Anyone have photos of how you carry 4x8 sheet goods?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ingot, Mar 21, 2019.
  1. May 3, 2019 at 11:27 AM
    #61
    ICU1
    ICU1 Well-Known Member
    deadpocketss likes this.
  2. May 3, 2019 at 11:49 PM
    #62
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It could well be, I don't know, but my assumption would be that it's the same thin metal as everywhere else with a few layers added in. It doesn't take too long to pull the cover and see. I had it off to add the reverse camera but didn't inspect that area.
  3. May 4, 2019 at 3:41 AM
    #63
    KDubU
    KDubU Well-Known Member
    That’s a lot of weight on the tailgate.
    2016Tacoman likes this.
  4. May 4, 2019 at 4:39 AM
    #64
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    About 400 lbs.
  5. May 4, 2019 at 5:09 AM
    #65
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    I’ve had way more on my 2nd gen trucks. It’s fine, people are way overboard saying the tailgates are weak. Most of the weight is down at the lower end anyways. I can easily lift up the entire load and open the tailgate. The weight is distributed between the front, the wheelwells and the tailgate.
    wi_taco likes this.
  6. May 4, 2019 at 5:27 AM
    #66
    jaapsheep
    jaapsheep Well-Known Member
    Janice
    canada
    2023 Blue Crush TRD off road access cab
    went for the blackout package this time
    I'm in the Okanagan, and I go out of my way to get Otter feed :)
    TinoTaco[QUOTED] likes this.
  7. May 4, 2019 at 5:31 AM
    #67
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Most of that weight is in the front. Pressing against the front of the bed. It’s not all on the tailgate.
    Thegenerik1 likes this.
  8. May 4, 2019 at 5:32 AM
    #68
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    YF_Ryan[QUOTED] likes this.
  9. May 4, 2019 at 7:56 AM
    #69
    2016Tacoman
    J
    True there is some force difference front and back because of the angle of the load, but if you do a static force diagram, only forces are at two points, front and back down. Force in the back is not alleviated from the load 'pushing' into the front of the bed. It's way over 300 lbs, about 350. If the load were level it would be shared equally, 50% front and back.
  10. May 4, 2019 at 8:00 AM
    #70
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Wrong, they also rest on the wheelwells. It’s not 350lbs, I lifted it and lowered the tailgate myself.
    MagicToolbox likes this.
  11. May 4, 2019 at 8:06 AM
    #71
    2016Tacoman
    J
    16 sheets of that 7/16 osb ply at 48 pounds each is 768 pounds total.
    Even if its resting in the middle you lifted 384 pounds. Really ?
  12. May 4, 2019 at 8:13 AM
    #72
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    I’m sorry you don’t understand physics.
  13. May 4, 2019 at 8:14 AM
    #73
    2016Tacoman
    J
    I took many statics and dynamics engineering classes. Fill me in.
    Nonetheless nobody needs any logic to realize lifting 16 pieces of 7/16 ply at one end is a feat regardless of how its loaded.
  14. May 4, 2019 at 8:28 AM
    #74
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    _____________
    ___I_____I___^
    Crude diagram but if something is supported where the vertical bars are, you can lift at the arrow and the force required is reduced substantially. It's how I can get a 500lb timber up on saw horses by myself.
    Thegenerik1 and royceferris like this.
  15. May 4, 2019 at 8:30 AM
    #75
    2016Tacoman
    J
    Once you lift at the right end, is not the only point of load at the extreme left vertical bar ? Yes. Middle one is not in play then. ie only 2 points. Rear and you holding it. Load is split, 50%.
  16. May 4, 2019 at 8:30 AM
    #76
    royceferris
    royceferris Well-Known Member
    Roy
    Nashville TN
    2019 OR DCSB 6MT
    https://www.vcalc.com/wiki/KurtHeckman/Mechanical+Leverage+Calculator
    Also... he has a long bed. The wheel well fulcrum isn't a thing in a 5 foot bed since they are all the way to the cab.
    wi_taco likes this.
  17. May 4, 2019 at 8:32 AM
    #77
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    It removed my spaces, look at edited diagram
  18. May 4, 2019 at 8:33 AM
    #78
    2016Tacoman
    J
    I only see where there are two points of load once raised. You '^' (tailgate) and 'I' near cab. Ply is at an angle once raised any at all. Once lifted any at ^ that middle I is no longer in the equation. You are supporting a good portion of the load. Proportional to the distances between the only 2 points. Angle come into play as it is raised also.
  19. May 4, 2019 at 8:39 AM
    #79
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    My point is if 1 of 2 supports is closer to the balance point, there is less weight held by the outboard support.
  20. May 4, 2019 at 8:42 AM
    #80
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    Exactly. Plus you are only lifting it maybe a half inch to allow the tailgate to drop and then lowering the load which will pivot on the wheelwells like a teeter totter.
    wi_taco and RocTaco[QUOTED] like this.
