Anyone in Texas that can install and tune a CB? Or anyone that can tell me how?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JstanTaco7, Oct 8, 2021.
  1. Oct 8, 2021 at 6:31 AM
    JstanTaco7
    JstanTaco7 [OP] Well-Known Member
    Jackson
    2014 Texas Edition Prerunner SR5
    New grille, double power horns, new head unit, taillights with startup animation, headlights
    I have been trying to install a cb radio for a few weeks and I know I have all the necessary equipment, but I can't find a spot to ground the antenna and I'm not sure how to tune it. Has anyone had this problem and figured it out?
  2. Oct 8, 2021 at 7:02 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Ground it on the chassis somewhere with braided strapping.
    Tuning wise you will need an SWR meter. Depending on your antenna you may need to trim it for optimal SWR on your most frequented channels. Firestiks are a bit easier as they have the tuning tip.
    There are myriad of good resources online on how to accomplish all of this
  3. Oct 8, 2021 at 7:42 AM
    JstanTaco7
    Jackson
    Okay thanks man, I have an swr installed in my radio but I couldn't decide where to ground it. Final question, what is braided strapping? And where is it, thanks
  4. Oct 8, 2021 at 9:29 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Example: https://www.dxhamradiosupply.com/Grounding-Braid-s/2170.htm Premade:https://www.dxhamradiosupply.com/Tubular-Tinned-Grounding-Braid-s/1843.htm
    See what ham clubs are in your area and one of the geeky old guys in jorts, dark socks and Crocs will almost certainly chime in about having every piece of test equipment since the 1950s and how he'll be happy to help you. Of course he'll want to make sure you have all of your licenses, swear some allegiance to the FCC and show you all of his QSL cards.
    :anonymous:
    ETA- You'd probably be better off installing a GMRS radio these days unless your club specifically still uses CBs.
    deanosaurus likes this.
  5. Oct 8, 2021 at 9:40 AM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Damn! This is what I’m wearing right now!
    Icarus II likes this.
  6. Oct 8, 2021 at 9:52 AM
    Bajatacoma
    SC
    I've got the insulated version of those for hunting camp. :rofl: My regular ones are plain tan; I started wearing them back around '08 working oil rigs. They're comfortable on the hard decks (industrial vinyl on steel) and quick and easy to slip off under your desk or when you need to put your boots on to go outside.
  7. Oct 8, 2021 at 4:23 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Also be aware you have a ground plane antenna, for use on metal body vehicles and non ground plane ones that are used on fiberglass and other non metallic surfaces. Using the wrong one can create nightmares. 40 years of electronic communication work for bonafides.
