Anyone have experience with JL stealthbox?
Discussion in 'Audio & Video' started by trdsport808, Jan 21, 2011.
  1. Jan 21, 2011 at 7:07 PM
    trdsport808
    trdsport808 [OP] Active Member
    Honolulu
    Mag gray tacoma sport
    I just installed a JL stealthbox with 2-10" Jlw1s in my 2010 double cab tacoma. It is powered by an Alpine MRD-M605 amp.
  2. Jan 23, 2011 at 5:02 AM
    PX213
    PX213 Member
    New Orleans, La
    2008 Tacoma
    I haven't dealt with the Tacoma stealth box, but I have worked with them in an extended cab early 90's Chevy and a 2003 Ram Quad Cab.
    They wanted more boom in the Chevy, so they went to W3's which involved heating up the back wall of the stealth box (plastic older design) with a heat gun and pressing it further back so it was pressed all the way to the floor to clear the W3 magnets and pushing then with a JL 500/1. It was LOUD.
    The Dodge one blew out the surround after a couple of years, and a W3 dropped right into it with no mods. That is running off of a Kicker 700.5.
    That one sounds really good, but too small of a box for that sub to really show what it can do.
    Not sure how a W3 would fit into that enclosure.
  3. Jan 23, 2011 at 5:47 AM
    ratm3245
    ratm3245 Well-Known Member
    SW. Illinois
    2010 Black Sand Pearl 4X4 DC/SB TRD Sport
    TRD Cat-Back, Weathertech Mats, Nfab light bar, PIAA 520 ATP Drivers, PIAA 520 Fogs, Weathertech Vent/Visors, Blendmount Escort Radar Detector, Kenwood DDX516 HU w/Bluetooth, Kenwood Kna-G610 Hideaway Garmin GPS Navigation System, Alpine S-Series in the doors, JL Stealthbox, JL J2 500.1 Amp, Alpine MRP-F300 Amp, Pro Comp 7098 17X8, 265/70R17 Duratracs, UWS Lowpro Tool Box, K&N 63 Series Intake, 50% Tint in front, Bajarack, AllPro Sliders
    I have a Stealthbox in my 2010 pushed by a JL J2 500/1 and I'm very happy with it. I had to tweek the EQ and crossover on my head unit to get it the way I wanted it but once I did it sounds great.
  4. Jan 23, 2011 at 5:19 PM
    Brandon###
    Brandon### Well-Known Member
    Do you have an aftermarket head unit? How are the subs wired?
  5. Jan 24, 2011 at 7:47 AM
    Abe Froman
    Abe Froman The Sausage King of Chicago
    Fayetteville, NC
    2023 SR DCSB 4x4, White
    Once in a while I hear about someone being disappointed with this item, but the vast majority (including me) is very happy. You've got a great amp to push that sub. It should sound fantastic. Check your install. What gauge wire did you use? Check amp gains and all connections. And you did drill through your back wall and bolt it down as the instructions indicate, right? That will make a difference. Does your HU have a sub output level control? I wouldn't think swapping the drivers out would be a good idea. JL's engineers spent a lot of time finding the best use of that space and the enclosure is designed specifically for those W1s. Nothing much deeper will fit anyway. If you don't find anything, you might try taking it to a reputable shop and have them take a look. My full review on this unit is here: http://www.crutchfield.com/s_13694312/JL-Audio-Stealthbox.html?search=tacoma+stealthbox Good luck and let us know how it goes.
  6. Jan 24, 2011 at 7:57 AM
    Abe Froman
    Fayetteville, NC
    I thought I knew, but this is strange: JL's website says this box uses the 4 ohm version of the 10W1v2 drivers - making the total load of the stealthbox 2 ohms. http://mobile.jlaudio.com/products_stealthbox_detail.php?fit_id=1583
    But Crutchfield indicates the 8 ohm version of the same driver is used, making the total load of the stealthbox 4 ohms.
    Perhaps there are 2 versions floating around out there?
    Edit:
    OP, if your stealthbox's impedance is 2 ohms, you're getting 600 watts out of your amp. If it's 4 ohms, you're only getting 400 watts. http://www.crutchfield.com/S-cP0FxRS2Sax/p_500MRDM605/Alpine-MRD-M605.html
  7. Jan 24, 2011 at 8:18 AM
    Abe Froman
    Fayetteville, NC
    For anyone who cares, I just got off the phone with a tech at JL audio. He confirmed that they did indeed use the 8 ohm driver in this stealthbox at one time, but all new ones come with the 4 ohm drivers (total load = 2 ohms). Crutchfield's website is just a little behind on this (called them too and they're updating). The JL tech is researching further, will email me an approximate time when that change was made and I'll post it here, but it's easy enough to test yours yourself with a multimeter to see which one you have.
