Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. May 9, 2025 at 9:57 AM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Try re-linking the TX/RX together a few times and see if it works itself out. Maybe crack open the TX and see if it's just a loose wire on the trigger pot.
    IvanhoeTaco[QUOTED] likes this.
  2. May 9, 2025 at 10:11 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    I had no issues with TX before the "fire". Just been sitting for a month
  3. May 9, 2025 at 11:52 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I can't imagine it would just give up the ghost after sitting. It's either not fully linking, or maybe the TX was dropped, just reaching here.
    If the rates are not zeroed out upon link or startup, the throttle generally won't engage. Try the obvious first, center the throttle. If no luck, try setting the throttle a few clicks one way or the other, maybe the new ESC isn't recognizing the center of the throttle pot. Meaning, it "sees" throttle input upon startup.
  4. May 9, 2025 at 2:04 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    That didn't take long at all. CC is first up, just testing the breakover angle on both chassis. The 64mm tires made the difference and the CC made it over just fine. Slightly longer run for the 3d Snu chassis :D. I think they are actually very close, aside from the motor tilt and slightly better LCG of the CC. It would be really cool to have a 2nd driver and follow the leader to really see any differences.
    I'm gonna go back to the D-Glad link combo on this one because it's just a lot of fun. No need for two C-Bolts. I'll put up a link after I get it published.
    https://www.youtube.com/watch?v=KgcZVDmk3wM
    grambo911 and Kwikvette like this.
  5. May 12, 2025 at 6:32 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    An alternative, cheap but decent TX/RX combo.
    https://www.amazon.com/dp/B0B7X5XGLR?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
    I first saw this when building the Orlandoo Hunter kits.
    Then 24Yep did a review on one, had to give it a shot.
    RX is 1mm longer and 2mm narrower than a Spektrum. Spektrum is around $50, Turbo racing is around $16. Fits on the skid just fine.
    Much smaller pack size. Fits in a motorcycle top case and leaves room for more. Plus so cheap not a big deal if it's damaged.
    The menu takes a few minutes to figure out, and requires some patience during the learning curve. It automatically times out after about 10 seconds, so gotta be on your selection game.
    It has 15 model memory.
    How does it feel?
    Not too bad. It's cheap af. But feels solid in the hand.
    If you're familiar with the FMS TX's, then it feels about the same in the hand. The trigger was a bit notchy, I opened it up and put a drop of Tri-Flow on the moving parts and it is smooth now. The steering feels the same. Overall, not as fine and precise as the Spektrum, but there is a huge price difference, so it works great IMO :D. It works well enough that after about a 15 minutes with it, it felt fine and I was slaying lines like before.
    Edit:
    Video explaining how channels 3&4 work.
    https://www.youtube.com/watch?v=T8h-qikINLA
  6. May 15, 2025 at 2:48 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Damnit.... I have been wanting a smaller radio for my crawlers and maybe combine the two crawlers onto one radio, the fact it does expo and endpoints is perfect for my needs. I really wish that two radios could be bound to one receiver in the case I wanted to run both crawlers at the same time.
  7. May 15, 2025 at 2:59 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Two Receivers can be bound to this radio on the same channel, you can run two cars at the same time. I plan to try this and see if they will "follow the leader" on one transmitter. :D
    lowmower, nd4spdbh[QUOTED] and 50Buck like this.
  8. May 15, 2025 at 3:05 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    That has some cool implications. I'll probably wind up getting a tank like what I got for my brother, and a buddy will as well. We could get a synchronized group of tanks if we could link it all up. LOL
    Deathbysnusnu[QUOTED] likes this.
  9. May 15, 2025 at 3:38 PM
    nd4spdbh
    SoCal
    Interesting. Yeah i want the opposite. I have my big 1/10th crawler and my mini crawler, would be nice to have them on one radio, but then if the need arises which it has (take a buddy / gf etc) out crawling and both are getting ran you need two transmitters.
  10. May 15, 2025 at 4:05 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    For $36, get two and you're set. :cool:
    I might be misunderstanding the reviews on the multiple link of receivers, maybe they are talking about the multiple model memory. Which is odd, since it advertises it, and shouldn't come as a surprise..
