Anyone have problems with mice (or any critters) while camping?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nixinus, Jun 21, 2019.
  1. Jun 21, 2019 at 8:50 PM
    Nixinus
    Nixinus [OP] Well-Known Member
    Oregon
    2010 4x4
    Now I want chilli cheese dogs...
    steveo27[QUOTED] likes this.
  2. Jun 21, 2019 at 8:51 PM
    tcjacado
    tcjacado Well-Known Member
    I would have named that car the hantavirus
  3. Jun 21, 2019 at 9:13 PM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    good thing Hanta is not in southern az last 5 years
    tcjacado likes this.
  4. Jun 23, 2019 at 7:30 AM
    Nixinus
    Oregon
    2010 4x4
    So I see some fiberglass exhaust wrap and insulation at my local auto parts store and it got me thinking. Would filling the areas under the airbox with some type of insulation prevent the bastards from getting up there in the first place?
  5. Jun 23, 2019 at 10:00 AM
    tcjacado
    Nope, they will use that to make their nest more comfortable, the insulation especially.. fiberglass wrap may just restrict air flow too much.
  6. Jun 23, 2019 at 10:20 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    The cayenne pepper and water in a spray bottle is similar to what I did when squirrels chewed my wiring harnesses except I used men’s hairspray and then quickly dusted with cayenne pepper.
    The hair spray help make it stay longer.
    Skyway and tcjacado like this.
  7. Jun 23, 2019 at 10:25 AM
    Nixinus
    Oregon
    2010 4x4
    Where are you spraying and laying down the cayenne? I'm looking at my engine with the plastic cover removed and I would like to get this as close to the "valley" under the intake plenum. I don't see any clear way into that space without removing a bunch of parts.
  8. Jun 23, 2019 at 10:32 AM
    tcjacado
    Remember mice also clean themselves.... so as they are crawling around they will get it in their fur and when they clean themselves.... magic. They won't typically stay in a area that has consequences.
  9. Jun 23, 2019 at 10:33 AM
    spitdog
    I just hit all the visible areas real good, especially the wires. I also took a large plastic cup with a snap on cap, filled it up with moth balls, drilled a bunch of 1/4 holes and zipped tied in in my engine bay. I didn’t drive my last tacoma that much because I had a work truck. So I think the squirrels thought that was a good place to nest and eat my wires. Moth balls are pretty strong and you may not want to go that far with the zip tie if it’s a daily driver, but you could do the same where you park and just leave them on the ground.
  10. Jun 23, 2019 at 10:37 AM
    Nixinus
    Oregon
    2010 4x4
    I'm starting school tomorrow and use a cheap daily driver to commute so the truck won't get out much, maybe an occasional weekend trip. I sealed my garage pretty well but I'll still hang some moth balls in the engine bay while it sits.
    spitdog[QUOTED] likes this.
  11. Jun 23, 2019 at 10:39 AM
    Nixinus
    Oregon
    2010 4x4
    That makes sense, thanks. I would prefer not to spray cayenne (or anything) over electronics or parts that get real hot. I've got a few good spots that can be coated to hopefully stop them in their tracks.
  12. Jun 23, 2019 at 10:40 AM
    Nixinus
    Oregon
    2010 4x4
    Do you guys think using some cheap lights, something slim like a pen light, and shinning it in that valley under the plenum would help?
  13. Jun 23, 2019 at 10:51 AM
    tcjacado
    I think if I was going that route I would just install a couple of rock lights in the engine bay.
  14. Jun 23, 2019 at 10:57 AM
    spitdog
    If your not driving the truck, put some baited mouse traps at the tires. That’s where they first access the truck.
  15. Jun 23, 2019 at 3:40 PM
    #35
    Nixinus
    Oregon
    2010 4x4
    I've got rock lights setup as work/bed lights. I know the draw is not a lot but don't want to leave them on all night, especially when it gets cold.
    Any recommendation? I looked at the poison (Warfarin) ones but I have a dog at home.
    For those wondering why I seem like such a noob, this is the first time I've encountered this many rodents. This was my first overnight in Tillamook (Oregon) where I saw dozen crawling on the ground when I flashed a light. I've got no experience with rodents since I've maybe seen 1 or 2 growing up in SoCal.
  16. Jun 23, 2019 at 4:07 PM
    #36
    spitdog
    I have a dog at home also and I use jerky for bait in victor mouse traps. It’s safe, it last and mice love it. Went you first set the trap , wet the jerky good.
  17. Jun 23, 2019 at 4:20 PM
    #37
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Moths have balls ?
    Nixinus[OP], steveo27 and tcjacado like this.
  18. Jun 23, 2019 at 4:59 PM
    #38
    Preston Lay
    Preston Lay Member
    Preston
    I will try the pepper/water mix and see if that will cure the problem for me.
  19. Jun 24, 2019 at 1:23 PM
    #39
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    I've had lots of underhood wiring chewed up by a marmot and I've also spent hours battling a pika that finally left. Animals love hot engines on cold nites. Always open your hood when you park to let out the heat. I've used coyote urine with mixed success. Plus your dog may not like it. I've only had trouble with a hot engine. Best thing to do is get to camp in the afternoon, open the hood and have a cold engine by dark. I know it's not always possible....
    Nixinus[OP] and WPNZ like this.
  20. Jun 24, 2019 at 3:32 PM
    #40
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    What the hell kinda horrible places are you camping that rodents run rampant like this? I spend almost every other weekend in the woods and will maybe see a single mous or 2 all weekend.
    Sounds like you have some kinda plague following you.
