Anyone in NY???
Discussion in 'North East' started by ComaChic, Jun 3, 2009.
  1. Sep 18, 2019 at 2:26 PM
    #2921
    JackCrank
    JackCrank Well-Known Member
    Jack
    Brooklyn
    2006 4x4/2.7L/5MT/Access Cab/Desert Sand Mica
    Bone stock for now...
    Brooklyn NY
    Bastek and Tac0Man like this.
  2. Sep 18, 2019 at 2:26 PM
    #2922
    JackCrank
    Jack
    Brooklyn
    Whoops, missed a few pages...
    Bastek likes this.
  3. Sep 18, 2019 at 4:50 PM
    #2923
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    :wave:
    Staten Island
    LOL
  4. Sep 20, 2019 at 4:44 AM
    #2924
    Frikki
    Frikki New Member
    Does anybody know of any junkyards in a ~150mile radius around NYC that might have a 1st gen I could pick apart for bits and bobs?
  5. Sep 20, 2019 at 7:28 AM
    #2925
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
  6. Sep 20, 2019 at 9:02 AM
    #2926
    JackCrank
    Jack
    Brooklyn
    What's good my guy?
  7. Sep 20, 2019 at 9:07 AM
    #2927
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    All is well bud. Enjoying the weather!
  8. Sep 23, 2019 at 8:00 AM
    #2928
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    ok so here the deal,
    i want to change my ATF fluid with drain and fill.
    was curious if anyone remotely local has done it for there 2nd gen at all and would be willing to "coach" me through it so i can do the remaining changes alone.
    im mechanically inclined and do all my own work but def dont wanna f*ck up the trans in anyway
    ithaca, rochester, buffalo or the around areas?
  9. Sep 23, 2019 at 8:42 AM
    #2929
    Dogg23
    Dogg23 I like big tires
    Nate
    Rochester, NY
    16 DC OR MT 10 Sport MT & 16 4R Trail
    Big tires
    This should help. I’m a MT guy so I haven’t done it on the taco.
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
  10. Sep 23, 2019 at 8:43 AM
    #2930
    12taco12
    rochester NY
    2012 TX Pro
  11. Sep 24, 2019 at 5:55 AM
    #2931
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Practice getting into temp check mode. If you can do that, then you are set and wont need supervision.
  12. Sep 24, 2019 at 6:25 AM
    #2932
    12taco12
    rochester NY
    2012 TX Pro
    what can i fuck up if that goes awry
    Bastek likes this.
  13. Sep 24, 2019 at 6:37 AM
    #2933
    mightytacoman
    Kel
    4.5L 1grfe
    Can't Fuck up anything by just going into temp check mode. For filling, just remember it has to be running and to plug it before you shut it off.
    Bastek likes this.
  14. Sep 24, 2019 at 6:42 AM
    #2934
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Solid advice! I screwed that up when I was checking my fluid, and before I realized it, it leaked out about 1/2 quart
  15. Sep 24, 2019 at 11:17 AM
    #2935
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I think someone reported they jumped the wrong pins and immediately saw smoke coming out of the dash. Idk
    Bastek likes this.
  16. Sep 24, 2019 at 1:16 PM
    #2936
    12taco12
    rochester NY
    2012 TX Pro
    see this shit here is what i mean ha
  17. Sep 24, 2019 at 1:30 PM
    #2937
    spitdog
    The sticky with the post by fortec is actually pretty good. Pretty easy to follow it you take your time.
  18. Sep 24, 2019 at 11:57 PM
    #2938
    B.lynch137
    B.lynch137 New Member
    I’m in Brunswick.
    lynyrd3 and gabbo2112 like this.
  19. Sep 25, 2019 at 3:41 AM
    #2939
    rcracin
    rcracin Well-Known Member
    Anyone in NYC going to Vermont Overland? I'm heading up tomorrow.
    lynyrd3 likes this.
  20. Sep 25, 2019 at 9:11 PM
    #2940
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    I’m by Albany and planning to do mine sometime before winter. You have an open invite to come join me.
