Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Apr 7, 2012 at 8:20 PM
    #5181
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Wraith axles. Yeah I put the big bore shocks on and the stock tires make it look like a 6 inch lift with 30 inch tires.
    Looks gay. I dont even want to take a picture of it; because it looks to goofy.
  2. Apr 7, 2012 at 8:40 PM
    #5182
    Lgs79
    Lgs79 Well-Known Member
    Luis
    Bay Point, CA
    2011 Tacoma 4x4 DC SB
    Just started going to a SC track with my slash and man I thought it was easy.
    It's hard but so much fun.
  3. Apr 7, 2012 at 8:45 PM
    #5183
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    Hobbypartz.com apparently finally has those new lipos in stock 5800mah 45C and 5000mah 65C :goingcrazy:
  4. Apr 7, 2012 at 10:41 PM
    #5184
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    better order em quick before they sell out lol
  5. Apr 8, 2012 at 1:44 AM
    #5185
    SACTOWN
    Greg
    Holy crap!! Most are all ready out of stock
  6. Apr 8, 2012 at 1:48 AM
    #5186
    DanglingFury
    Keith
    2006 4Runner 4x4
    They've all been out of stock for freaking ever.
  7. Apr 8, 2012 at 2:49 AM
    #5187
    mjbtaco
    Michael
    Montclair , so cal
    they're pretty horrible about restocking their items
  8. Apr 8, 2012 at 8:29 AM
    #5188
    DanglingFury
    Keith
    2006 4Runner 4x4
    People are claiming these "rare earth elements" lithium etc are scarce. That's why they aren't in stock... Other brands aren't out of stock, though. :notsure:
    I'm probably gonna order the 5800mah and try the 5900mah from valuehobby.com. I only have 2 4000mah lipos... needs moar!
  9. Apr 8, 2012 at 10:09 AM
    #5189
    SACTOWN
    Greg
    So I went out to run my slash this morning and something broke, help.
    It seems like it runs fine when I have the wheels spinning free, but as some as I put it on the ground it does not move.
    The motor runs fine also the tranny moves, but it seems like the axles don't. I believe it my be the slipper clutch but not sure
    Any ideas before I open it up?!?!
    Thanks
  10. Apr 8, 2012 at 10:14 AM
    #5190
    SACTOWN
    Greg
    I say the slipper cutch because it turns fine when the wheels are off the ground, but as soon I put it on the ground the spring and nut stop moving
  11. Apr 8, 2012 at 10:51 AM
    #5191
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    Sounds like the slipper has loosened up on it. Tighten it and see for sure.
  12. Apr 8, 2012 at 11:05 AM
    #5192
    SACTOWN
    Greg
    It looks like a lot of work. Seems like I have to pull the motor, tranny, Axle cover and couple of things. Then I have to get my big old hands in the small little area.
    Looks like a lot of work
  13. Apr 8, 2012 at 11:10 AM
    #5193
    SACTOWN
    Greg
    Random poser shots.
    Enjoy
  14. Apr 8, 2012 at 11:25 AM
    #5194
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Its not that much, i pulled mine completely apart yesterday and re filled my front and rear diff, checked all my gears. I would guess the slipper clutch also, on mine i can tighten it without taking anything apart, i assume yours is the same way?
  15. Apr 8, 2012 at 11:31 AM
    #5195
    SACTOWN
    Greg
    After looking more closely
    I think so with the exception of the cover on the drive shaft.
  16. Apr 8, 2012 at 11:35 AM
    #5196
    t4daddy
    North Alabama
    Again not really familiar with those type models, but on my models, it takes longer to get the 1/4 driver out of the tool box than to adjust the slipper.
  17. Apr 8, 2012 at 11:37 AM
    #5197
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Just looked at mine again, you will need to pop off the rear section, which is just 4 easy accessable bolts.
  18. Apr 8, 2012 at 11:48 AM
    #5198
    SACTOWN
    Greg
    Eating. I will check in a bit
  19. Apr 8, 2012 at 12:46 PM
    #5199
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    Well I just dumped another $250 for the protrac kit, beadloc's, trenchers, mip cvd kit for the front, mip axles for the front, and proline powerstrokes for the front. This will get me back running, ill upgrade the rear the same way when i break something (which wont be long im guessing).
  20. Apr 8, 2012 at 1:57 PM
    #5200
    DanglingFury
    Keith
    2006 4Runner 4x4
    Yupp... I've seen a lot of trucks absolutely covered with Monster Energy stuff. A lot of people like to put bro'd out tundra bodies on their rock crawlers.
