Anyone here successfully converted the AC compressor to an onboard air system?
Discussion in '1st Gen. Tacomas (1995-2004)' started by crackedmirror, Jul 5, 2021.
  1. Jul 5, 2021 at 8:59 AM
    crackedmirror
    crackedmirror [OP] Well-Known Member
  2. Jul 5, 2021 at 3:51 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Ac compressors are not made to pump air . The incoming Air would need to have so much filtration to keep clean and dry.
    The ones I removed worked like crap.That is why the got thrown out.
    Want Low bucks find a Air compressor off a Truck with Air brakes in a yard block off plate oil lines brackets your good to go.
    Big enough tank a 3/4" impact works great
    crackedmirror[OP] likes this.
  3. Jul 5, 2021 at 4:28 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    You would need oil in the air to keep the compressor lubed, so not gonna work. Better off adding a separate compressor (electric) or the full size guys have an old A/C compressor that has separate crankcase oil that they use, maybe you could add that to the truck with a lot of bracket work and a longer belt? Lots of work for air haha.
