Anyone have their wheel bearings life cut DRAMATICALLY short after 35 inch tires ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05BDS, Jul 15, 2013.
  1. Jul 15, 2013 at 7:46 PM
    05BDS
    05BDS [OP] Well-Known Member
    2005 TRD 4door Tacoma
    6 inch BDS lift 35x12.5 Nitto Trail Grapplers 18x20 KMC Rockstars
    Hey guys, got a 6 inch bds lift and 35x12.5 tires, re-did my wheel bearingd about 7500km ago, both the front, and after installing new spidertrax wheel spacers my front passengers side bearing is done. Wondering if the tires and spacers are too much for the bearings, thanks, !:D
  2. Jul 15, 2013 at 7:49 PM
    Brandon###
    Brandon### Well-Known Member
    They probably weren't installed properly the 1st time.:infantry::popcorn:
  3. Jul 15, 2013 at 7:50 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  4. Jul 15, 2013 at 9:08 PM
    05BDS
    brought them to a local shop and had them done, think it was a friday and they rushed through it?
  5. Jul 16, 2013 at 9:19 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    You'd think 35's would lengthen bearing life. Much less rotation per distance.
  6. Jul 16, 2013 at 9:22 AM
    DMBFan37
    DMBFan37 Well-Known Member
    This happened to me. The lift will also shorten your CV boots lives.
  7. Jul 16, 2013 at 10:10 AM
    05BDS
    @psutaco , i dont think so, it looks like the seals are leaking , bummer, maybe its time i learned out how to do this myself. Anybody have a thread on wheel bearings? on auto locking hubs?
  8. Jul 16, 2013 at 10:34 AM
    mr2mki
    mr2mki Well-Known Member
    More torsional force though.
  9. Jul 16, 2013 at 12:04 PM
    05BDS
    lol its going 2 be a pain in the ass the most i have ever done is the lift for my truck and never really got too involved with the wheel bearings, gonna go buy a pair and do the passenegers side and wait till the drivers goes !
  10. Jul 16, 2013 at 12:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    With the larger tires you dramatically increased the load on the bearings. Then the added spacers you increased that load exponentially.
    Yes the bearings and seals will have a shorter life span. The stock bearings and seals were not designed for that loading.
    Other than going to a more robust bearing seal arrangement it will continue to be an issue. That and water washing out the grease is why you see so many threads on here about front bearing replacements.
  11. Jul 16, 2013 at 12:24 PM
    no mods
    no mods Well-Known Member
    cincinnati
    Some stickers
    I used to have bearing issues ... I have 35s for years and now on 36s. The secret lies in keeping the water out ..
    the fix.. Pack wheel bearing grease inside the rear seal. No more fail. Well at least it slowed them dramatically. I'm about 1 every 10 months. I get the cheapest turds from where ever I can find eBay/ rock auto
  12. Jul 16, 2013 at 12:36 PM
    05BDS
    thank you guys so much for the tips and advice ! i am going to pull the tire off and take a look, i bet the mechanic who worked on my truck messed something ( dont let drunk friends wrench ) lol, i will keep you all posted as once ive checked the bearing and seals i will take some pictures and post them !
  13. Jul 16, 2013 at 12:41 PM
    4x4yota
    4x4yota 4wd is awesome
    Collin
    PA
    02 trd stepside v6
    +1
    35s are hard on bearings then the added spacers is also hard on them
  14. Jul 16, 2013 at 12:41 PM
    no mods
    cincinnati
    Some stickers
    U don't even have to do that if u jack up truck and grab the top of the tire and move it back and forth it ( push towards driver /passenger) any slop will tell u the bearing is junk and new seals and bearing need to be pressed on.
  15. Jul 16, 2013 at 1:06 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    1 every 10 months. You Still have bearing issues. Just sayin. :rolleyes:
  16. Jul 16, 2013 at 1:11 PM
    no mods
    cincinnati
    Some stickers
    I suppose then have dirty oil issues, air filter issues, brake pad issues and tire pressure issue too. A $40 dollar repair once a year is just the cost of doing business in my book
  17. Jul 16, 2013 at 1:44 PM
    no mods
    cincinnati
    Some stickers
    No kidding! Can't even imagine what it would look like if I was out like 2 times a month.
    I forgot I also have twilight and mirror issues too.. Those get "serviced" at least once a year too
  18. Jul 16, 2013 at 1:54 PM
    no mods
    cincinnati
    Some stickers
    On a totally different side note I figured out the takeoff shutter I've had for 2 years now.. Turns out the lift plus bigs wheels and heavy payload is hatefull on the carrier bearing. (Which also gets annual replacement) I figured out if u toss some window weld in there and let it setup shutter goes away! Who 'd a thunk I was lover loading the abilities of a center support bearing. Next one I put together will have hot formed polyurethane formed in it for the cool factor.
    This should have been stickied like 2 years ago .. I would have a lot more hair for sure
  19. Jul 16, 2013 at 1:56 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I would venture to say the spacers put more strain on the bearings than the tire size by moving the leverage out further, than normal on the bearings.
    I know lot's of guys have spacers without problems, but I am not a fan of them.
  20. Jul 16, 2013 at 3:25 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I have around 30,000 miles on 37's. Same set of wheel bearings. Stock steering components. The other 50,000 miles (80K total) were on 33's, and I changed them out at 50,000 miles because you guys made me paranoid and think they must be bad. They weren't. I also greased the seal quite a bit.
