Anyone in AZ need OEM 4x4 leaf-springs... free!?
Discussion in 'Arizona' started by AriZonaD54, Jan 3, 2010.
  1. Jan 3, 2010 at 9:34 AM
    AriZonaD54
    AriZonaD54 [OP] BANNED in 49 states...
    Andrew
    Valley of the Sun
    AZers... I've got a set of leaf-springs (only 10,000 miles) that I pulled from my 2008 back in August. I am giving these away to anyone who needs them.
    Please do not take these if you already have a set and are just going to "garage" these. I'd like these to go to someone who needs them or some charity case. Thanks in advance. I can bring them to the next Phoenix area GTG or can meet you somewhere. :cool:
    Too lazy to post pics. These are the non-TSB springs but were not sagging when they were removed for a lift application.
  2. Jan 3, 2010 at 8:19 PM
    dubya05
    dubya05 0O0O0O0O
    El Mirage, Az
    06 PreRunner SR5 TRD
    fog light mod, mag-light mod, secondary air filter delete.
    hmmmm are they any different in load capacity? aka, if i load my bed with my quad with these and with out these will these make the bed sit any higher?
  3. Jan 3, 2010 at 8:25 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    nope
  4. Jan 3, 2010 at 8:27 PM
    TacoNut
    Adam
    Denver, Co
    Well, it could be made to work. But would take too much fabrication than I think you'd like ;)
  5. Jan 3, 2010 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Meh....Cut the front mounts, and move them back a bit.....Weld them back on......;)
  6. Jan 3, 2010 at 8:38 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Unsure.
  7. Jan 3, 2010 at 8:40 PM
    TacoNut
    Adam
    Denver, Co
    Should only take 2 hours or so... up to you!;)
  8. Jan 3, 2010 at 8:42 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Connor.. they're yours if you wanna give it a shot. Lemme know.
  9. Jan 3, 2010 at 8:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont think so Bud. BUT....If you buy me a new welder, Sure! :)
    Yeah....ALso have to relocate the center of the springs to accomodate the first gen body, and such....Maybe 2.25 hours.....:p
  10. Jan 3, 2010 at 8:54 PM
    TacoNut
    Adam
    Denver, Co
    Not to mention extend brake lines. and depending on how much lift fix the driveshaft angle.
    buy me a more powerful welder and it'll be done....
    Some how I don't really trust the weight of a whole truck to 110V MIG
  11. Jan 4, 2010 at 8:47 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Are these the 4 pack or 3 pack? I don't need them but that will help with the question of load capacity.
  12. Jan 4, 2010 at 8:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "NON- TSB" = 3 leaf.
  13. Jan 4, 2010 at 9:03 AM
    Masada
    Taylor
    Laveen, AZ
    So that would answer this question...
    No it has no extra load capacity than the one you have now.
  14. Jan 4, 2010 at 10:00 AM
    dubya05
    dubya05 0O0O0O0O
    El Mirage, Az
    ^ thank you masada. that was the answer that I was looking for. Ill let these go onto someone else.
  15. Feb 2, 2011 at 1:41 PM
    dalethemail
    dalethemail Member
    tacoma
    spacer lift 3 in.
    will they work for a 98 tacoma trd one of mine broke last week.mine is a 3-pac with add a leaf on the bottom of the leaf.
  16. Feb 2, 2011 at 1:48 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    holy thread revival
  17. Feb 2, 2011 at 1:52 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    When I had my 98' I broke 1 and took it to these guys...
    Dunbar Spring 718 W. Jefferson St. Phoenix, AZ 85007 phone - 602.258.6901
    They did good work and had me up and running in a day or so...
  18. Feb 2, 2011 at 2:50 PM
    Ninja
    Ninja The Lone Wolf of TW!
    Charles
    Arizona
    '04 Prerunner SR5 Reg. Cab
    Today is Groundhog Day. :D
