Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Feb 20, 2025 at 7:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You know, I'm here asking about weights but really I'm going to be a bit nervous about it on this second build.
    With the battery up front, I'm hoping to keep any weight I add down low.
    Deathbysnusnu[QUOTED] likes this.
  2. Feb 20, 2025 at 7:47 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    The battery location really does make a difference. That 3s (25g) is a lot of fun, very zippy, but the performance overall is better with the lighter 2s (17g). It's not even taller, just wider.
    I have a pair of single 150mah cells that might be able to fit in a lower location, and more towards the rear in my case. Weighing on the scale front to rear, 300 front, 200 rear right now.
    Kwikvette[QUOTED] likes this.
  3. Feb 20, 2025 at 8:30 PM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    But it's rotating mass so it's not as great as it might seem
    Deathbysnusnu likes this.
  4. Feb 20, 2025 at 8:50 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Got my body all painted up. Just need to make some windows and a windshield and it'll be Rady to mount on the chassis
    Hafaday, Bikinaz, lowmower and 2 others like this.
  5. Feb 20, 2025 at 10:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Geez, two comp crawlers now!
    My chassis and rear axle arrive on Monday :playball:
  6. Feb 21, 2025 at 9:20 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    So I went to hook up my wolf esc to my pc to mess with the setting and it failed to communicate. Decided to just hook it up to my valkyrie motor and just run it with whatever default settings it was sent with. Upon turning everything on my motor begins to smoke. Maybe a mistake by me? Idk, but motors toast and probably a faulty esc. Emailed mofo for some further guidance.
  7. Feb 21, 2025 at 9:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof that sucks dude
    Strictlytoyz[QUOTED] likes this.
  8. Feb 22, 2025 at 9:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    LGRP replacement axle housing, and tire arrived along with my Hard Park order!
    The axles look gooooood
    I'd argue the links are cut out a bit better than the chassis from MD
    The holes are perfectly round and there's no evidence of a lead in/out like I noticed on the chassis
    lowmower and Deathbysnusnu like this.
  9. Feb 22, 2025 at 9:31 AM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    Last pictures looking fresh.
  10. Feb 22, 2025 at 11:01 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Got it all figured out. Apperantly the esc was sent to me with brushed settings loaded. Ended up wiping the firmware and downloading some brushless settings and all is good. The only response from mofo I got about my situation was that the motor will smoke if esc is set to brushed. That's it. Nothing more. No next steps nothing. Now I just need to figure out what all these different settings do
    lowmower and Kwikvette[QUOTED] like this.
  11. Feb 22, 2025 at 11:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuuuucking aye
    Not sure if it was the tires, the shorter chassis, or both but the rig performed significantly better today
    On steep descents, I can actually stop the rig in place whereas before I had to forcibly continue otherwise the rear wanted to go sideways or force the front end to start pivoting
    Steep climbs like these don't require me to "bump" it at all
    And the narrower tires having given me back some steering angle helps in transitions like these a lot easier
    Hafaday, lowmower and Deathbysnusnu like this.
  12. Feb 22, 2025 at 1:28 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That's disturbing. That smoke came from something getting hot and melting. Have you had a chance to see if the motor still works?
  13. Feb 22, 2025 at 1:42 PM
    odomandr
    Andy
    Fort Collins, CO
    Might as well test it with direct power on 3s now.
  14. Feb 22, 2025 at 1:52 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    I've tested it with both my furitek esc and my moforc esc now that it has brushless firmware on it. Seems to be fine but idk if the damage has already been done. Idk if this is its full potential or not but seems alright.
  15. Feb 22, 2025 at 2:03 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Side shot comparison of my 2 rigs. My new turds got some clearance and sits way lower
    Hafaday, lowmower, Roody and 2 others like this.
  16. Feb 22, 2025 at 2:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Chassis partially assembled
    That short front end is really made to compliment their BOA setup
    The links too
    Shock mounting up front is on the links due to the BOA
    Can't wait to fully flex it
    Comes with two trays for the esc and rx, so I'll have to figure out what I want to run
  17. Feb 22, 2025 at 2:15 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    That thing is gonna be a beast
  18. Feb 22, 2025 at 2:16 PM
    odomandr
    Andy
    Fort Collins, CO
  19. Feb 22, 2025 at 2:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The rear axle is slightly narrower too compared to the front
    Supposed to help with climbing/turning and trying to squeeze between gates, something the 4WS users can easily do
    lowmower likes this.
  20. Feb 22, 2025 at 2:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
