Anyone have problems with their Add A Leaf moving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackSeven, Apr 17, 2012.
  1. Apr 17, 2012 at 6:54 PM
    BlackSeven
    BlackSeven [OP] Grab your helmet, this shits about to get retarded
    Maryland
    '10 Reg Cab 4x4
    Toytec Ultimate Lift kit, Toytec Rear AAL, 4.88 Gears, ARB Rear locker, Doug Thorley header, Volant Cold Air Intake, Demello Offroad front high clearance bumper, ARB On board Air compressor, BLHM, Wet Okoles, 2011 Color matched grill, Weathertech mats, 4x Innovations Sliders, ATO Engine Skid plate, ATO High lift bed mounts.
    My AAL keeps twisting in the leaf packs and it ends up hitting the brace on the front of the pack and squeaking. All I do to fix it is whack it about 8-9 times with a dead blow to get it back inline with the rest of the leaf pack. It's just kind of annoying to have to do that. It always happens the same way on either side. The front of the leaf moves towards the outside of the leaf pack. I've had to do it twice now (once on each side) about 1 week apart.
  2. Apr 17, 2012 at 7:00 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Retorque your u-bolts after realigning the AALs. The 37 ft-lbs in at least some of the FSMs is some kind of error, 75-85 lubed is the correct range. I did 85. Then retorque several more times after a couple hundred miles each until they don't move anymore. That should cure it.
  3. Apr 17, 2012 at 7:02 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Spring clamps.
    They also help axle wrap. Have fixed my squeak completely.
  4. Apr 17, 2012 at 7:03 PM
    BlackSeven
    Maryland
    '10 Reg Cab 4x4
    Awesome thanks for the tips. I'll re-torque them tonight.
  5. Apr 17, 2012 at 7:06 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Same thing happened to Kona, spring clamps got him fixed up I think.
