Anyone hear "creeking" in their cab?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vram74, Mar 31, 2016.
  1. Mar 31, 2016 at 1:56 PM
    vram74
    vram74 [OP] Well-Known Member
    05 Prerunner SR5
    Does anyone hear creeking inside their cab when driving over uneven surfaces? Like when straddling a curb or going over a speed bump? Sounds like something is flexing on my driver side, where the AC door and main door meet. I only seem to hear it on the driver side, so its bugging me a little.
  2. Mar 31, 2016 at 2:14 PM
    DiggerDan
    DiggerDan Well-Known Member
    Perhaps the creaking is your leaf springs?
    ODNAREM likes this.
  3. Mar 31, 2016 at 2:41 PM
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
    my creaking is the windshield. it pops and creaks when it goes from a cold morning to a warm day. annoying
    jmaack likes this.
  4. Mar 31, 2016 at 2:49 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    ODNAREM and File IFR like this.
  5. Mar 31, 2016 at 3:08 PM
    vram74
    05 Prerunner SR5
    I suppose it could be the driver side leaf spring. It sure sounds like its in the cab, though.
  6. Mar 31, 2016 at 4:16 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    My truck is not quiet.
  7. Mar 31, 2016 at 4:17 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    There was a thread before about cab creaks, and it was the weather stripping on the door. Not rubbing against the cab, but the inside of the hollow stripping rubbing on the interior walls of itself.
    Some people fixed it by spraying some lube inside one of the small holes in that piece of stripping.
    ODNAREM and EDDO like this.
  8. Mar 31, 2016 at 4:19 PM
    estrada_e234
    estrada_e234 Well-Known Member
    Edwin
    2015 PreRunner SR5 DCSB 4x2 MGM
    Tints n Derp
    Yup.. I have that annoying 'creeking' sound as well as the 'kazoo' sound when driving at high speeds. The only two complaints I have regarding my truck.. :/
  9. Mar 31, 2016 at 4:20 PM
    estrada_e234
    Edwin
    Tints n Derp
    Do you happen to have a link to this thread, preferably with the page number to the pictures of the "fix" :)
  10. Mar 31, 2016 at 4:23 PM
    T4RFTMFW
  11. Mar 31, 2016 at 4:30 PM
    vram74
    05 Prerunner SR5
    The best way I can describe my sound is the noise an old wooden boat would make rocking in the ocean. Does that make sense?
    I will lube the seals and see if it goes away :)
  12. Mar 31, 2016 at 4:31 PM
    T4RFTMFW
    Give them a good exterior cleaning (and the paint where they contact the cab) and see if it doesn't help, if not, try shooting some kind of silicone lube inside the weatherstripping and then see if that doesn't fix it.
    My guess is one of them will do the trick, or both.
  13. Mar 31, 2016 at 4:32 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Ditto.
  14. Mar 31, 2016 at 4:33 PM
    jmaack
    Justin
    Helena Alabama
    My kazoo noise was not the front at grille like many threads. It is in driver side weather stripping. I pulled it some and it is better.
  15. Mar 31, 2016 at 4:39 PM
    estrada_e234
    Edwin
    Tints n Derp
    Right, I've read other threads and narrowed it down to the sealing areas along the doors.
    So if that's causing my 'kazoo' type noise and the seals are causing the 'creaking' noise, then both issues are coming from the same areas right? All the rubber surrounding material around my doors.. I'm thinking I'll try to clean up the areas around my doors this weekend and wipe down anything that has rubber with my 303 protectant and see how that works.
  16. Mar 31, 2016 at 4:41 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    My door seals creak like crazy. Clean with silicone spray lubricant about once a month. You'll be reminded if you forget.
  17. Apr 3, 2016 at 7:28 AM
    vram74
    05 Prerunner SR5
    Wiped down with silicone as suggested and all better now. Thanks guys!
    EDDO likes this.
  18. Sep 5, 2016 at 3:02 PM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I'm fairly certain that my creaking noise is coming from the leaf springs...up a curb, over a bump, and when I shake the truck from the outside. Any idea how to fix it?
    Later.
