Anyone install Pioneer TS-G650 on an 07 Tacoma REAR doors?
Discussion in 'Audio & Video' started by 1914, Mar 26, 2022.
  1. Mar 26, 2022 at 12:24 PM
    1914 [OP] Member
    I bought a set of TS-G650 speakers for the rear door of my double cab thinking I could make it work, but now as I'm installing them I'm getting a bit nervous they may interfere with the window or collide with the door panel like some have warned as a possibility.
    I have not been able to find a solution though aside from getting the correct size speakers.
    Has anyone tried to make these work and was successful? I'm interested in hearing what you did.
    I'm using the Metra 82-8148 and also would consider cutting the OEM speakers out of their brackets and re-purpose those if I thought it would work, but it looks like I would run into the same problem. Btw, that method worked perfectly fine on my front tweeters. Added a few dabs of hot glue and it was in there solid if anyone considered it.
  2. Mar 26, 2022 at 1:59 PM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Check Crutchfield they sell that speaker. Put your truck info in and see if they fit your truck.
