Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Apr 4, 2012 at 8:40 PM
    #5101
    RicnDenver
    RicnDenver Stop talking and START wheeling
    Denver, Co.
    99 4Runner/04 4runner
    toyteclift, budbuilt, stubbs,
    I got me an Axial Wraith, its pretty fun.
  2. Apr 4, 2012 at 8:42 PM
    #5102
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
    Throw that battery to the front if it isn't all ready done and you will like it even more!!
  3. Apr 4, 2012 at 8:49 PM
    #5103
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Greg, what kind of lowers are those, Spikes? What'd they run you, if it's any of my business.
  4. Apr 4, 2012 at 8:49 PM
    #5104
    RicnDenver
    Denver, Co.
    its not there yet, I want to, and make a hinged hood to make replacing the battery easier. :cool:
  5. Apr 4, 2012 at 9:00 PM
    #5105
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Ill post one up when I get around to installing it, i soldered my traxxas connectors to the esc and to my gen ace lipo tonite, it was the first time i soldered anything in atleast 8yrs :eek:.
  6. Apr 4, 2012 at 9:05 PM
    #5106
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    So that servo you guys recommended I order?
    I ordered it a few days ago... Just now learning that Savox servos sometimes glitch or brown out because of insufficient BEC in castle ESC's...
    DEFECATE ON MY FACE.
  7. Apr 4, 2012 at 9:25 PM
    #5107
    t4daddy
    North Alabama
    As much as you desire that, I'll pass. Not a problem unless running above 4S IIRC. You should have no issues..
  8. Apr 4, 2012 at 9:44 PM
    #5108
    SACTOWN
    Greg
    Anderson manufacture I got them on special for 65 but they run 100 I believe
    It is a new company. All mil spec
  9. Apr 4, 2012 at 9:47 PM
    #5109
    SACTOWN
    Greg
  10. Apr 4, 2012 at 10:09 PM
    #5110
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
  11. Apr 4, 2012 at 10:41 PM
    #5111
    SoCalRoadie
    SoCalRoadie Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    I took the B4 to the track the other day. I had fun, but broke more than I expected. I'm running a stock 17.5t BL so I don't think going faster will help?
    I'm now interested in something more forgiving while I learn to drive. Something that will take my bad jumps and other track abuse. Some thing beefier.
    I've been looking at the 1/8th electric buggies and 1/10th 4x4 SCTs. My LHS supports AE/Traxxas and my track is AE/Losi.
    I know Traxxas is stupid tough but I don't want to sell it/drop a ton of cash into making it competitive with the real racing trucks. The RC8.2e looks like a tank and should take any abuse I throw at it. The SC10 4x4 looks pretty beefy and is cheaper. I would have to get a new esc/motor/servo unless I went Traxxas.
    I kinda have a direction but not a whole lot of momentum. Any suggestions? Thanks in advance.
  12. Apr 4, 2012 at 10:46 PM
    #5112
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  13. Apr 4, 2012 at 10:49 PM
    #5113
    t4daddy
    North Alabama
    You own one of the best platforms out there. I own both a B and a T4 those models are not that fragile. I, of course, don't know your driving skills, but a new model is not gonna correct bad habits. I'd suggest, slowing down and learning to drive what you have, you don't get in your real truck and just hammer it down do you? On a race track slower, is usually faster. The driver that crashes the least, most of the time finishes close to the front.
  14. Apr 4, 2012 at 11:12 PM
    #5114
    SoCalRoadie
    Jim
    Burbank
    Fair enough. All of my damage was related to jumping. I broke ball studs, shock ends, a rear bulkhead and cracked the front of my chassis. All of my racing experience is on road, all of my bashing is off road with little jumps. I also haven't driven any rc for the last 4-5 years...
    I was thinking a larger, tougher vehicle would be more forgiving to my driving. Then when I get better go back to the smaller, lighter B4.
    It could also be all the CF on the FT B4 I have. Would switching some key parts out make the buggy more forgiving? Chassis, arms, etc?
  15. Apr 4, 2012 at 11:25 PM
    #5115
    t4daddy
    North Alabama
    Damn dude, that's a lot of stuff broken. Make sure ball studs are tight, I find most of the ones that snap, are loose, but, they will "work harden" over time. The chassis kinda freaks me out, I've never even seen one broken. But yes, swapping to the composite (plastic, not carbon) chassis is more forgiving, same with the A-arms (I'd suggest RPM ones). Don't race against other drivers, just race the track, or yourself, and magically you'll do better..
  16. Apr 5, 2012 at 4:16 AM
    #5116
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I agree with t4daddy, that's a lot of broken stuff even for a terrible driver. I would have to chalk that up more to bad luck than anything else. Are these really big jumps, like on a larger track set up for the 1/8th scales? Are you overshooting? Undershooting?
    A bigger or more complex vehicle won't necessarily break less and will cost more in time and $ to fix. However, if the track is better suited to 1/8th scales, you may find it easier to drive an RC8. Or, you may need a little more power than the stock setup, just to let you get a little more control over your speed. Stock setups can take a bit to get moving, and if you are coming up short on jumps and that is what is breaking things, more available power could help. Of course, if you are already overshooting them, scratch the more power and just practice.
    Otherwise, I see no good reason to change until you can stop breaking what you've got.
  17. Apr 5, 2012 at 6:01 AM
    #5117
    SoCalRoadie
    Jim
    Burbank
    The track is built for 1/10th mod and 1/8th nitro. I can clear doubles fine just one double ends in a tabletop not a ramp down. That's my problem area if it's not a perfect landing. The triple I don't even attempt since I know I don't have enough power.
    What I perceived was the kids with their modded SCTs flying all over the track. Jumping too far and crashing with no broken parts. While my little buggy breaks on doubles? I figured I just had a fragile racing buggy and wasn't skilled enough to control it properly. Even the old guys with 1/8th were crashing harder than I was with no consequence.
    Like I said I still had fun, I just figured I might need to change classes till I can drive better.
  18. Apr 5, 2012 at 6:12 AM
    #5118
    DanglingFury
    Keith
    2006 4Runner 4x4
    Oh well, that's good. In both cases.
  19. Apr 5, 2012 at 6:21 AM
    #5119
    DanglingFury
    Keith
    2006 4Runner 4x4
    Are you undershooting the double and landing on your chassis instead of your tires?
  20. Apr 5, 2012 at 6:24 AM
    #5120
    RicnDenver
    Denver, Co.
