Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Feb 13, 2012 at 6:53 PM
    #2261
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Everybody needs to go back a page or two and check out that thread I posted. That dude made a Wraith do things that a Wraith never even bought about doing.
  2. Feb 13, 2012 at 6:53 PM
    #2262
    JStradaXR
    JStradaXR Well-Known Member
    Chuy
    Ontario CALI
    06 X Rated
    Everything but boost =[
  3. Feb 13, 2012 at 6:57 PM
    #2263
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    it'll fly like a brick though and it will handle like shit
  4. Feb 13, 2012 at 7:04 PM
    #2264
    DanglingFury
    Keith
    2006 4Runner 4x4
  5. Feb 13, 2012 at 7:18 PM
    #2265
    SACTOWN
    SACTOWN Well-Known Member
    Greg
  6. Feb 13, 2012 at 7:25 PM
    #2266
    DanglingFury
    Keith
    2006 4Runner 4x4
  7. Feb 13, 2012 at 8:35 PM
    #2267
    SACTOWN
    Greg
  8. Feb 13, 2012 at 9:14 PM
    #2268
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
  9. Feb 13, 2012 at 9:18 PM
    #2269
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    ^ nice deals, but is Venom aluminum any good? I always hear people compare them to Integy.
  10. Feb 13, 2012 at 9:32 PM
    #2270
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    So, what's that gonna buy you? Bulkhead I mean. Are the factory ones weak?
  11. Feb 13, 2012 at 9:33 PM
    #2271
    mjbtaco
    Michael
    Montclair , so cal
    supposedly its pretty good. i've seen people use their shocks mostly.
    im not too woried about the bulk head though. its just a hunkin piece of aluminum haha. dont see any problems arising from using them. i ordered 2 bulk heads and 2 complete sets of tires. we'll see how they turn out.
  12. Feb 13, 2012 at 9:34 PM
    #2272
    mjbtaco
    Michael
    Montclair , so cal
    yeah factory ones are plastic. a lot of people rip the arm mounts off the stock bulk heads. a lot harder to do that with aluminum. they also look a lot prettier :D haha
  13. Feb 13, 2012 at 9:50 PM
    #2273
    t4daddy
    North Alabama
    So, now the question is, does a set of A-arms and a set of hinge pins cost less than a bulkhead? And at what weight sacrifice? Some parts are designed to be the weak link.
  14. Feb 13, 2012 at 9:58 PM
    #2274
    mjbtaco
    Michael
    Montclair , so cal
    well this bulk head cost 11 bucks.
    a set of pro-line or rpm arms costs 10 bucks.
    stock traxxas hinge pins are like 4 bucks for a set.
    i have never broken an arm so i dont really worry about that happening. i dont do any extreme bashing so theres very little opportunity for me to do something that will cause that much damage.
  15. Feb 13, 2012 at 10:09 PM
    #2275
    t4daddy
    North Alabama
    Have you ever broken a bulkhead? That's kinda my point. Now you've chased your weakest link to the A-arms/pins. And if you break a arm now, your pin is now toast (because it can't give in the alloy bulkhead). I'm not trying to be an ass, there's just very few places aluminum is beneficial to an 10th scale model.
  16. Feb 13, 2012 at 10:13 PM
    #2276
    t4daddy
    North Alabama
    Does the bulkhead a least have "set" screws to keep the pin from rotating? If not, the alloy will wear way faster than plastic, and your front-end will have tons of slop before you realize it.
  17. Feb 13, 2012 at 10:17 PM
    #2277
    mjbtaco
    Michael
    Montclair , so cal
    well i look at it this way. if i break an arm all i have to do is swap out the arm and pins.
    if i break a bulk head i have to completely disassemble the entire front end of the truck.
    so I upgrade that because it is a lot less of a hassle to just replace a single arm and hinge pin than tear apart the truck.
    I have very few aluminum parts on my trucks.
    i have an aluminum bulk head and aluminum caster blocks. i upgraded the c blocks because those are common breaks.
    and with my current set up i have not broken any parts on my slash as far as suspension. so I believe teh upgrades i have made are very beneficial.
  18. Feb 13, 2012 at 10:19 PM
    #2278
    JStradaXR
    Chuy
    Ontario CALI
    06 X Rated
  19. Feb 13, 2012 at 10:24 PM
    #2279
    mjbtaco
    Michael
    Montclair , so cal
    the pins rotate inside of the bulk head they are "set" in the arms them selves.
    i've had my aluminum bulk head in my slash for 6 months and theres absolutely no slop in the bulk head.
  20. Feb 13, 2012 at 10:32 PM
    #2280
    Tacomanator
    Clam Slammer
    Southern Cali
    X2!! That thing is a bitch to get to!
    I have aluminum arms (bad I know) but I wonder what would happen if I got an aluminum bulk. My whole front end would pretty much be aluminum. Something would have to give somewhere, right?
