Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Jan 30, 2025 at 9:40 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I will say the employees seem to be into the small scale stuff and are always working on some projects based on a scx24 or something else.
    Deathbysnusnu likes this.
  2. Jan 30, 2025 at 9:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I did a function check of my axles with the driveshafts disconnected.
    My front wheels spin pretty smoothy front or back
    My rear wheels won't spin at all by turning them, but they'll turn if I spin the driveshaft connected to it
    Pulling off the diff cover to see what's going on...
  3. Jan 30, 2025 at 9:47 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Exactly my suspicion. Too much play on the upper wormgear. But nooooooo, 1 oring is how it's supposed to be. All that gear slop is acceptable :crapstorm: bigger oring seemed to fix my issue kind of like in the video. I also have various metal washer shims arriving today from amain to mess with different preload in the gears
  4. Jan 30, 2025 at 9:48 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    From what I understand. In a worm gear setup the wheels should not be able to turn back and forth freely unless turned at the upper worm gear. Via driveshaft in your case
  5. Jan 30, 2025 at 9:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ah ok, thanks for explaining that.
  6. Jan 30, 2025 at 10:14 AM
    odomandr
    Andy
    Fort Collins, CO
    This is pretty normal for a worm gear axle
    I know on ar45 axles reverse was binding due to pinion needing shimming. Could try that
    Kwikvette[QUOTED] likes this.
  7. Jan 30, 2025 at 10:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll keep this in mind along with that video.
    A function check yesterday (running the actual motor) showed nothing but absolutely fluid motion.
    If on a descent it starts "stuttering" I'll definitely come back to this.
  8. Jan 30, 2025 at 10:23 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    From what I've read. If you can free spin both foward and reverse at the tires....thats not good
    My shit wouldn't bind with all 4 tires off the ground. Once weight of the truck was on the ground the rear end would bind up
  9. Jan 30, 2025 at 10:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No no
    The rear at the wheels doesn't turn at all by hand, but does via driveshaft
    The front turns freely at the wheels by hand forward and back, and via driveshaft
    The vehicle did not experience any issues at all when turned by the motor either
    Think there was confusion answering two people lol you guys already covered why the rear won't turn by hand at the wheels (cause of the worm gear)
    I didn't know that was a characteristic of a rear worm gear setup
  10. Jan 30, 2025 at 10:34 AM
    odomandr
    Andy
    Fort Collins, CO
    I've honestly attributed the down hill stutter to the worm unbinding and then binding again on descents. When I have a moment I'll have to watch this video
  11. Jan 30, 2025 at 10:36 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah that video @Deathbysnusnu describes it perfectly
  12. Jan 30, 2025 at 10:37 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Just pulled both apart. Front first. One O-ring on the driveshaft side of the gear only.
    Added 2nd O-ring to the other end, assembled and it was tight as hell, no spin.
    Removed 2nd O-ring. Removed stock O-ring from driveshaft side and placed it on the other end. Assembled and tested by hand, axle spins via the wheel, in forward direction only.
    Installed and tested on downhill. Big improvement in the front, became apparent there was still something in the rear.
    Took the rear apart, same thing, moved O-ring to back of worm gear. testing by hand, was not able to spin via the wheel, spun fine via shaft.
    Installed in vehicle, 90% of the lurching is now gone downhill in forward and reverse. Smooth as butter uphill and on flat ground. I'll run with this for now.
    Kwikvette likes this.
  13. Jan 30, 2025 at 10:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hell yeah thanks for posting this
    Nice to see you can start tackling these things ahead of time without the new transmission or mount
    Deathbysnusnu[QUOTED] likes this.
  14. Jan 30, 2025 at 10:41 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Just wanted to stop in and look, maybe spend money.
    Gonna visit the local guy here in town around 1:00 when he opens up, see what he has in stock for bodies.
    lowmower likes this.
  15. Jan 30, 2025 at 10:43 AM
    odomandr
    Andy
    Fort Collins, CO
    I'm guessing the meus axles have better tolerances (the metal). They spun so smooth prior to install. I tried them without drag break and the truck rolled. I never expected the worm gear axles at this size to free wheel like that.
  16. Jan 30, 2025 at 10:44 AM
    odomandr
    Andy
    Fort Collins, CO
    Who is that? You mean e team Lowell?
  17. Jan 30, 2025 at 10:46 AM
    odomandr
    Andy
    Fort Collins, CO
    I'd say it is worth stopping in for yourself once at least. I was in Greeley a bit more during Oct-Dec and popped in a few times. It's based out of a crummy truck mod shop so temper expectations
    lowmower and Deathbysnusnu like this.
  18. Jan 30, 2025 at 10:46 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Yeah, can't ever remember the name. RC shop in the back of the diesel shop down on Duff.
    odomandr[QUOTED] likes this.
  19. Jan 30, 2025 at 10:47 AM
    odomandr
    Andy
    Fort Collins, CO
    I spend more at e team than I have at jackwagon
  20. Jan 30, 2025 at 10:49 AM
    odomandr
    Andy
    Fort Collins, CO
    Yeah e team is over there off link lane. I like the electronics shop over there called mountain states electronics. And there is a place for nuts and screws over there too called cd fasteners. I get all my RC hardware there and should inquire about the smaller stuff too. Are you aware of those two spots?
