Anyone into R/C?
Discussion in 'Sports, Hobbies & Interests' started by A.D., Feb 7, 2009.
  1. Dec 3, 2012 at 7:25 PM
    #8621
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    I just sniped a brand new, in packages FT ball diff w/ bearings, cases, the works for 35
  2. Dec 3, 2012 at 7:36 PM
    #8622
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    Is anyone looking for a new replacement engine? Im trying to move this one so I can get a truggy some kid in the neighborhood is selling cheap. I am looking to get $200 has 3 shoe clutch & bb bell on it already. Brand new never installed.
    Ofna Racing Picco .26 Max JL Red Dot Engine W/Pull-Start - Ofn part #51225
    Features: Specifically engineered as a direct replacement for the stock Traxxas T-Maxx or Revo engine. Uses existing Traxxas clutch assembly, manifold and pipe. Composite body slide valve carburetor. Black in color with 10-fin black cylinder head.
    Designed to Fit All T-Max and Revo Applications * Modified Crank * JLR Red-Dot Technology * CNC Cooling Head * Timing has been Changed to Create More Top End with a big block exhaust.
    Overview == Picco has worked its modifying magic again, applying it to the already proven line of MAX engines. The same lightening of the crank and trademark red putty that were used in the highly successful JL off-road and on-road Red-Dot engines have been applied here to increase performance dramatically. Use of this same technology combined with big block power to tear up the competition, pop wheelies and soar through the air with the kind of speed you never thought was possible.
  3. Dec 3, 2012 at 7:49 PM
    #8623
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    you should sell it on rctech, way more RC people there
  4. Dec 3, 2012 at 9:06 PM
    #8624
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    People forget that the glitching problem has to do with the internal bec in the esc 99% of the time. I have had 0 problems with my savox servos, except when I ran a shitty ezrun esc.
  5. Dec 3, 2012 at 9:08 PM
    #8625
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    ^this
  6. Dec 3, 2012 at 9:26 PM
    #8626
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Well i ordered the rx8/tekin 1900kv combo, savox 1256tg, and 2 sets of aka motos mounted for my dad, also threw in 2 sets of aka city blocks for my truggy, figured since im spending that much might as well get something for me..
    I had a glitching issue and a range issue with my slash, turns out my motor/esc wires were too long, shortened them up and its good to go.
  7. Dec 3, 2012 at 9:30 PM
    #8627
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I've seen more than a few times with Tekin RX8s (6v and 5amp) BECs. And again some never have the problem. You can read about it all you want, and more over on RCTech. Just search "Savox Spectrum brown out".
  8. Dec 3, 2012 at 10:03 PM
    #8628
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    you're talking about two different things lol it's either the tekin rx8 or its the spektrum and savox. As I run spektrum and savox on a few tracks including near 2 international airports 1 of which was inside a giant metal building.. I've never glitched. I'm more inclined to blame Rx8.
    I have however had my 1/8 go into failsafe for a second but that uses airtronics.
  9. Dec 3, 2012 at 10:37 PM
    #8629
    t4daddy
    North Alabama
    The only reason I brought up Tekin was in response to Taco saying the only time he'd had a issue was running lesser ESCs. RX8s put out 6v 5amp for the servo. Again, I've seen the very same set-ups, some with, some with out the issue. There's a few hundred pages on RCTech concerning it. Castle can have these issues as well, prolly why they make the external BEC.
  10. Dec 3, 2012 at 10:42 PM
    #8630
    t4daddy
    North Alabama
    You keep saying glitch, which is radio inference of some sort. This is brown out, were the servo pulls more power than the reciever can provide.
  11. Dec 3, 2012 at 11:03 PM
    #8631
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    I'm running 2 airtronics servos and the receiver handles it fine lol I'm not convinced there's a brown out. Rx8's internal BEC maybe but not internal BECs in general nor the receiver
  12. Dec 3, 2012 at 11:09 PM
    #8632
    t4daddy
    North Alabama
  13. Dec 3, 2012 at 11:55 PM
    #8633
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    This thread confirms what I'm saying lol has nothing to do with the receiver, or servo, it's a shoddy internal BEC. The only people who say its the receiver have an unbacked bias against spektrum. this explains perfectly why I have no problems with my electric car which uses 1 servo, nor my 1/8 that uses 2 much less efficient servos that draw off of a smaller battery.
  14. Dec 4, 2012 at 12:03 AM
    #8634
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Looks good, so that will ship with my car then?
  15. Dec 4, 2012 at 12:07 AM
    #8635
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    R/C are ***** fast
  16. Dec 4, 2012 at 12:29 AM
    #8636
    t4daddy
    North Alabama
    It's the Spectrum receivers inability to pass voltage through, to power hungry Savox servos. I run Spectrum in all my RC cars, with no issues, with a Radiopost, Futaba, and a JR servo. I fly my planes and helis with Spectrum, even using the ultra cheap Orange Rx in them, no problems. The fact remains, that running a Spectrum radio, and Savox servo with any ESC, MAY cause some problems.
  17. Dec 4, 2012 at 12:37 AM
    #8637
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    There is no evidence to support that claim, save the couple people bashing spektrum, the discussion is on BECs.
  18. Dec 4, 2012 at 12:50 AM
    #8638
    t4daddy
    North Alabama
  19. Dec 4, 2012 at 1:15 AM
    #8639
    Dmonkey
    Branden
    NorCal
    VZN159L (2002 DC)
    Listen, if its an inherent problem with the savox and spektrum combo then you can expect it to happen to a large majority. These things are not home built to random specs. It would be a vast majority of people having problems with it, not a random one or 2 here and there. You are not justified in saying that it's spektrum causing it, it's not good science or deduction.
    People are also bashing Castle BEC's for being shitty so once again we can draw only 1 conclusion.. If the item responsible for keeping steady voltage going to the receiver isnt any good, its not the receiver's fault, nor is it the savox's fault.
    Everything being discussed is extremely vague "the spektrum guys always have problems" Well at all the tracks I've been to where the bulk of people are running spektrum, it's not something anyone discusses.. because it doesnt happen. So who's opinion is fact?
    Explain how I've been running this combo for months now and have not had so much as a stutter from my car? If the combo is bad then the combo is bad, it's something you can replicate. You don't get to try and sway people away from something and claim they "may" have a problem when you have people speculating that it's this or that. there is no tangible proof of there being anything wrong other than 3rd party speculation and vague generalities about how spektrum just sucks in general.
    The whole thing is opposite of scientific, it's a bunch of people circle jerk googling the same info and rehashing it in their own words.
  20. Dec 4, 2012 at 2:30 AM
    #8640
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Lets just all switch back to 27mhz
