Anyone have this trans low fluid problem ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bw4706, Jan 23, 2014.
  1. Jan 29, 2014 at 11:48 AM
    bw4706
    bw4706 [OP] Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Got a call from the Dealer today. They said they checked the Trans again, Same codes showed up and told me the fluid level was not exactly where it should be even though they just topped it off a few days earlier to fix the no up shifting problem. I more or less told them I think their out of their minds.
    I'm sure I'll be back there for a third time with the same problem. We'll see. Picking it up on Thursday.
  2. Jan 29, 2014 at 1:06 PM
    gearcruncher
    Canadain bumper technician
    There just buying time until you are out of warranty . Friggen stealerships
  3. Jan 29, 2014 at 1:52 PM
    sattwood3590
    sattwood3590 Member
    '13 PreRunner
    I have a 2013 DCSB, how can I check the fluid level myself? With so many posts about it being low, it concerns me.
  4. Jan 29, 2014 at 2:21 PM
    bw4706
    Illinois
    I think it has be checked at 113 deg. They use a laptop to check the level at the dealer. I have a warranty until 100 k and I'm at 53 k now. If it happens again they said they are out of options and will most likely have to put a new trans in. I hope that's true.
  5. Jan 29, 2014 at 2:23 PM
    bw4706
    Illinois
    They also told me they are seeing a lot of 2013 with low fluid levels in the trans. I would definitely get it checked to be safe.
  6. Jan 31, 2014 at 9:39 AM
    bw4706
    Illinois
    Well, I picked it up yesterday after the dealer said it was fine. Shifting problem happened again on the way to work today. Called Toyota and they said bring it back in and they will be putting a brand new transmission in it for me. Glad the warranty covers it !!!
  7. Feb 1, 2014 at 5:21 PM
    gearcruncher
    Glad to hear Toyota is going to cover the transmission . I doubt they will tell you why the trans failed but if I had to guess , 50 k of driving around low on fluid will do that to a transmission , Eventually something has to give .
  8. Feb 2, 2014 at 4:39 AM
    bw4706
    Illinois
    You're right, they wouldn't admit it was due to low fluid. All they say is They did everything they could to repair it and they'll just replace it.
  9. Feb 20, 2014 at 6:41 AM
    bw4706
    Illinois
    Picked up my truck two weeks ago after dealer installed a new transmission. Today it did the same thing with the new trans. While driving it downshifted and won't up shift.
    About two days ago, I took off from a stop and the truck felt like the rear end locked for a second or was binding. I was thinking axle wrap. (TSB on rear springs was never done if that matters ). After it downshifted today and couldn't up shift , The check engine light came on along with the traction control light.
    I guess it's back to the dealer today.
  10. Feb 20, 2014 at 8:59 AM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    WOW, that sucks big time.
    This is making me real nervous......
  11. Feb 20, 2014 at 9:23 AM
    bw4706
    Illinois
    I'm wondering if it's a problem with the traction control ?
  12. Mar 6, 2014 at 3:43 PM
    bw4706
    Illinois
    Still not fixed !!!
    This make the 5th. time back at the dealer for the same transmission problem.
    Downshifting from 5th. To 4th. And not being able to shift back into 5th.
    1st. - found fluid to be low by one and a half quarts- filled and cleared codes
    P0776 & P2714
    2nd. - cleared codes again & pressure tested and checked solenoids
    3rd. - installed new transmission . Paperwork says replaced due to internal failure.
    Shifting problem returned
    4th. - found corroded connector to trans - cleaned connector and cleared codes.
    Shifted fine for a week and a half. Problem returned
    Today, 5th. Time - dealer said they will replace the ECU and have me drive it, if the problem returns they will replace the entire wiring harness.
    When will it end ?
  13. Mar 6, 2014 at 3:55 PM
    taco52
    taco52 Well-Known Member
    01 SR5 v6 5speed 4x4
    Dang, sounds like a hassle. At least the dealer is working with you. Subd for outcome
  14. Mar 6, 2014 at 4:13 PM
    bw4706
    Illinois
    True. They have warrantied everything which I am thankful for. It just gets to be a pain thinking its fixed and it happen all over again.
