Anyone have the leaf spring recall for 2nd gens?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NeonHeights, May 19, 2018.
  1. May 19, 2018 at 11:11 AM
    NeonHeights
    NeonHeights [OP] Well-Known Member
    Looking for a little bit of help with anyone who received the rear leaf spring recall on their 2nd gen tacoma.
    Wondering if you could send me the part numbers that are printed on the top of your driver and passenger side leaf packs so I can confirm with mine.
    I received the recall springs last summer and my drivers side springs are sagging A LOT. There is a 2" difference in height between the driver and passenger side pack, so im trying to figure out if I was given the right packs and if they were installed on the right sides.
    My passenger side leaf pack has WHITE text and is part #48210-04660
    My driver side leaf pack has YELLOW text and is part #48220-04300
  2. May 19, 2018 at 11:30 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I never got the replacements since i already did the 3 leaf add a leaf. What you’re experiencing is consistent with what a lot of other guys are experiencing. I didn’t change mine for that exact reason. For me, why replace crappy leafs with crappy leafs. If mine ever fail with the added support of the aal then I’ll get something better. I know you were just asking for the numbers sorry I don’t have that.
  3. May 19, 2018 at 11:30 AM
    NeonHeights
    Ive heard of sag, but never 2". You can see it very obviously from the back. Other guys report 0.75-1" difference
  4. May 19, 2018 at 11:35 AM
    maxtherat
    Inland Northwest
    From what I’ve heard it’s all over the place especially if you have offspec +/- leafs along with the lean. Point being, Toyota hasn’t done us any favors with these leafs. I don’t know what the colors mean and what the difference in pn is all about.
  5. May 19, 2018 at 2:45 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    My 2005 4x4 4cyl AC truck just got a new frame with new leafs. BRB
    Just remember - my truck is a 4cyl access cab. The truck in your profile picture is a double cab.
    EDIT: I was wrong! I found them hiding way on topIMG_0446.jpgIMG_0447.jpgIMG_0448.jpg
    BassAckwards likes this.
  6. May 19, 2018 at 2:47 PM
    Pigpen
    Dan
    Northwest Montana
    The new leaf packs are as bad as the old ones. You get a replacement, not an upgrade.
  7. May 19, 2018 at 4:10 PM
    NeonHeights
    Thats very unfortunate. My bed is completely empty, all I have is a 150lb steel rear bumper, and im getting 2" of drivers side sag on virtually brand new leaf springs.
  8. May 19, 2018 at 6:07 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    If you get a new set under recall, make sure to fluid film them. I got mine replaced under TSB in 2014 - they look like shit and are all rusted now in only 4 years. Toyota still makes the most reliable vehicles that will last, but some of their decisions are pretty terrible when it comes to materials and finishes.
  9. Aug 29, 2018 at 12:01 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    After putting this off for a year or so, I decided to go and get my leaf springs changed out under the recall. I drove 40+ miles to a dealer and service department that I had a little more faith in. Much more faith than the one that is only about 5 miles from my house. While there, they also looked at the frame and U-joints. Both checked out just fine. The original leaf springs were a three pack and the new ones are a 4 pack. I did notice that the new bump stop is different than the old one. I've reinstalled my Roadmaster Active Suspension (RAS) back on and it all looks pretty kosher. I do plan on spraying the new leaf springs down with some LPS 3 or something equivalent.
    I took some measurments before and after that I'll list those below, along with a couple of pictures of the bump stops. Measurments were taken from the top of the rear wheel to the bottom of the fender flare on the passenger and drivers side of the vehicle.
    OLD leaf spring with the RAS still on;
    D.S. 7 1/4" ---- P.S. 7 1/2" RAS was set at the 25% setting for handling and load carrying (set in 2012)
    OLD leaf spring with RAS removed;
    D.S. 6 3/4" ---- P.S. 7"
    NEW leaf springs prior to RAS reinstall;
    NEW leaf springs with RAS reinstalled;
    D.S. 7 5/8" ----- P.S. 7 5/8" RAS now adjusted to the 40% setting for handling and load carrying
    OLD BUMP STOP
    NEW BUMP STOP
  10. Aug 29, 2018 at 12:34 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Get some OME Dakars and done...
  11. Aug 29, 2018 at 1:13 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    mine were replaced last year
    no sag as the rear is higher than the front still
    I didn't measure it but the rear before wasn't that much higher.
  12. Aug 29, 2018 at 2:29 PM
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I got the recall springs during the frame swap in march and not even two months and the new springs squeak and creak like they are antique leaf springs. I still love my truck it just sounds like a pile thanks to these awesome springs.
  13. Aug 29, 2018 at 4:22 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Im supposed to go this week for the recall the dealership called and said the parts were in . But I don’t think im going to let them change it. I just leveled the front with 5100 and I don’t want it to have the rake again. So I bought some 2-1/2 inch ubolts and im going to add them were the spring can possibly swing into the gas tank. And my frame is also recalled for the spray and im not letting them do that either
    JSB10 likes this.
  14. Aug 29, 2018 at 4:50 PM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    Here are my replacement spring #s:
    LH spring 48220-04300
    RH spring 48210-04660
    These are the correct springs that replace the old 4 leaf TSB springs, that were much better in my opinion.
  15. Aug 29, 2018 at 5:01 PM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Access / DBL Cab Replacement Spring Kits for the old 3 leaf noodle springs: 04005-34204
    Replacement for the better 4 leaf "Harsh Ride" TSB springs: 04005-34404
    Install Kit: 04005-34104 for both.
    The new "Safety Replacement Springs for the Harsh Ride TSB Springs" (whew) are sitting about an inch lower than the old 4 leaf springs.
    Fritz
  16. Aug 29, 2018 at 5:04 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    I got the replacement under TSB and they helped but I love the Dakars so far. 2010 AC.
  17. Oct 16, 2019 at 11:32 AM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Reviving this thread...
    Some are saying the original 4 leaf (3+1) leaf spring pack is better than the new recall 4 leaf (3+1) leaf spring back.
    Is this correct?
    I'm contemplating getting the recall springs to replace my old sagging original leaf springs but it sounds like I shouldn't as there isn't any improvement from the new springs to the originals... No increased weight capacity, no lift.
  18. Oct 16, 2019 at 2:40 PM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I have an '06 Sport. My right spring says RX -045-7 & my left says RX 046-7.
  19. Oct 16, 2019 at 6:19 PM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    The part # on my recall sport springs are right side 48210-04650 in white
    Left side 48220-04290 in yellow
    I haul fire wood with no problems.
  20. Oct 16, 2019 at 6:25 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Some low mileage 2015s with 4 leafs, which are same part numbers as recall ones certainly helped out my RC, even lifted the rear 1". Did this a few yrs back and still good to go. Didn't bother to waste time at dealership and spin wheel of danger having them "work" on my truck. NOT worth the risk.
