Anyone have emissions suggestions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08silvertaco, Jul 10, 2024.
  1. Jul 10, 2024 at 3:38 PM
    08silvertaco
    08silvertaco [OP] Member
    2008 tacoma mtn
    Toy tech lift. 31in/ KN Filter/delta flow muff
    Losing 60-80 per tank. Check engine says gross emissions leak.
  2. Jul 10, 2024 at 3:41 PM
    Bishop84
    Bishop84 Well-Known Member
    If the evap purge valve is stuck open you'll get all sorts of issues. If its a standard leak (like a gas cap) its not typically a concern for efficiency or economy, but still has to be addressed. The gas is evaporating, but not enough to cause a massive drop in MPG.
    cybrnook likes this.
  3. Jul 10, 2024 at 3:42 PM
    cybrnook
    cybrnook Well-Known Member
    SE Michigan
    2022 TRD Off-Road Manual Transmission
    I ate a big bowl of cherries earlier and also am having a gross emissions leak.
    Any mods to the truck? (Fuel, engine wise)
  4. Jul 10, 2024 at 3:44 PM
    08silvertaco
    2008 tacoma mtn
    KN cone filter, after market delta flow muffler. Both have been done for years.
    Regarding the evap purge valve not even sure where that is.
  5. Jul 10, 2024 at 3:48 PM
    cybrnook
    SE Michigan
  6. Jul 10, 2024 at 3:54 PM
    08silvertaco
    2008 tacoma mtn
    Mine is a 6/4.0 how would I know if its stuck open.
  7. Jul 10, 2024 at 4:13 PM
    cybrnook
    SE Michigan
  8. Jul 10, 2024 at 4:56 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    What was your code(s)?
  9. Jul 10, 2024 at 5:52 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    If I can interpret this correctly, you are losing 60-80 miles per tank of gas. That's about 4-5 MPG. A lot.
    YOU HAVE A MASSIVE VACUUM LEAK SOMEWHERE.
    If you don't even know what an EVAP purge valve or EVAP system is, I HIGHLY HIGHLY HIGHLY recommend you just take it to an independent shop.
    All Toyota EVAP systems are basically the same and any decent shop will have troubleshooted and repaired dozens, if not hundreds, of these before. Expect to pay 1 hr of labor for diagnostic troubleshooting (standard minimum) and 1 hr for any part(s) replacement. Plus parts.
    The improvement in fuel economy will pay for the repair very quickly.
    nds0000 and kidthatsirish like this.