  15. Mar 7, 2014 at 4:24 PM
    #35
    cpanther1995
    cpanther1995 Well-Known Member
    Charlotte
    Prerunner TRD Sport
    New to this form and to Tacomas. Bought my 1st Tacoma just a little over 2 weeks ago. 2013 Black TRD Sport V6 automatic 2WD less than 6k when purchased at Carmax.
    I noticed a slight rough shift and slight rough feel. My family and friends thought I was being a picky new truck guy, looking for problems. No "new" vehicle I've owned had any rough transmission feeling. Although it was slight, something seemed off. At a stoplight, the truck would feel like it wanted to move forward for a second. 3rd gear had a more pronounced ship than the others.
    The kicker was this Tuesday. I was coming off the interstate after getting around some very slow traffic. Went down the exit ramp and after coming to a stop I made my turn. The engine revved, but the truck did not move for a second. After that it took off slowly, and then drove normal.
    I joined this forum right after buying my Taco, but due to work I only lurked occasionally...mainly looking for info on running boards bed covers etc. Tuesday night after the slip, I went to this forum and found this thread.
    I took it back to CarMax the next day. I told them about Tacoma World and about this thread and how some 2013's appear to be shipping low on transmission fluid. They wasted no time and got it to a local Toyota dealer for diagnosis.
    Turns out mine was low on transmission fluid and they also found damage. They ordered a new transmission for me, and I'll have it back in a week.
  16. Mar 8, 2014 at 10:51 AM
    #36
    bw4706
    Illinois
    Welcome to TW.
    Good luck with the new trans. Hope that solves your problem.
  17. Mar 8, 2014 at 2:21 PM
    #37
    cpanther1995
    Charlotte
    Prerunner TRD Sport
    Thanks. Hope yours is solved too.
    I hope that Toyota will from now on make sure their transmissions are full of fluid before they go out to customers.
  18. Mar 14, 2014 at 3:56 AM
    #38
    bw4706
    Illinois
    Picked up my truck yesterday for the 5th. time. New computer and new wiring harness this time. Seems fine now but we'll see . Last time I had it for a week and a half before the shifting problems came back.
    New Trans , Computer & Wiring Harness. I'm hoping this is the end of my trans problems.
  19. Mar 14, 2014 at 2:49 PM
    #39
    cpanther1995
    Charlotte
    Prerunner TRD Sport
    Got mine back Wednesday. Since it had 5700 on it when I bought it, and there was some new doubt that CarMax changed the oil AND I hit 7300 miles...figured I needed to change the oil just to be safe.
    The transmission feels fine and shifts fine. At my oil change shop ( friends of our family) they made sure to show me the transmission and you could visually tell it is brand spanking new. The only thing the mechanic pointed out, there was a very small amount of moisture in the upper right corner of the pan. He asked me when this was done. When I told him I just got it back, he said this could be residual fluid. he detected no drips or leaks. Told me to take it to a car wash to clean the underbelly and keep an eye on it. If it continues to look even slightly wet there take it back.
    Installing my new used 14 OEM running boards bought from a Forum member ( thanks Jim!). We will have it on a lift and I'll be able to check it again.
  20. Mar 27, 2014 at 6:27 PM
    #40
    cpanther1995
    Charlotte
    Prerunner TRD Sport
    Update: the 1st week with the new transmission no problems. Last weekend I felt something. The best way I can describe it, a minor slip after I put it in drive. Very minor, not like the one I experienced before the transmission was replaced. Then this week, I felt the transmission down shift twice as I was slowing down. Normally with an automatic trans I don't feel it downshift.
    Everything I've experienced recently is minor, but I can't ignore it.
    Today after a sales call the truck had a very minor slip after going into drive. I'm going back to CarMax in the morning. They may have me go right to the Toyota dealership. If this is a brand new transmission, why would it do this?
    There have been no leaks. I've been checking daily.
    If these transmissions are prefilled, I wonder if they just slapped it on and didn't double check the fluid level?