    Mine came linked out of the box. I made settings for expo, end points, etc on memory one. I switched to a few different model channels, and the receiver still works, but without my settings. Those reappeared once it was back to model memory one. So I assume it will work multiple receivers at once. I'll let everybody know in a few weeks.
    lowmower likes this.
  11. May 16, 2025 at 8:30 AM
    nd4spdbh
    SoCal
    Eh more of wanting to consolidate. The 1/10th crawler has an older BIG bulky flysky GT3B. Id love to have a small transmitter for that and utilize the same one for the mini crawler then if both need to be ran just power up the mini crawlers receiver like normal without having to bind to its transmitter. But I dont know of any transmitter that allows 2 controllers to be bound to it at the same time.
  12. May 16, 2025 at 10:56 AM
    grambo911
    grambo911 Well-Known Member
    SF Bay Area, Kommiewokafornya
    2023 Lunar Rock Trail Edition
    AWE Exhaust, KARTBOY exhaust hangers, custom 1/0 exhaust grounding, lots of Titanium hardware from my old builds, silly JDM bits from my old Subaru builds, Uniden Bearcat Off Road CB, Firestik 2 w/custom CF mount, custom KARTBOY plate frame with Rigid Ind Spot on ball head mount, Yakima Mega Warrior w/custom CF cross brace. ARP extended studs (not installed yet), Optima Red Top, Siless Insulation in cab. Diode Dynamics LEDs throughout... More titanium fasteners. K&N intake snorkus delete. Greddy hose clamps throughout. DBA 4000XS Brake Rotors. TRD PRO fogs. Dakine Tail Gate Pad. More to come of course.
    Picked up a vintage Tamiya Dynatech 02H. Gonna do the Toy Story 3 rehab to it tonight. Very excited. A NIB unit runs about $350. I got a very fair price, for this gem, out of the UK.
    Deathbysnusnu likes this.
  13. May 16, 2025 at 2:45 PM
    nd4spdbh
    SoCal
    Ok thats a freaking cool looking brushed motor!
    grambo911[QUOTED] likes this.
  14. May 16, 2025 at 5:07 PM
    Bikinaz
    Bikinaz It wasn't me!
    Hey You!
    Phoenix, AZ
    2014 Regular Cab 4x4 5MT
    Pelfreybuilt Skids. ModCo wheels. Sliders. Cruise Control. Intermittent Wipers. Fog Lights.
    I have lights!
    MGMDesertTaco, lowmower and Kwikvette like this.
  15. May 17, 2025 at 10:15 AM
    Bikinaz
    Hey You!
    Phoenix, AZ
    This is my first attempt of 1 handed driving. I did have to stop the video and use both hands to clear this, though. Also this is my first attempt to share a YouTube video. I'm not sure if this will work or is allowed. I tried to load it directly but I got an error message.
    https://youtu.be/dvoE48a9O1A?feature=shared
    nd4spdbh and Deathbysnusnu like this.
  16. May 17, 2025 at 3:58 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    This was my normal set up for all of my club races this season for the Micro B open class, the Mini B Modification class, and the Mojave Grom BLx class. My 11yo daughter runs in her Mini T 2.0 stock.class. I ended up.winning this seasons first place in points for the Micro B Modified class.
    Before the nights chaos....lol
    In between heats with charging, swapping out parts and Batteries, and overall fixing cars in between.
    Cipher94, Rodarbal, grambo911 and 5 others like this.
  17. May 19, 2025 at 10:05 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    Has anyone here ran any Injora 1.9" 4.19 tires? Finally getting around to finishing the Tacoma body swap on my 1/10 scale. I think I might pick up a set of Kraken Claws, they work great on my Ascent 18.
  18. May 19, 2025 at 6:34 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Newest build, hopefully I can make it to the dunes this weekend and get some time to rip it.
  19. May 20, 2025 at 5:24 AM
    lowmower
    Benji
    2011 Pyrite Mica V6
    Looks great!
    a2lowvw[QUOTED] likes this.
  20. May 20, 2025 at 12:15 PM
    grambo911
    Wait until I'm done with refurbishing. I have some details to finish up tonight. :]
    nd4spdbh[QUOTED] and Bikinaz like this.
