Anyone have SSW Dakar wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nerveblock, Jun 28, 2023.
  1. Jan 14, 2025 at 12:15 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    It should be very close at stock alignment specs, if you get a higher castor alignment you should have 0 rubbing. May have to remove mud flaps or go to a low pro option. I was able to run 285/70r17 on a 17x9 +1 with a 2" front 1" rear and an alignment with added castor.
    Tacopaco98 likes this.
  2. Jan 14, 2025 at 12:33 PM
    Tacopaco98
    Tacopaco98 Active Member
    Timmy
    2021 Tacoma sr5
    so hypothetically speaking… you’re saying i can run 17x9 -12 with 285/70/17 tires on a 2inch lift without rubbing , CMC, or trimming needed on stock parts ?
  3. Jan 14, 2025 at 12:35 PM
    Tacopaco98
    Timmy
    2021 Tacoma sr5
    so aslong as i have higher castor alignment and a 2/1 lift , i can use my stock UCA’s and etc and not worry about rubbing , cmc , or trimming ?
  4. Jan 14, 2025 at 3:05 PM
    Veet-88
    It's always a maybe as every truck is different to some degree.
    The lift is the least important aspect here. Lifts do not mean clearance it only helps ride height. If you hit a bump while turned the wheel goes right back to where it was and what it would of rubbed on at stock height it will still hit under compression.
    The alignment pushes the wheel forward in the wheel well to help with the cab mount clearance.
    The only 100% way to gaurentee no rubbing is you have to be ready to trim and cut a bit worst case. Doesn't matter what we say here you need to make sure you have a competent shop to help you make it work if you don't understand how to do it.
    By rule of thumb yes this should work but never a gsurentee
    SloTaco13 and Tacopaco98 like this.
  5. Jan 14, 2025 at 4:09 PM
    SloTaco13
    SloTaco13 Well-Known Member
    California
    2023 Lunar Rock TRD Offroad 4x4
    I ran this setup without any rubbing (with zero trimming) with a 2.75" lift up front and stock UCAs. However, my lift installation shop said my truck was the only Tacoma he's worked on that did not rub with a wheel/tire setup that aggressive (17x9 -12 and 285/70/17).
    With 17x9 and 0 offset and 275/70, you should be in the clear, with zero trimming needed... but just as Veet-88 said above, it's never a guarantee.
    Veet-88 likes this.
