Anyone have photos of how you carry 4x8 sheet goods?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ingot, Mar 21, 2019.
  1. May 4, 2019 at 11:47 AM
    #101
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    That would be 375 I believe, for short bed
    2016Tacoman[QUOTED] likes this.
  2. May 4, 2019 at 11:49 AM
    #102
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    We can explain it to you but we can't understand it for you.
    wi_taco, TomTwo, Alnmike and 2 others like this.
  3. May 4, 2019 at 11:53 AM
    #103
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Correct.
    A .......................B
    Short bed
    -------- 16 sheets of ply at 750 lbs.
    ^ resting points
    If B lifts the ply how much weight is he lifting ?
    Correct. 375 A hell of a lot of weight. Not many at all can do that from chest height. Maybe 1% or less.
  4. May 4, 2019 at 11:58 AM
    #104
    BigWhiteTRD
    Ted
    Here I thought you were saying for short bed picking it up was 79% of the load. Guess I was confused.
  5. May 4, 2019 at 11:59 AM
    #105
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    ITS NOT LEVEL IN THE BACK OF THE TRUCK.
    walterj and Alnmike like this.
  6. May 4, 2019 at 12:03 PM
    #106
    ICU1
    ICU1 Well-Known Member
    If no one is around when the tree falls, does the tree really make a sound?
  7. May 4, 2019 at 12:13 PM
    #107
    2016Tacoman
    J
    He said he lifted and lowered the tailgate. So it is level when finished and he is supporting 1/2 the weight in a short bed or it is crashing into the bed.
    Do you let 350 lbs slam your composite bed ?
    If so then your right.
    I'm out of here.
  8. May 4, 2019 at 12:39 PM
    #108
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    I’m sorry you can’t conprehend. It was me who had the 16 sheets of plywood.
    I don’t know the equation, which is complicated. But I know the angle of the material and the length of the material are factors.
    Imagine if a 1’ long bar of steel weighed 500lbs. Lifting one end would be very very hard to do. Now imagine a 20’ long bar of aluminum weighs 500lbs. Can you lift the end of it? Yes it would be very easy. Understand?
    Now the angle also matters. If you had that 1’ bar of steel flat on your work bench it would be almost impossible to lift up one end. Now if it was on a material cart at a 45 degree angle it would be much easier to lift the upper end.
    RocTaco likes this.
  9. May 4, 2019 at 1:29 PM
    #109
    ICU1
    What the sheet is going on here?
    Goochwarmer, MR E30 and Thegenerik1 like this.
  10. May 4, 2019 at 1:36 PM
    #110
    BigWhiteTRD
    Ted
    I sheet the bed
    tonered, ICU1[QUOTED] and RocTaco like this.
  11. May 4, 2019 at 1:44 PM
    #111
    DOSS
    DOSS Well-Known Member
    Scott
    Utah
    2016 Black Tacoma TRD Sport DBCB
  12. May 4, 2019 at 2:02 PM
    #112
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    I was going to chime in, but reading all this sheet made me reconsider.
    TinoTaco and TomTwo like this.
  13. May 4, 2019 at 2:03 PM
    #113
    ICU1
    Boots optional for this discussion
    RocTaco likes this.
  14. May 4, 2019 at 2:10 PM
    #114
    Alnmike
    PNW
    '21 4R
    Unless those boots are tied together hanging on two supports 20 inches apart and one boot fills with water at a rate of 3cm^3 per hour and the evaporation rate is 8% per minute.
    MagicToolbox and RocTaco like this.
  15. May 4, 2019 at 2:12 PM
    #115
    ICU1
    I think you’re onto something here. What if one boot is half size smaller? Don’t even get me started on that...
  16. May 4, 2019 at 2:13 PM
    #116
    ICU1
    I’ve had many classes on shoeology
  17. May 4, 2019 at 2:18 PM
    #117
    Alnmike
    PNW
    '21 4R
    If one size is smaller, the moment of inertia will make it tricky to throw up onto the power lines.
  18. May 4, 2019 at 2:30 PM
    #118
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    wi_taco, MR E30 and FitzTaco84 like this.
  19. May 4, 2019 at 2:40 PM
    #119
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I think we have a winner but not sure who it is .
    wi_taco likes this.
  20. May 4, 2019 at 2:41 PM
    #120
    ICU1
    But at what point will one boot/shoe hang lower than the other boot/shoe? These serious questions keep me up at night
