Anyone here used high-temp gasket maker instead of OEM specified pre-made gasket in a critical area?
Discussion in 'Technical Chat' started by crackedmirror, May 3, 2021.
  1. May 3, 2021 at 6:35 PM
    crackedmirror
    crackedmirror [OP] Well-Known Member
    Thinking of replacing valve cover gasket with with high temp gasket maker material.
  2. May 3, 2021 at 7:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't recommend it, it likely won't seal properly and you can't use gasket maker on the spark plug tube seals. Get a Fel-Pro set or OEM, valve cover gaskets are relatively inexpensive.
  3. May 3, 2021 at 7:57 PM
    Bishop84
    Bishop84 Well-Known Member
    No way. It would take a fuck ton and would be awful to clean if it leaks.
    Toyotas aren't chevy small blocks we can't do stuff like that.
    6 gearT444E and Dm93 like this.
