Anyone have problems with seized camber bolts during alignments?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, Jul 19, 2025.
  1. Jul 19, 2025 at 9:53 PM
    Redtaco777
    Redtaco777 [OP] Well-Known Member
    NC
    Uni-filter Mod
    do u know what’s all that I’ll need ? Shoot 100 is not bad
  2. Jul 19, 2025 at 9:53 PM
    Redtaco777
    NC
    Uni-filter Mod
    really ? I head people talk down on hardware that’s not oem so bad it’s crazy
  3. Jul 19, 2025 at 9:55 PM
    Bishop84
    Bishop84 Well-Known Member
    I have a co-worker that just installed Amazon arms and they have play already, its a roll of the dice.
    The hardware is usually available at dealers, cutting them out sucks, a good sawzall and blade grease makes it easier.
  4. Jul 19, 2025 at 9:56 PM
    Owenhall
    Owenhall Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    Honestly there was no difference and they fit perfectly in the bushings seemed they high quality didn’t seem like soft steel or anything. ( I’m talking about the cam bolts sorry if I confused anyone)
  5. Jul 19, 2025 at 10:00 PM
    Redtaco777
    NC
    Uni-filter Mod
  6. Jul 19, 2025 at 10:09 PM
    RockinU
    RockinU Well-Known Member
    Texas
  7. Jul 21, 2025 at 12:19 PM
    Redtaco777
    NC
    Uni-filter Mod
    what part numbers did u ask for, i think i already will have the cam bolts
  8. Jul 21, 2025 at 12:19 PM
    Redtaco777
    NC
    Uni-filter Mod
    how have they been holding up so far for you I am thinking about getting these exact ones
  9. Jul 21, 2025 at 12:28 PM
    RockinU
    Texas
    I’ll try to look through my file of receipts when I get home.
  10. Jul 21, 2025 at 12:29 PM
    RockinU
    Texas
    All good. LCA’s aren’t a big failure spot aside from wearing out ball joints and bushings. I wasn’t super picky about them, and honestly picked the ones that would arrive soonest.
  11. Jul 21, 2025 at 1:14 PM
    Keaton1717
    Keaton1717 Well-Known Member
    Keaton
    New Richmond, OH
    Cement 2020 DCLB TRD OFFROAD/MGM 2014 ACLB TRD OFFROAD
    @Redtaco777 this is what I have been running for 80,000 miles and haven’t had any issues with them. And no issues with the cam bolts seizing either. Hope this helps. Won’t break the bank either.
    Redtaco777[OP] likes this.
  12. Jul 21, 2025 at 1:34 PM
    Redtaco777
    NC
    Uni-filter Mod
    thanks, why do u need the dorman bolt i thought the ki already comes with everything
  13. Jul 21, 2025 at 1:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Those bolts are greaseable.
    The others are not.
    Now.....Let's see how long it takes for someone to start an argument about, "The greaseable bolts are weaker".
    In theory, they are. In practice, I never seen them break or bend.
    I personally never had my cam bolts seize. But I have lifetime alignment.
    So my cam bolts get "adjusted" at least one a year. (if needed) Plus, I don't live in a rust prone area. (salt state)
    I also don't submerge my truck in water and mud. I'm old. I use my truck to commute, haul, and tow.
    I don't play the mud anymore. I'm lazy. Fixing and cleaning things are no longer my idea of fun.
  14. Jul 21, 2025 at 1:41 PM
    Keaton1717
    Keaton
    New Richmond, OH
    Dorman is the cam adjuster bolts and they are greaseable. That’s what they use for the alignment. The LCA’s come with everything to install just not the cam adjuster bolts.
  15. Jul 21, 2025 at 1:49 PM
    #35
    Redtaco777
    NC
    Uni-filter Mod
    oh i was just confused on why the lcas came with three bolts
  16. Jul 21, 2025 at 1:54 PM
    #36
    Keaton1717
    Keaton
    New Richmond, OH
    They bolt into the spindle.
  17. Jul 21, 2025 at 2:00 PM
    #37
    Redtaco777
    NC
    Uni-filter Mod
    ohhh. honeslty man i dont even know if i should even buy new lcas my truck literally only has 80k miles its a 2012, regardless i will still need to buy the cam bolts just incase they are seized
  18. Jul 21, 2025 at 2:11 PM
    #38
    Keaton1717
    Keaton
    New Richmond, OH
    Yeah, when I cut mine out I had to buy new LCA’s because I heated up the rubber bushings so much that they started to melt.
  19. Jul 21, 2025 at 2:12 PM
    #39
    Redtaco777
    NC
    Uni-filter Mod
    #39
  20. Jul 21, 2025 at 2:20 PM
    #40
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I used to. Also had issues with the tabs bending flat. Took care of it though:
    RockinU and crashngiggles like this.
