Anyone in NY???
Discussion in 'North East' started by ComaChic, Jun 3, 2009.
  1. Oct 7, 2019 at 1:31 PM
    #3001
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
    A bunch of us CT peeps got together at another member's house, who "hooks us up". We did it a week or two ago already.
  2. Oct 7, 2019 at 1:31 PM
    #3002
    DrFunker
    DrFunker Well-Known Member
    Never too early. :D
  3. Oct 7, 2019 at 1:34 PM
    #3003
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Just purchased 5 gallons. Takes two or so to do our trucks right
    lynyrd3 and Sasquatchtaco like this.
  4. Oct 7, 2019 at 1:35 PM
    #3004
    DrFunker
    I don't think it would take 2 gallons. Maybe if you go on thick.
    @surfandturf or @BadDNA would know.
  5. Oct 7, 2019 at 1:36 PM
    #3005
    mightytacoman
    Kel
    4.5L 1grfe
    I put it on thick and have done it several times over the years.
  6. Oct 7, 2019 at 1:43 PM
    #3006
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Oh man, I only got one gallon. I might have to look locally for another.
    lynyrd3 likes this.
  7. Oct 7, 2019 at 1:46 PM
    #3007
    mightytacoman
    Kel
    4.5L 1grfe
    If you got one, you can try to it. Pending you're thickness preference it would work. When you take it to shop they usually put it on incredibly thin and use less than a gallon. Hence why I started doing it myself
  8. Oct 7, 2019 at 1:46 PM
    #3008
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    Napa seems to have it near me
    But I'm not doing it until I get a new frame :fingerscrossed:
  9. Oct 7, 2019 at 1:52 PM
    #3009
    Sasquatchtaco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    I'm definitely going to get another gallon. I'll check the local napa. Thank you, gents! :hattip:
    PS. Toyota won't replace my frame so I've gotta improvise :D
    mightytacoman[QUOTED] likes this.
  10. Oct 7, 2019 at 2:32 PM
    #3010
    Twins09
    Twins09 Well-Known Member
    Dave
    Dutchess County, NY
    2019 MGM TRD Sport, 02 WS6 vert
    Vent visor, hood protector, door sill protector, next up eibach,SCS Ray 10s to be installed next week...
    Im using woolwax its basically the same stuff. They say its a little thicker and less prone to wash off. I was told 6 aerosol cans would be enough for my truck. I ordered it from their website came in four days. Ill see how it works and imhow much i use
  11. Oct 7, 2019 at 2:39 PM
    #3011
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    4-5 cans is what I buy of fluid film for my truck. I spray until I get to the point of “anything more and it’s dripping off”. Lowe’s sells fluid film cans BTW.
    Rexfordian13 likes this.
  12. Oct 7, 2019 at 2:55 PM
    #3012
    mightytacoman
    Kel
    4.5L 1grfe
  13. Oct 7, 2019 at 2:56 PM
    #3013
    pmstoy10
    hudson valley, ny
    What year is yours? I can't remember. You've gotta be in the running at some point.
  14. Oct 7, 2019 at 3:13 PM
    #3014
    Sasquatchtaco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    09.. someone told me to stop babying it :D
    pmstoy10[QUOTED] likes this.
  15. Oct 7, 2019 at 3:34 PM
    #3015
    gabbo2112
    gabbo2112 Well-Known Member
    New York
    2020 TRD Off Road
    I sprayed my new frame last November, it was a vegetable based oil and was awesome. I did it at my friends shop and am heading north to do it again in two weeks. I don’t think there could be a wrong time to protect your truck child! I have however used fluid film to touch up the jack spots from tire changes etc. Awesome product too.39D4C3DF-6B29-428E-BBD9-C08316C5F2C6.jpg
    Sasquatchtaco[QUOTED] likes this.
  16. Oct 7, 2019 at 3:39 PM
    #3016
    pmstoy10
    hudson valley, ny
    I agree with them...
    I mean me:spy:
  17. Oct 7, 2019 at 4:29 PM
    #3017
    lynyrd3
    Bill
    East Central Upstate NY
    Where did you have your frame inspection? Go to Johnston’s Toyota in Middletown NY . That’s the second place I went and they failed it after another dealer wanted to just coat it .
  18. Oct 7, 2019 at 5:35 PM
    #3018
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Hey @Sasquatchtaco , your truck made the hunter mtn instagram.......sorta. it's a pic of the green jeep, but your in the background.
  19. Oct 7, 2019 at 5:44 PM
    #3019
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I think I've been putting it on pretty generously and I only go through about 2 qts per truck.
    DrFunker[QUOTED] likes this.
  20. Oct 7, 2019 at 6:34 PM
    #3020
    pmstoy10
    hudson valley, ny
    My understanding is that Prestige tries pretty hard to find a failure spot as well....or so I've been told
    lynyrd3[QUOTED] likes this.
