Anyone install a scanguage with blendmount? In a 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by little_mule, Feb 27, 2016.
  1. Feb 27, 2016 at 9:27 AM
    little_mule
    little_mule [OP] Rock of the Marne
    Texas panhandle
    2016 sr5 dcsb v6 at
    So i have a pretty neat scanguage with the rearview mirror mount. It's mounted and all that but i am wondering if anyone has done this yet? Any pointers for running the wiring under the A-pillar and dash? Thanks, this thing is really cool!!
    Edit: i meant specifically on the 3rd gen, 2016 dash and a-pillars.
  2. Feb 27, 2016 at 9:41 AM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    On my 15 I ran the wire up the left pillar. and under the headliner. Was a clean install. also ran the Garmin Power up the opposite pillar. (I used it mostly for the trip features and Water temp.) I have an ELM in the truck and Torque OBD Pro should I need to monitor engine functions. Also have a portable code reader.
    On my 16 I don't need the ScanGuage II, There is enough information available. So I moved the ScanGauge to the MX5.
    little_mule[OP] likes this.
  3. Feb 27, 2016 at 5:29 PM
    wudbuchr
    wudbuchr Well-Known Member
    Linnie
    Lexington, TN
    2016 (7128A) BBP 4x2 - TRD Sport Access Cab
    * Clear Bra (full front) * BBP (8T0) Side Body Molding * Tinted Windows with AWS window shades * Romik Running Boards * Color matched Undercover Lux bed cap and BedRug bed liner * MobTown Locking bed storage doors, Tailgate skin and cap * Chrome Tailgate Script lettering * G-Tec Fab Door Sill Protectors and OEM Mud Guards * Fumoto Valve * ScanGauge-II * LED Interior, Stop, tail, Bed, OPT7 LED H11 low beam and fog lights * WeatherTech floor mats * Clazzio seat Covers * Removed jump-seats & rear seat-belts * Sound deadened back wall, rear posts, rear doors and front doors with a layer of RAAMmat, a layer of Ensolite, and a layer of EzCool * Insulated the roof with two layers of EzCool * GT series Image Dynamics speakers (6x9 fronts, 6.5 rears) * Audio Control DQ-61 DSP, 5-channel amplifier and sub woofer. * Redline Tuning Quick Lift Elite hood struts * Thinkware F770 (Dual) Dashcam with Cellink Battery B * Lexus SmartKey Transmitter and Emergency Key
    I mounted mine in the left corner of the windshield (leading edge of the headliner) using two measuring tape belt clips and two screws. The screws were in my case when I sent it in for an update and they were still there when I got it back. This location places it in ideal view of the driver, while not interfering with your field of vision. I trucked the cable under the headliner and behind the top of the alpha pillar covering. I then tucked it behind the rear vertical edge of the alpha pillar covering, between it and the weatherstripping. If you pull the "airbag" plate out (it is hinged on the rear edge - use a small screwdriver or a door panel tool to pry up the front edge), you will find a 10MM bolt that when removed exposes the air bag and other wiring. I chose to run my cable on the back, keeping clear of all other wiring and the airbag. Excess cable can be stored behind the drivers side kick plate. You can find inexpensive small (6 feet) measuring tapes at Tractor Supply for under $5.00. The clips make removal/installation very easy.
  4. Feb 28, 2016 at 7:46 PM
    little_mule
    Texas panhandle
    2016 sr5 dcsb v6 at
    thanks wudbuchr!! appreciate the input
  5. Feb 28, 2016 at 11:06 PM
    wudbuchr
    Linnie
    Lexington, TN
    Any time, that's what TW is for - Taco owners helping Taco owners. Glad I could help.
