Anyone Have Sway Bar Specs?
Discussion in 'Suspension' started by Cooter, Jan 14, 2012.
  1. Jan 14, 2012 at 10:24 AM
    Cooter
    Cooter [OP] New Member
    OR
    03 Ext Cab SR5 4WD 3.4L 6" Lift
    6" Lift, Flowmaster Exhaust, Custom Roll Bar
    Somehow my sway bar contacted my driver side cv axle. The link is bent and the cv axle boot is all torn up. I can't tell if my sway bar is bent or not by eye, and I'm looking for the specs online to make sure. I suspect I might have some more serious issues though.
    2003 Ext Cab 4WD 3.4L V6
  2. Jan 14, 2012 at 10:37 AM
    Underdog777
    Underdog777 Well-Known Member
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    Pretty much everyone is going to run through here telling you to take it off and leave it off. It's the right thing to do.
    As far as specs I can't help you off the top of my head. Usually I go with "if it doesn't look right, it's wrong".
    edit: welcome to Tacoma World.
  3. Jan 14, 2012 at 11:43 AM
    Cooter
    OR
    I am lifted 6". People are telling me running without a sway bar makes the truck "dive" into corners pretty hard, especially lifted trucks. Since the link is bent on my driver side, I have noticed a pretty significant difference when turning, hitting speed bumps, potholes, etc. I would really rather fix the problem instead of just leaving the sway bar off, although the cheapest one I found is about $150 online.
    If I just knew the distance from end to end, that would help alot. But I guess I have to take mine off and find one at a junk yard to hold it up to then?
  4. Jan 14, 2012 at 12:13 PM
    Underdog777
    Gilberz
    '06 Stuckrunner
    Camburg LT.
    The "dive" isn't that bad. While I'm not lifted six inches I can safely say that in day-to-day driving you won't roll your truck, and you Cadillac around turns. If you wheel it, your making one less part to get fubar.
  5. Jan 14, 2012 at 5:07 PM
    Cooter
    OR
    It's the Fabtech 6" kit.
    I took the bar off for now, and it really isn't as bad as others were saying. It started snowing, so I guess I'll deal with it next weekend. Thanks anyway guys.
