Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Mar 10, 2012 at 10:04 PM
    #3401
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    What motors are you both running?
  2. Mar 10, 2012 at 10:37 PM
    #3402
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Apparently HobbyPartz is going to my local track on Friday. lets see whats going on :D
  3. Mar 10, 2012 at 10:39 PM
    #3403
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Both are stock trucks with the vxl setup, only things we have done is add rpm bumpers.
  4. Mar 10, 2012 at 10:39 PM
    #3404
    mjbtaco
    Michael
    Montclair , so cal
    is the stampede 4wd and is the slash 2wd?
  5. Mar 10, 2012 at 10:40 PM
    #3405
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    both are 4wd
  6. Mar 10, 2012 at 10:42 PM
    #3406
    mjbtaco
    Michael
    Montclair , so cal
    a gear change will help. im pretty sure the stampede is lighter than the slash 4wd. they are essentially the same thing but the stampede is more scaled down. what gearing are you running now?
  7. Mar 10, 2012 at 10:53 PM
    #3407
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Im running stock gearing, I believe its 13/54, it came with a 18t pinion I can try out.
  8. Mar 10, 2012 at 10:54 PM
    #3408
    t4daddy
    North Alabama
    Is the Sampede more of a stadium truck vs. the Slash more of a short course truck? Sorry, I don't/can't keep up with Traxxas' models.
  9. Mar 10, 2012 at 10:54 PM
    #3409
    mjbtaco
    Michael
    Montclair , so cal
    yeah i usually run 18/56 so the 18/54 should give it a higher top speed.
  10. Mar 10, 2012 at 10:55 PM
    #3410
    mjbtaco
    Michael
    Montclair , so cal
    the stampede is more of a monster truck type thing.
  11. Mar 10, 2012 at 10:58 PM
    #3411
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Ill switch it out tomorrow and test it, if all else fails ill switch to a mmp sct 2400kv combo and a 3s running a 19/54 gearing. That should be more then enough to keep up. :cool:
  12. Mar 10, 2012 at 11:00 PM
    #3412
    mjbtaco
    Michael
    Montclair , so cal
    lol that will do the trick.
  13. Mar 10, 2012 at 11:03 PM
    #3413
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Yeah, but in doing that setup ill have to spend alot of $$, ill need to upgrade alot to be able to handle the power and not break crap, haha.
  14. Mar 10, 2012 at 11:03 PM
    #3414
    t4daddy
    North Alabama
    Now I understand. I would be embarrassed also if that thing out anythinged me. Well, maybe car crushing. The trannys have to be geared WAY different.
  15. Mar 10, 2012 at 11:04 PM
    #3415
    t4daddy
    North Alabama
    What am I thinking of, a Rustler?
  16. Mar 10, 2012 at 11:07 PM
    #3416
    mjbtaco
    Michael
    Montclair , so cal
    probably a rustler or bandit
  17. Mar 10, 2012 at 11:07 PM
    #3417
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    I just looked his up, hes running a 11/54 to my 13/54, not too big of a difference.
  18. Mar 10, 2012 at 11:10 PM
    #3418
    t4daddy
    North Alabama
    Not pinion/spur ratio. The ratio of the transmission.
  19. Mar 11, 2012 at 5:54 AM
    #3419
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    The tire size is also something to factor in with this Slash/Stampede discussion here. I think obviously the stampede is getting more traction and will have more top end due to the taller tires.
    If you want to make that slash scream get a Tekin SC411 motor and a mamba max ESC or equivalent.
  20. Mar 11, 2012 at 5:55 AM
    #3420
    mjbtaco
    Michael
    Montclair , so cal
    you mean tenshock sc411?
