Anyone install a extra loud horn in their taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Teegs, Jul 24, 2019.
  1. Jul 26, 2019 at 2:55 PM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    '22 MGM DCLB TRD OR
    Fairly easy to install. If I recall correctly, it's power and ground to the control box; pos and neg to a 100W speaker and a pair of wires running to a momentary switch. If you get the version with a PA function then it has a seperate 3 pin connector specifically for that.
    ruffridha9 likes this.
  2. Jul 26, 2019 at 7:29 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Thanks, I wouldn’t be getting the pa just the horn solo
    Thats how I’d like it to function- via horn button on steering wheel. So when you say ran that back to the amp, I’m guessing you tapped/extended the wire for the horn from the grill to the amp in the cabin. Question, was there not access to the same wire in the cabin instead of running it from the grill or would that not work?
    So the comment about needing another battery was more of a joke because of how much power it requires or is there serious concern with a single stock battery?
  3. Jul 26, 2019 at 8:02 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    You could get a horn from a junk yard and mount it next to the factory horn. Should be cheap and make it twice as loud. Did that on my Wife's Camry because she was always getting cut off. The air horn videos above are pretty cool and may justify the extra cost.
  4. Mar 28, 2020 at 6:20 PM
    ruffridha9
    ruffridha9 Well-Known Member
    West Coast
    2012 Tacoma base
    stock ish
    @DaBigDogg @mwc273 @Gunshot-6A
    sup boys,
    I’ve been sitting on a pap112 amp install after failing my first go round.
    I was able to establish some sort of sqwelch to the 100w speaker when testing the pa function and pressing the button, but no audio or power horn function with the momentary switch I have.
    I did some shuffling of wires and got the same result.
    is a relay not required to run this setup?
    I see the instructions have an optional horn ring control using a relay, but I’m looking to run separate from factory horn.
    For the life of me I cannot figure this shit out. not very familiar with the electric field, but I’ve managed to wire up multiple sets of led lights and clean them up with a fuse block/ circuit breaker so I’d like to think I have a basic understanding.
    any tips or guidance is much appreciated gents :hattip:.
    thanks in advance
    Gunshot-6A likes this.
  5. Mar 28, 2020 at 6:35 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    If youre referring to sharptone install, the oem horns ground out through the mounting tabs. For the sharptones, i just ran a wire from the ground tab to a ring connector that wraps around the mounting bolt.
    Have you tested the switch? Ive had some that are DOA out of the package. Should be 12v in and 12v out
    ruffridha9[QUOTED] likes this.
  6. Mar 28, 2020 at 6:58 PM
    ruffridha9
    West Coast
    2012 Tacoma base
    stock ish
    Was referring to a separate air horn wiring.
    you are right, thanks for the testing reminder. I will definitely do that to ensure the switch is getting juice.
    I thought you had a whelen airhorn,
    But just stalked your build page and saw you have a Carson setup. Just searched that diagram, holy shit. I'm struggling with three wires.
    Did you integrate this to your factory horn with a flip switch, or run an entirely different line with momentary switch ?
    If different, did you run a relay?
    Gunshot-6A[QUOTED] likes this.
  7. Mar 28, 2020 at 7:25 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    The OEM horn has been scientifically engineered since freakin WW2 to cut through traffic noise...it maintains that delicate balance between loud enough to do the job, yet not loud enough to immediately send someone into cardiac arrest. It passes the DOT qualifications. More is not always better, and people have already thought this through.
    Chew likes this.
  8. Mar 28, 2020 at 7:27 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I need a horn with 2 settings- Regular, and Brown Note.
    ruffridha9 and stun gun[QUOTED] like this.
  9. Mar 28, 2020 at 7:30 PM
    Cruisernate
    Cruisernate Member
    Nate
    Alberta, Canada
    2017 Tacoma TRD Off-Road DCSB and 1986 HJ60 Land Cruiser
    I had an OBA set up for my lockers on my 13 Tacoma so i used a set of 3 chime train horns and they sounded awesome... mostly cause i like trains, not so much for honking at people.
  10. Mar 28, 2020 at 7:37 PM
    robie_0n3
    robie_0n3 Well-Known Member
    David
    Scott AFB, IL
    2018 Tacoma TRD Off Road
    I installed a pair of Hella Supertones and a pair of Hella Sharptones... Ended up with a very Euro-sounding horn. It sounds exactly like my 2018 VW Atlas, but significantly louder.
    Comet'spop likes this.
  11. Mar 28, 2020 at 9:27 PM
    Gunshot-6A
    Conner
    Everett, WA
    The Carson runs a 4 tone setup of a separate panel. All wires run direct from its control box so it is the relay essentially. Wiring isnt that bad if you just follow the diagram. Electrical is something that just comes easy me. :notsure:
    In general though, a relay should be used for something like a airhorn.
  12. Mar 28, 2020 at 9:29 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
  13. Mar 28, 2020 at 9:48 PM
    ruffridha9
    West Coast
    2012 Tacoma base
    stock ish
    got it.
    Hoping to get it this second time around.
    Thanks man
  14. Mar 29, 2020 at 4:03 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    The horn on my trd sport is pretty loud. What trim level do you have?
    Tullie D likes this.
  15. Mar 29, 2020 at 4:45 AM
    #35
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    This post just made me realize something. I've never actually used the horn in my truck(16'- owned it since new).
    Being a firefighter, I've always wanted to put in a set of the Grover Stuttertones in my truck(that is the classic fire truck airhorn).
    CBChief, ruffridha9 and Gunshot-6A like this.
  16. Mar 29, 2020 at 4:54 AM
    #36
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    I've got a 2019 SR5, and my horn seems decent. Good enough for my needs.
  17. Mar 29, 2020 at 6:23 AM
    #37
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    Yes. I installed a Whelen PAP. It’s quite loud and people definitely notice it. The PA is pretty awesome as well.
    The Whelen took the place of the stock horns. I press the center if the steering wheel and you get the Whelen.
    As far as horrid drivers, yeah, the PA has been helpful more than once.
    https://www.youtube.com/embed/ab9jPZZ9gh0
  18. Mar 29, 2020 at 7:10 AM
    #38
    Gunshot-6A
    Conner
    Everett, WA
    Thatd get some attention
  19. Mar 29, 2020 at 7:11 AM
    #39
    Gunshot-6A
    Conner
    Everett, WA
    You think that, but the sharptones are quite a bit louder. 70% I think. Once you hear them, you realize what a horn should be
    robie_0n3 likes this.
  20. Mar 29, 2020 at 9:44 AM
    #40
    robie_0n3
    David
    Scott AFB, IL
    Just to throw numbers out there, the OEM horns on my TRDOR are stamped 100 db. Hella Supertones are 118 db and Hella Sharptones are 114 db.
