. I can live with it but
    if it’s an easy fix for 20.00 then I will try to see if it works.
    I’m loving this new marlin short shifter ALOT.
    I’m going to try the foam pipe insulation and then wrap the pipe insulation and seams with sound deadening tape this weekend
  4. May 24, 2022 at 11:16 AM
    #44
    homegrown_xt
    Sonoma County
    I could be free if you have some fuel hose and some zip ties in your tool box. ;-)
    Good luck with the foam tubing and sound deadening tape, let me know how it goes.
    The shifter is awesome, isn't it? I love it more now that it is quieter. I had an LCE short shifter kit for a couple of months but didn't like the adapter that you had to put on the ball of the shifter, the Marlin feels more solid since it is a machined unit, no adapters.
  5. May 24, 2022 at 8:56 PM
    #45
    1997tacomav6
    Denver
    It’s amazing in how it transforms the transmission from a sloppy shifter into a precise shifting unit. It took me along time to decide on this complete unit.
    I have not had one gear grind or one missed shift like I used to.
    will update the foam and deadening tape soon
  6. May 24, 2022 at 9:09 PM
    #46
    homegrown_xt
    Sonoma County
    I barked the tires a couple of times when I first got it until I got the shifting timing right with the clutch. Did you switch to MT-90 in the tranny?
  7. May 25, 2022 at 9:52 PM
    #47
    1997tacomav6
    Denver
    Yes, been running MT-90 for years,
    I went to Home Depot and got a 1/2” foam insulation section in the plumbing section for 1.89 and zip tied it on and then duct taped the foam insulation to seal everything up.
    It definitely quieted down the transmission noise a bunch,
    I unscrewed the top part of the stick shift and fitted the insulation section down over the lowe section
  8. May 25, 2022 at 10:19 PM
    #48
    homegrown_xt
    Sonoma County
    Nice job with the foam insulation, glad it worked out for you!
    I noticed there was less noise right away, even with the stereo turned up, I could hear a growling bearing noise. Not anymore. The tranny whine is still there but that has been there for over 20 years.
    The Marlin short shifter is a mod I don't think anyone will regret.
  9. May 26, 2022 at 2:50 AM
    #49
    1997tacomav6
    Denver
    X2
  10. Jun 15, 2022 at 7:26 AM
    #50
    cynicalrider
    cynicalrider #NFG
    Jersey
    Was researching new shift boots when I got here and now I want to spend $360 on a part I didn't even know I wanted/needed. I wasn't sure how this compared to the URD kit.
    yotadude520[OP] and manapiko like this.
  11. Jun 15, 2022 at 7:57 AM
    #51
    manapiko
    manapiko Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Same! I dont need a short throw at all, but now I want one.
  12. Jun 15, 2022 at 8:47 AM
    #52
    homegrown_xt
    Sonoma County
    I believe the URD kit is the same as the LCE kit, a spacer block for the shifter housing and an adapter to lengthen where the shifter end goes into the transmission. I still have one of these kits sitting in my garage. I only used it for a couple of months before I changed it. I ended up having the shifter adapter tack welded to the shifter because I did not trust the little set screws staying in place and backing out.
    I think the Marlin piece is a better constructed unit.
    Madjik_Man likes this.
  13. Jun 15, 2022 at 9:11 AM
    #53
    yotadude520
    yotadude520 [OP] Well-Known Member
    Will
    The Dirty T
    1986 Toyota Land Cruiser
    OME Lift - FJ62 Axles - 33x10.50 BFGs
    I totally recommend it - It is singlehandedly one of the best mods I've ever done on my truck, especially after it was shortened.
  14. Jun 15, 2022 at 9:18 AM
    #54
    Madjik_Man
    Colorado Front Range
    That is/would be my only complaint about short shifter kits.
    I don’t like how tall the shifter becomes.
    Keep me/us posted about machine it down and adding the threads. I was about to go full moron and cut my shifter then rethread it with a tap/die.
    But I haven’t gone there yet.
  15. Jun 15, 2022 at 9:19 AM
    #55
    Madjik_Man
    Time to post up a pic in the “Let’s See Your Shift Knobs” thread.
  16. Jun 15, 2022 at 9:21 AM
    #56
    Madjik_Man
    Ill have to try that next time.
    I think the only time tears were shed was when I was trying to get that f’in collar in.
  17. Jun 15, 2022 at 10:24 AM
    #57
    homegrown_xt
    Sonoma County
    Cut it down, I did it myself and it came out good, of course go slow and have a set of calipers to measure it so you don't sand too much off. Check out post # 37 on this thread. If you don't feel comfortable doing it yourself then definitely take it to a machine shop to have it chopped down.
    Madjik_Man[QUOTED] likes this.
  18. Jun 15, 2022 at 10:50 AM
    #58
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I actually like the extra height. When you move your hand from the steering wheel to the shifter it's right there.
