Anyone have experience installing HF/VHF/UHF radios in a 2013 Toyota Tacoma Access Cab?
Discussion in 'General Automotive' started by takomaenthusiast, Apr 20, 2016.
  1. Apr 20, 2016 at 5:27 AM
    takomaenthusiast
    takomaenthusiast [OP] Member
    Shannon
    2013 Silver Tacoma Prerunner V6
    Predator Side Steps, K&N drop in filter, Toolbox
    Interested to see if anyone here has had experience installing a HF radio in particular in a 2013 Toyota Tacoma access cab. I already have a VHF/UHF unit installed, but i've heard that i'll need to bond all the body parts together, etc, for a good ground, but wanted to check if anyone knew about the Tacoma's state as it sits from the factory. Are the body parts bonded together already? Are there any significant things I need to consider before taking on this project? I'll be installing a Kenwood TS-480SAT in the truck, hoping I can do it myself, i've already installed a system (which i've taken out to make room for the HF stuff).
    From what I understand there's a 90 amp alternator in there already? I think this would be sufficient enough to run a 100w rig no? Does the Tacoma create any kind of crazy RFI? I have the V6 Prerunner SR5 model. I plan on using plain ole' hamsticks mounted to the rear bed. I ordered the antenna mounts that go in the rail system in the back (which I understand will also need to be grounded well). I'm told that this truck has a composite bed? I thought it was just a bedliner in there! lol
    Any input is appreciated, thanks!
  2. Apr 20, 2016 at 8:32 PM
    CFI AandP
    CFI AandP Well-Known Member
    Cory
    Florida
    '18 BBP DCSB Limted
    Who are you trying to reach with UHF/HF from the Tacoma?
    Joe D likes this.
  3. Apr 21, 2016 at 5:09 AM
    takomaenthusiast
    Shannon
    Hi Cory,
    Thanks for your reply. I'm installing a Kenwood TS-480HX & a Yaesu FTM-400DR in the Tacoma. Was just wondering if there's anything specific I need to be aware of with the Tacoma's (i.e. ignition noise, body parts not grounded, etc). My radio is a 200w radio, so I may need to install dual batteries, just not sure. Truck has a 120amp alternator.
    Trying to contact the world! Installing HF mobile since I have no time for HF @ home :)
    Thanks again,
    S
  4. Apr 21, 2016 at 10:12 AM
    CFI AandP
    Cory
    Florida
    '18 BBP DCSB Limted
    Yeah, I'm not sure how that'll work. My experience with HF has only been with aircraft. I can't imagine the FCC is too excited about someone having a 200w mobile transmitter.
    Reminds me of the Christian Slater movie Pump Up The Volume.
  5. Apr 21, 2016 at 10:45 AM
    takomaenthusiast
    Shannon
    Sorry! Maybe this is a question for an amateur radio forum & not a Tacoma forum! I'll search elsewhere, thanks though.
    Oh, and we're legally authorized to transmit upto 1500 watts btw :) So pump up the volume it is!
  6. Apr 21, 2016 at 12:53 PM
    CFI AandP
    Cory
    Florida
    '18 BBP DCSB Limted
    Good to know, like I said I'm not to familiar with that sort of setup. My only HF experience has been while flying, so I am uninformed on this side.
    Good luck.
