Anyone have idea whats going on here? When i floor it voltage shoots up, all dash lights come on(vid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, May 6, 2025 at 1:28 PM.
  1. May 6, 2025 at 1:28 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    https://files.fm/u/2e24mw3wvq
    When i floor it voltage all over the place, all dadh lughts come on and truck stutters. Auto zone did their test said alternator is good. Dont know how reliable that is though
  2. May 6, 2025 at 1:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Start by checking battery connections
    Look for something loose, like where the power cables go into the fuse box or main fuses
    Dm93 likes this.
  3. May 6, 2025 at 1:39 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What does “voltage all over the place” mean?
    Do you have any mods, e.g. a pedal commander?
    Chew likes this.
  4. May 6, 2025 at 3:41 PM
    stielinc
    stielinc Active Member
    This, was going to ask same question..
  5. May 6, 2025 at 3:49 PM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    In his video, if you watch the voltmeter on the scangauge when he floors it the voltage drops from 13 something down to 7.2 and when he lets off the throttle it soars to over 18 volts.
    gudujarlson[QUOTED] likes this.
  6. May 6, 2025 at 4:04 PM
    gudujarlson
    Minnesota
    Sounds like a short circuit. The voltage across the battery//altenator terminals will drop when the alternator/battery is working hard (delivering a lot of current).
    That would also explain why the engine is sputtering. The ignition system is not getting enough power.
    Many years ago the positive battery post on my 1974 Datsun pickup short circuited on my hood. The engine, lights, and everything else stopped running immediately and a spot on the hood started to glow. It was like a scene in close encounters of the third kind.
  7. May 6, 2025 at 4:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Or a loose connection ..
    The dash lights are all flashing on and off like someone is turning the truck off and on really quick
    A loose battery connection could do that
    SR-71A and Dm93 like this.
  8. May 6, 2025 at 4:46 PM
    gudujarlson
    Minnesota
    The drop in voltage and the sputtering engine are what I’m focused on.
  9. May 6, 2025 at 5:23 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Engines need electricity to operate. Look at those dash lights, ALL of them lighting up like a Christmas tree.. just like a bulb check when you first flip the ignition on..
    Dm93 likes this.
  10. May 6, 2025 at 5:32 PM
    gudujarlson
    Minnesota
    I’m not sure what your point is.
  11. May 6, 2025 at 5:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    A short circuit would likely blow a fuse, and that portion of the system would go dark and stay dark until the fuse was replaced. It's not going to rapidly cycle on /off
    A loose connection at the battery or fuse box however, could rapidly cycle on/off. And it would affect the entire truck, hence ALL the warning lights flashing in unison
    If it's related to him hammering the gas, I'm wondering if the torque of the engine moving is pulling on a harness or cable. I'd be checking connections at the battery, alternator and starter, fuse box.. wherever those big red power cables go..
    Is the battery hold down installed? Is the battery secure?
    Does he have a aftermarket fuse panel installed near the battery?
    Anyone recently done any work with lights or accessories?
    Veet-88, jmneill, Dm93 and 2 others like this.
  12. May 6, 2025 at 6:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I see lots of cars come in where the customer tried to put their own battery in and didn't get the cables tight. Drive over a sharp bump and the whole dashboard goes black for a quick second and then everything comes back on. Just like turning the key on and off really quick. Loose cable connection at the battery or fuse box causing an intermittent open circuit for the entire electrical system
    Dm93 likes this.
  13. May 6, 2025 at 7:12 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    How long has this been going on? Was something done to the electrical system lately? Is the battery light on?
    I tend to agree about a loose or corroded connection.
  14. May 6, 2025 at 9:19 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Is the battery ground cable tight on both ends, the negative battery terminal and to the body?
    Not sure where it is or if there are any, but also check the engine ground straps also.
    Veet-88 and Bertw192 like this.
  15. May 6, 2025 at 9:54 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    My immediate thought was the ground connection to the body. Based on the scan gage, I bet there are other more mods... and either stacked leads or a loose bolt is fouling it all up.
  16. May 6, 2025 at 10:04 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any modifications to the electrical system?
    Definitely go there, after checking for loose or damaged wires.
    t0p_d0g likes this.
  17. May 6, 2025 at 10:36 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    No one has mentioned possible rodent damage?
  18. May 7, 2025 at 9:57 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Not sure what testing was done, but that looks like a bad voltage regulator in the alternator.
    MagicToolbox likes this.
  19. May 7, 2025 at 10:25 AM
    OnHartung'sRoad
    Oooh, I’ve been saving this and forgot about posting it, drafts!
