Anyone have this happen?
Discussion in 'Technical Chat' started by Pennywise, May 26, 2010.
  1. May 26, 2010 at 4:51 AM
    Pennywise
    Pennywise [OP] Active Member
    Here I was, comming home from work, I feel a slight wobble up front on the left side. I say to myself "Thats strange", then all of a sudden I am riding on my left front rotor and my front wheel is passing me and doing some serious 4 wheelin through the woods! i stay focused on getting my truck off the road and out of on comming traffic, luckily it is only 1 car, so I ease her off the road and then I can concentrate on my now airborne tire and about 200 meters on up the road, still getting it on about 40 mph and heading into a blackberry bush about 40 ft wide and 100ft long! I eventually found my tire and rolled it back to my truck. i jacked it up and saw that 1/3 of my rotor was ground off but all was still intact. So I borrowed a lug from my 3 wheels
    and put her back on and drove home, the truck drove just fine. I will find out more when I have some time off to disassemble the left side and check her out.. :confused: I am running 33" tires with Bilstein shocks and toytec springs, only 3" of lift.
  2. May 26, 2010 at 4:57 AM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
    never had that happen to me but glad you're ok and no one was hurt!
  3. May 26, 2010 at 4:58 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    They make these things called lug wrenches that are used to keep your lug nuts tight. Check the tightness of all your lug nuts on a regular basis and you won't be losing any wheels.
    Glad everyone is OK.
  4. May 26, 2010 at 5:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    I have seen it happen several times.
  5. May 26, 2010 at 5:28 AM
    Pennywise
    Nice!!! Thanks, I just tightend them 2 weeks ago after changing the front springs.. But the incident just changed the lug check to a every sunday check.. thanks for the concern..
  6. May 26, 2010 at 6:19 AM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    If you properly torqued them just 2 weeks ago I highly doubt they loosened up all by themselves, more likely some asshat was going to help themselves too one of your tires
  7. May 26, 2010 at 6:33 AM
    Pennywise
    Funny you should mention, the fronts were loose but not the backs (possible since that was the last thing worked on) but I did torque them! The tires are some nice ones though (Cepek Crushers) and brand new.. Hah!
  8. May 26, 2010 at 6:36 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Only seen that in the movies. Glad you're OK.
  9. May 26, 2010 at 6:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Aluminum rims?
  10. May 26, 2010 at 7:12 AM
    Pennywise
    Thats a roger...15X10's
  11. May 26, 2010 at 7:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    That might be why. I have always been told to retorque them after 100 or so miles by my local tire shop. I don't know if there is any validity to this though. Oddily, they never tell me that when I bring in the steelies.
  12. May 26, 2010 at 9:05 AM
    Pennywise
    Thanks for the info... It will become a practice..
  13. May 26, 2010 at 9:10 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    I worked at a wheel shop, all aluminums got retorgued after 100 miles due to the wheel softness. Steelies are good after 1 shot
  14. May 26, 2010 at 9:16 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    always check your torque a hundred miles or so later its just a good habit. I have my torque wrench in my truck it only takes a minute.
  15. May 26, 2010 at 9:20 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Are you using a torque wrench? And I'll second re-torquing aluminum wheels after 100 miles or so.
  16. May 26, 2010 at 9:46 AM
    Pennywise
    Yep, using a torque wrench, but not checking every 100 miles. Thanks for the new info guys, i have never heard of the 100 mile check on the lugs.
    Interesting how a minute piece of info and the lack of knowledge there of can make you feel like a jackass! Thanks once again.
  17. May 26, 2010 at 10:03 AM
    Bretsuaz48
    Bretsuaz48 Well-Known Member
    Bret
    Surprise, Arizona
    2016 Sport
    Thankfully, no one was injured. Could have been really bad.
  18. May 26, 2010 at 2:38 PM
    Barnone
    Barnone Guest
    Pennywise.
    Glad that all turned out ok. Could have been a disaster.
    How far did you drive before the wheel came off?
    I've got to go with Snipe and say that someone removed the lug nuts either to steal the wheel or to play a nasty trick on you. I find it hard to believe that all the lug nuts would come off at the same time.
  19. May 27, 2010 at 1:57 PM
    Pennywise
    Yep, all left fronts came off, and the wheel lock snapped the lug clean off. The right fronts were semi loose. I drove around 250 miles at the most and it was a first for me to have that happen. All I can say is that it was an interesting mishap that could have gone south in a bad way. The vehicle recovery was a cinch and handling the truck with 3 wheels wasnt all that bad, but it sure could have been a doozy. I just rounded a long right hand turn at the lake with oncomming traffic and the road I was on is bordered with large pines. This could have been a career ender. I just have to chalk it up to numerous driving courses (trak and off road) that really paid off in the recovery of the vehicle after the wheel came off. Toyotas equipment did hold together and saved my bacon! Thanks for the concern! Hope to see you guys one of these times, this forum has good people on it.
