Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 26, 2025 at 1:34 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Printed a couple press fit inserts, threaded them and done deal.
    I had no idea the DX4C was capable of this kind of mixing.
    Still fine tuning the rates and stuff. It's an entirely different toy now.:D
  2. Jan 26, 2025 at 1:50 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    @Kwikvette
    @odomandr
    So, I found what's binding. Been tearing this thing down, putting it together, checking everything. I'm an expert at assembling this thing now as I've done it a dozen times now :rofl: Tore the trans apart, both axles. Everything is fine. Put it back together and discovered it's something to do with my front left wheel hex. With that tire/wheel off its fine. As soon as I put the wheel and tire on she binds. I'll dig into it later this evening. Gotta go to my friends kids birthday party
    Deathbysnusnu, odomandr and Kwikvette like this.
  3. Jan 26, 2025 at 1:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shoot, least you found out.
    I found my wheel binding as well when my axles first came in. It only occurred when I installed the +1 hexes from LGRP, but the instant I removed it and reinstalled the Meus hexes (with o-ring) it spun freely.
    So I've got extra hexes now just sitting here :rofl:
  4. Jan 26, 2025 at 2:33 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Just came across an old photo I took about a decade ago on a powerplant I was working on. Wonder what scale truck uses this servo horn.
  5. Jan 26, 2025 at 4:08 PM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    Great seeing everyone's projects.
    I finally got around to getting my 1/6 SBR back to a running state after exploding the original rear axle housing on a rock at near full speed on 8S.
    New and improved aluminum housing.
    Aluminum rear trailing arms, links, and front upper/lower control arms will be the next upgrade this summer
  6. Jan 26, 2025 at 4:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I had at one point a 4ws TLT based custom crawler with a custom modded Traxxas 3 channel controller (with crystals lol). It was awesome as a dedicated slowed crawler rig, but the extra moving parts on the rear axle took a beating and servos weren't nearly what they are today so I ended up going back to just front steering on that rig.
    I have been tempted to do 4ws on my current Capra axle custom build but I like the lack of complexity and [extra] robustness
    Edit - how is parts availability on those old axles n teams?
    Deathbysnusnu[QUOTED] likes this.
  7. Jan 26, 2025 at 4:26 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Just in the last few hours I have noticed the added strain of 4ws. Links started popping off that never did before. I added washers to the outside of the balls and they are captured now. Let's see what breaks next. :D
    nd4spdbh[QUOTED] likes this.
  8. Jan 26, 2025 at 7:02 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Last pics of these. Found a strip of light foam for stuffing into AC window units and it worked well for the tires. No foams the sidewalls were folding over. Cleaned up the wiring. Ditched the large 2s battery on top in favor of a 3s 900mah that sits between the upper shock mounts. Traction boards on top for when needed.
    tossup between this body.
    and the Deadbolt body that came with the SCX10.
    I didn't think I would like the smaller rubber, but they really grew on me. I think bigger tires with 4ws would start breaking things. As is, it brings back some challenge and is fun to drive again. These grip like a fat kid with a bag of candy.
    Breathed new life into two older neglected models. Ironically, the AX10 had the bigger tires and the UTB/SCX10 had the that same smaller size in a 1.9 wheel.
  9. Jan 26, 2025 at 7:31 PM
    nd4spdbh
    SoCal
    Probably a lil too much flex but fuck it... Run it and tune it.
    My fancy RR10 bomber no matter how I tuned it and threw money at it didn't crawl anywhere near what my OG circa 2002 TLT build would do.
    Needless to say if it works it works!
  10. Jan 26, 2025 at 7:37 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I always liked that neon green deadbolt.
    I did the same to a wraith and a bomber. They both do well for trail runs and probably u4 if I was in shape to do that. Don't crawl that well on technical stuff though. Wraith is more technical and harder to control with similar power. But neither one crawls in comparison to my other trucks
    Deathbysnusnu likes this.
  11. Jan 26, 2025 at 7:37 PM
    nd4spdbh
    SoCal
    Getting ready for King of the Hammers... Obviously the 1/10 is coming. Recently changed to some secret sauce (it's not) In the rear with a droop spring to hold max flex until needed and reduced flex with shock position changes, both for the positive performance from my random testing.
    Also sorting some rock lights (low power draw)
    And a high power front light bar. I haven't found a light controller that doesnt chip voltage on higher amp draw things so master light switch and front light bar are manual.
  12. Jan 26, 2025 at 7:41 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    This thing has crazy flex. That's with the shocks extension limited internally to 100mm. There are no alternate mounts either. This was back in the late 90's/early 2000's, I think the hobby was still in the experimental stage.:rofl:
    The original springs made it stand tall and had little flex.
  13. Jan 26, 2025 at 8:29 PM
    nd4spdbh
    SoCal
    Psssssh. Experimental stage was the TXT TLT axle era cutting your own chassis plates outta aluminum flat stock plate, skid plates out of cutting board, to mount a random transmission to......
    Ax10 was a cake walk
  14. Jan 26, 2025 at 10:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, I pre-ordered it along with their rear cable exit end cap.
    lowmower and Strictlytoyz like this.
  15. Jan 27, 2025 at 5:12 AM
    odomandr
    Andy
    Fort Collins, CO
    Have y'all seen the spider 9 axles?
  16. Jan 27, 2025 at 7:22 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Been sold out for weeks, but they sure look good.
    Capecrawlers did a video on them recently.
    As much as LGRP's stuff looks really good, I was extremely disappointed in their CS when I asked them specific questions about their own products only to get generic replies that lead me spending more than I needed to.
    Something as simple as "our transmission" or other stuff is proprietary.
    Capecrawlers says the same about their Spider9 axles which, that I understand, but their MR24 transmission too? Motor mount? Etc.
    Also, the wheel caps on my LGRP wheels fall off.
    I can't recommend LGRP to people in good faith, at least not their CS. I'll still buy their wheels and tires though.
    lowmower and odomandr[QUOTED] like this.
  17. Jan 27, 2025 at 9:24 AM
    odomandr
    Andy
    Fort Collins, CO
    I previously didn't buy anything from them as the prices seemed out of line with other options from RC4WD and Injora. I heard such great things about meus that I went ahead with them. I just saw the spider 9s today when cape crawler did an unboxing and review. I like the scale looks and using universals with larger output seems like a good upgrade but when I saw the prices my flabber was gasted.
  18. Jan 27, 2025 at 9:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No kidding
    I got Injora shocks and I'm like man, they come with tons of goodies to aid in installation in a variety of chassis
    Then their other stuff like their axles, or motors, etc
    They're like the Icon line-up of Harbor Freight tools; cheaper but great quality
    That's why I was really rubbed the wrong way after asking for assistance on motor plates, transmissions, motors when I first reached out to LGRP (providing specifics)
    Ended up spending over $110 on two transmissions and I'm still out of commission :rofl:
  19. Jan 27, 2025 at 11:06 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    All parts should be here this week. Axles are in Denver. :bananadance:
    Has anyone else noticed the transmission for the FCX and SCX are the same mount on the skid plate? Only thing that changes is the motor mount for orientation. Is FMS and Axial in cahoots?
    Strictlytoyz and Kwikvette like this.
  20. Jan 27, 2025 at 11:21 AM
    odomandr
    Andy
    Fort Collins, CO
    I'm not sure who owns fms. I don't think it is horizon.
