Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Mar 13, 2012 at 2:56 PM
    #3701
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    I have ridden that bike, well not yours but my buddies. Tons of fun. I would get into trouble if I owned one. Would be jumping curbs.
  2. Mar 13, 2012 at 2:58 PM
    #3702
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Anyone know how much this is worth? Something is wrong with the engine, it just won't start. It's a XTM, not sure what model.
  3. Mar 13, 2012 at 3:10 PM
    #3703
    bill-e-boy
    bill-e-boy new and improved
    billy
    florence
    04 dbl cab lifted pre-Runner
    added factory roof rack, factory skid plate, removed cheesy running boards, built a pvc bike rack, added interior floor lighting, added decal plate under rear window, added sylvania silverstars, installed toytec ultimate 3" lift, added hella optilux yellow fog lights, added orange park lights to the turn signals, new 265/75/16 goodyear duratracs tires and raceline rockcrusher 16" wheels
    Florence, SC
  4. Mar 13, 2012 at 3:11 PM
    #3704
    TheOtherGuy
    TheOtherGuy Well-Known Member
    Cajun Country
    05 Access 4x4
    DanglingFury,
    I completely removed the optidrive module and plugged the servos directly into the receiver and now everything is working well. I ran about a half a tank through it and the throttle/brake worked the entire time. That wouldn't have happened before I removed it.
    I don't know if it is the module that went bad or the sensor(I am betting on the module) but I can replace both for about $25. My other option is to just keep the opti drive off and just be careful with the reverse.
    Thanks for the help.
  5. Mar 13, 2012 at 3:19 PM
    #3705
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, I am completely amazed. I have 2 5300mAh lipos that I run in my SC10 4x4 (Castle SCT brushless setup) and they run hard for 20 minutes and only use like half the battery. I probably only needed one of them. They wouldn't fit the Losi 22 (too thick), so I got a 3800mAh (setup to run brushless 17.5T stock) for the buggy, and same deal.
    Anyone know how many charge cycles you get on these lipos before they start to deteriorate?
  6. Mar 13, 2012 at 3:24 PM
    #3706
    DirtJumper14
    SoCal
    2005 TRD OR
    I have had 2 venom 5000mah 50c batteries for a year and a half racing at least 3 times a month in 2 cars. Balance them always, keep them cool and don't drop them and they will last for hundreds of charges +. I never run mine down all the way though.
  7. Mar 13, 2012 at 3:45 PM
    #3707
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I've rode/owned bikes of all types for over forty years, this is, by far the most fun. I've dropped in a big-bore (440) kit, along with a set of Hot Cams, 39mm flat slide carb, and full Ti Yoshi pipe, it's no race bike, but pulls good for what it is.
  8. Mar 13, 2012 at 3:53 PM
    #3708
    t4daddy
    North Alabama
    Kinda depends on how you treat them, Jumpers' advice is pretty spot on. I don't balance every time, (won't hurt) and the're are a zillion opinions on this. I balance at every five cycles, even that, (by some folks ideas) is over kill. Over discharging is the killer of li-pos.
  9. Mar 13, 2012 at 3:57 PM
    #3709
    DirtJumper14
    SoCal
    2005 TRD OR
    Some people don't always balance them and from what I have heard it doesn't have to be balanced every charge. But, I have the newer hitec 4x charger so I do it anyway since I have it. Had worked for me so far. I have some newer venom packs also but not as long as those. Good battery for the price and definitely better than a hobby people battery. Those go out quite often at the track.
  10. Mar 13, 2012 at 3:59 PM
    #3710
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    So I am going with the Holmes Bxl waterproof, I got the 20t motor in it(for now) and I got the winch and bec going.
    Feels good to get it binded and working. Now I got to figure out where I am going to place the mess of the wires!! Woohoo fun stuff.
    Plus needs paint!!
  11. Mar 13, 2012 at 4:14 PM
    #3711
    t4daddy
    North Alabama
  12. Mar 13, 2012 at 4:22 PM
    #3712
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    If I remember correctly balance charging is also safer since it charges it each individual cell as its own instead of all cells as a whole preventing overcharging other cells if one or more of the other cells are damaged, again I've been out of this for a while so please correct me if Im talking nonsense here
  13. Mar 13, 2012 at 5:01 PM
    #3713
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    No problem. I need to get motivated to tear into this t-maxx and get it going like it's supposed to. I think I'm going to try to get it working like it should. Sometimes that happens just because the batteries are weak. :notsure:
  14. Mar 13, 2012 at 5:20 PM
    #3714
    DanglingFury
    Keith
    2006 4Runner 4x4
    I'm gonna herp my derp till my shirt gets burped on URC tonight. You guys need to watch. I'll be sure to take plenty of screenshots.
  15. Mar 13, 2012 at 7:24 PM
    #3715
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    Tards are the best form of motorcycling on the planet.:cool:
  16. Mar 13, 2012 at 7:25 PM
    #3716
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    any updates?
  17. Mar 13, 2012 at 8:05 PM
    #3717
    t4daddy
    North Alabama
    At least the most fun.
  18. Mar 13, 2012 at 8:05 PM
    #3718
    t4daddy
    North Alabama
    Seems Keith threw us in a trick bag...
  19. Mar 13, 2012 at 8:39 PM
    #3719
    DanglingFury
    Keith
    2006 4Runner 4x4
    Hahaha sorry guys. Something more attractive (and with larger breasts) came up. :spy:
  20. Mar 13, 2012 at 9:38 PM
    #3720
    t4daddy
    North Alabama
    You couldn't get laid in a monkey prison with a bunch of bananas...