  8. Jan 24, 2011 at 8:47 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    If everything is correctly done, I would assume your head unit is the culprit.
    do you have the stock headunit? Time to dump that.
    do you have an aftermarket head unit? It's time to see what the preout voltage rating is. If it's around 2V, it's robbing you of a lot of potential.
    My old honda had a single 12" single coil with a 5.5 volt head unit
    I now have a single 10" dual coil with a 2 volt head unit
    It doesn't matter how much I try fiddling with the knobs, I can't get anywhere near my old setup.
  9. Jan 24, 2011 at 1:32 PM
    zeroendless
    zeroendless Well-Known Member
    Dallas, TX
    Stock
    Just installed one last month, powered by JL 900/5 and the entire back wall is deadened.
    Initially, the system lacks mid bass (from the component), that was because i didn't finish doors deadening. Last week, i managed to complete two front doors, and now the entire systems sounds clean and "complete" with the "holes" sealed airtight. No, the Stealthbox won't win you any competition, you won't get the earth shattering, window breaking LOW bass response but i'm more than happy on the outcome. I got a pretty good system, if i turn loudness to 3/4 of the volume, it turns heads.
    What i am saying is... it could be mid bass that you are missing from your bass component, hence the system lacks SQ, it may not be the sub.
  10. Jan 25, 2011 at 11:39 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    I have one with the recommended jl 250/1 amp. It sounds great and it is really loud when i turn it up. I surprise a lot of people when i tell them it's only running at 250.
    Conclusion: JL stealthbox is a bit pricey but fit and finish is perfect, very clean design and it sound great. well worth it IMO, especially if you can find one used and save a few bucks
  11. Dec 3, 2011 at 12:44 PM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    How much cutting is involved, is it a difficult install?
  12. Dec 3, 2011 at 12:53 PM
    JStradaXR
    JStradaXR Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
    Hey I'm going to be replicating rodgers sub box ill let u know
  13. Dec 8, 2011 at 6:41 PM
    striker1021
    striker1021 Active Member
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    RevTek 3" Lift Leer 100XR Cap
    Wow this an old thread...I would have expected the JL Audio Stealthbox to have more threads! Anyways, I'm thinking about getting this and wondering what everyone thinks about it. Also, wondering if anyone has suggestions for a good amp to go with it and if I can use it with the stock system! Because of money I'd like to just get the amp and stealthbox. I do not have the JBL system either. Thanks for the help in advance everyone!
    If anyone has a good self installation guide out there that they want to share I'd definitely appreciate it!
  14. Dec 9, 2011 at 5:23 AM
    XJBaylor
    XJBaylor Well-Known Member
    Keith
    Plano, TX
    06 DCLB TRD Sport 4x4
    King coilovers with remote reservoirs, Deaver 12 leaf pack with 5100's, TRD exhaust, Kenwood 6160, Anthracite Sport Wheels
    I would look for any amp putting out between 300-400w RMS at 2 ohms. In this case a basic mono amp like the Alpine MRP- M500 would run you around $200 and provide plenty of power.
    Also, if you were to go with a custom built box for a single 8 or 10 from Mr. Marv you might be able to afford upgrading your speakers AND running a 4 or 5 channel amp to power your whole system. For what you would be spending on just the Stealthbox you could end up with a completely updated system.
    Just some food for thought.
  15. Dec 9, 2011 at 8:23 AM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    What ever you need Lmk .... I'll get it for u for cheaper. I work for online car stereo
  16. Dec 9, 2011 at 11:21 AM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    JStradaXR - Really appreciate the help, definitely will get in touch when I get closer to making a decision!
    XJBaylor - Do you have any suggestions in terms of stereo system upgrades? Speakers, Amp, Sub? I am absolutely clueless about stereo components when it comes down to it. I dont want some outrageous system, saw the stealthbox and how it fit behind the seat, out of the way and have always wanted to get one. Any other suggestions would be awesome! Also, would like to keep the stock head unit if possible (just do speaker/amp/sub upgrade). Thanks again for the help
  17. Dec 9, 2011 at 12:35 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    Anyone that pays 700 bucks for 2 100 dollar subs and some wood is outta their mind, what a ripoff
  18. Dec 9, 2011 at 1:14 PM
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
    Sad thing is they pay for it.
  19. Dec 9, 2011 at 1:22 PM
    striker1021
    Phoenix, AZ
    '09 V6 Tacoma 4x4
    It really is unfortunate for a lot of people...at least I was smart enough to come to TW to look for some great advice from you all! :)
  20. Jun 17, 2012 at 6:39 PM
    chargedMK3
    chargedMK3 Member
    Jordan
    Lakewood Wa
    2012 Magnetic Grey Sport
    2.5" Level, Fuel Wheels, K02 Tires,
    Its plexi, not wood.
    The subs arnt that shitty, they do their job well
    Id rather have a box I know fits perfectly than a custom box I hop fits.
    just sayin
    RyanMC likes this.
