Anyone install a Grill Craft without cutting OEM?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Outlaw, Jan 29, 2010.
  1. Jan 29, 2010 at 11:20 AM
    Outlaw
    Outlaw [OP] Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    I was just wondering if anyone has installed a Grill Craft Upper Grill without cutting the factory grill? IS there a way to attach it right over the top of the stock grill?
    Or are there any grills where you can do this?
    thanks in advance
  2. Jan 29, 2010 at 11:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It can be installed without cutting.
  3. Jan 29, 2010 at 11:27 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Of course I trust your knowledge Chris, but can you explain how? or get me instructions or point me to who would know?
    Reason I was asking is, I was going to get in on the Group Buy, and truckalter said he had never installed a GC on a Tacoma.
  4. Jan 29, 2010 at 11:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont have instructions. The only reason people cut out the center part, is because it is visible thru the grill.
  5. Jan 29, 2010 at 11:30 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    its a much cleaner look :D by cutting out the center
  6. Jan 29, 2010 at 11:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Bingo!
  7. Jan 29, 2010 at 11:32 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    yeah yeah i know i know.
    but how can you be sure without ever seeing it done?
    I want the front emblem to still be there.
  8. Jan 29, 2010 at 11:34 AM
    David Tarantino
    N.J.
    08 tacoma
  9. Jan 29, 2010 at 11:38 AM
    TurfTaco
    TurfTaco Is there a long john silvers on the island?
    URE
    07 Deer Collector
    285/75-16 BFG KM1's, AVS vent visors, AVS hood shield, pioneer avic F900BT, pac steering wheel control adapter, Boyo rearview camera, pac ipod interface, tinted windows, Toytec 1.5 AAL, Bistein 5100s (front set to .85) Eibach coils, Black headlights, grillcraft black billet insert, N-fab light bar, 4 Hella FF700 lights & color matched grille, Sockmonkey bedside decals. 16x8 MT sidebiters, Weathertechs, Fabtech spare carrier.
    If you are hesitant about installing the grille...don't be. It is very easy to cut out the insert and screw in the grillcraft. You will need a rotary tool, like a dremel tool and need to use a rotary cutting bit (chris4x4 advised me to this and it made the work quick and easy). WEAR EYE PROTECTION! Just tape up the grille surround so you don't scratch it and take your time. When you get your grillcraft you can lay it against your grille and you will see what you need to cut out. It took me a little longer than what others claim it took them but I am a perfectionist and went slow. There are 6 little screws to install (2 top, 2 bottom, 2 side). Easy and worth it. Do it yourself and it will make you feel proud. I also did the horn relocate which took about 25 minutes and it looks much better.
  10. Jan 29, 2010 at 11:41 AM
    TurfTaco
    URE
    07 Deer Collector
    Oh and becareful when you remove the stock grille. The pushpins and top screws are no problem, but those damn clips at the bottom are a bitch. I broke one taking it off and cussed trying to get it back on. You can get extra clips from toyota for 2 bucks and change. And paint behind the grill flat black for a clean look.
  11. Jan 29, 2010 at 11:56 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Thanks guys.
    Still not the info Im looking for though.
    i guess I will just wait and see if someone has done this or not.
    Starting to think its not possible...
  12. Jan 29, 2010 at 12:03 PM
    dman597
    dman597 Well-Known Member
    Doug
    maryland
    2012 DC 4X4 SPORT w/Tow
    6" Pro Comp Lift,295-75-R17,access rollup,Tint,front hitch,nfab step bars
    If you so to there website there instructions tell you that you can install wit or without.
    PS: does anyone know what it would look like if you paint it the same color as the truck?
    Dano_Nsb45 likes this.
  13. Jan 29, 2010 at 12:05 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    U can put it right over your stock grill! No cutting required! However u will be looking at the T emblem threw the mesh! Hope that helps?
  14. Jan 29, 2010 at 12:06 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I've seen it in person where the person did not cut the stock grill. It looked good but not as good as if you were to cut the stock grill. You can take the emblem off the stock grill and just 3M tape it onto the GC grill afterwards. Not hard to do at all.;)
  15. Jan 29, 2010 at 12:11 PM
    jaws revenge
    jaws revenge Well-Known Member
    i had a grill that i installed on my 09 without cutting. i since sold the grill though and don't have any pics.
    the reason i didn't like it without cutting is because of the argent oem grill (which i think started in 09). the prior years were black. a black background or painting or cutting, i think would look better.
  16. Jan 29, 2010 at 12:14 PM
    Artax
    Artax Member
    Davenport, IA
    07 Sport
  17. Jan 29, 2010 at 12:37 PM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    Which grill did you have?
    It would be easier to paint that cut.
  18. Jan 29, 2010 at 12:43 PM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    I found this picture on Grillcrafts website showing the center no cut out, but using a chrome grill( i prefer black) But it doesnt give intructions on how to do it without cutting it, and it shows that you remove the emblem, so Im guessing you would have to cut the new grill for the emblem to show through.
    thanks for your help everyone!
  19. Jan 29, 2010 at 12:45 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    You can leave the stock and emblem if you want, but it looks like ass. You might as well get a Lund screen. Members have done it before, I just can find the pics. Maybe over on TN. The members eventually cut out the stock grille cross bars.
  20. Jan 29, 2010 at 12:45 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    Or you can use a reciprocating saw;)
